[Solved] Black screen - I can't run any project
greatd
Postby greatd » Tue Jun 11, 2019 8:54 am
Hello,
I have the same issue like described on here -> https://forum.freecadweb.org/viewtopic.php?t=36087
OS: Windows 7
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Polish/Poland (pl_PL)
.17 version was working well, how to solve that problem?
Reason: Changed to [SOLVED]
Re: Black screen - I can't start any project
Postby chrisb » Tue Jun 11, 2019 10:11 am
... and how about the hints given in there? E.g. trying latest 0.19, changing GC driver?
greatd
Postby greatd » Wed Jun 12, 2019 7:03 am
I just checked how it works on .19 version:
The only difference between .18 and .19 versions is that in newer one only workspace is black, while .18 is completely black.
I've tried to update my drivers but it doesn't really help.
jmaustpc
Re: Black screen - I can't run any project
Postby jmaustpc » Thu Jun 13, 2019 4:24 am
Qt version: 5.6.2
You must be compiling against the old lib pack. Sgrogan in the last post of the topic you linked to is the one who compiled the Windows builds. He link to the downloads page for 0.19, one of the files "FreeCADLibs_12.1.2_x64_VC15.7z" is a newer lib pack. It uses QT5.12.1 and was compiled with VC15, you may need to update your VC version, sgrogan will know as other may also.
Jim
Postby Kunda1 » Thu Jun 13, 2019 6:09 pm
@chrisb should we merge this post in to https://forum.freecadweb.org/viewtopic.php?t=36087 ?
Postby chrisb » Fri Jun 14, 2019 12:14 am
I don't think so, the link should suffice.
carlopav
Postby carlopav » Sat Jun 22, 2019 9:37 pm
Sorry to make more noise here. I think i have same problem.
last working version was:
OS: Windows 7
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
Instead today i tried this one, and the problem showed up:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17091 (Git)
Hash: 4a0be9d3ba28ca14906574370de1f2f005af0d54
Python version: 3.6.8
Qt version: 5.12.1
Graphic driver: Nvidia GForce GT 540M
Postby chrisb » Sat Jun 22, 2019 10:38 pm
Can you try to uncheck Preferences->Display->Use OpenGL Vertex Buffer Object.
sgrogan
Postby sgrogan » Sun Jun 23, 2019 5:39 pm
Any chance this has something to do with it?
https://github.com/FreeCAD/FreeCAD/blob ... GL.h.cmake
"fight the good fight"
carlopav
Postby carlopav » Sun Jun 23, 2019 8:54 pm
Thanks for the quick reply. Unluckly, no way, I also updated last display drivers but it doesnt help with the version above...
Instead I tried last Conda Build (FreeCAD_0.19.17108_x64_Conda_Py3QT5-WinVS2015.7z) and this works perfectly...
OS: Windows 7
Version: 0.19.17108 (Git)
Hash: e632e9feb8a9dd56d5a879f2afef636cc159095e
Qt version: 5.6.2
