compile with netgen for FEM meshing
reox
Postby reox » Mon Jun 24, 2019 11:28 am
As described in this thread https://forum.freecadweb.org/viewtopic.php?f=18&t=35210 I try to create a version of FC with netgen enabled for FEM meshing.
It looks like that the meshing works fine in the mesh design WB, but fails in the FEM WB.
I build on a machine using debian unstable, the full build log can be found here: https://files.reox.at/.buildlog/freecad ... 4_0013.txt
For me, this looks like either some dependency is wrong, or I use the wrong flags.
Is it possible that the SMESH library is too old, when the internal version is used?
But currently there is no salomes mesh in debian IMO.
For the package versions installed, please consult the build log (just grep for "Setting up " in the log)
Summary:
00:18:34 O: -- Python:              [/usr/bin/python3] [.cpython-37m-x86_64-linux-gnu]
00:18:34 O: -- PCL:                 1.9.1
00:18:34 O: -- pybind11:            2.2.4
00:18:34 O: -- Boost:               106700
00:18:34 O: -- XercesC:             [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
00:18:34 O: -- ZLIB:                1.2.11
00:18:34 O: -- PyCXX:               [/build/freecad-daily-0.19+git201906240013~daily/src]
00:18:34 O: -- OCC:                 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
00:18:34 O: -- SMESH:               build internal
00:18:34 O: --  MEDFile:            [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
00:18:34 O: --  HDF5:               1.10.4
00:18:34 O: --  VTK:                7.1.1
00:18:34 O: -- NETGEN:              6.2-dev [-DNO_PARALLEL_THREADS;-DOCCGEOMETRY;-DNETGEN_VERSION=393728] [] [/usr/include/netgen/include;/usr/include/netgen] [nglib] [/usr/include/netgen/include;/usr/include/netgen]
00:18:34 O: -- SWIG:                3.0.12
00:18:34 O: -- Eigen3               3.3.7
00:18:34 O: -- Qt5Core:             5.11.3
00:18:34 O: -- Qt5Network:          5.11.3
00:18:34 O: -- Qt5Xml:              5.11.3
00:18:34 O: -- Qt5XmlPatterns:      5.11.3
00:18:34 O: -- Qt5Widgets:          5.11.3
00:18:34 O: -- Qt5PrintSupport:     5.11.3
00:18:34 O: -- Qt5OpenGL:           5.11.3
00:18:34 O: -- Qt5Svg:              5.11.3
00:18:34 O: -- Qt5UiTools:          5.11.3
00:18:34 O: -- Qt5Concurrent:       5.11.3
00:18:34 O: -- Qt5WebKitWidgets:    5.212.0
00:18:34 O: -- Shiboken2:           5.11.2 [/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.11.2] [/usr/include/shiboken2]
00:18:34 O: -- PySide2:             5.11.2 [/usr/include/PySide2]
00:18:34 O: -- PySide2Tools:        [/usr/bin/pyside2-uic] [/usr/bin/pyside2-rcc]
00:18:34 O: -- Freetype:            2.9.1
00:18:34 O: -- OpenGLU:             /usr/lib/x86_64-linux-gnu/libGLU.so [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include]
00:18:34 O: -- Coin3D:              [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
00:18:34 O: -- SPNAV:               [/usr/lib/libspnav.so] [/usr/include]
00:18:34 O: -- Matplotlib:          3.0.2
00:18:34 O: -- Rift:                not enabled (BUILD_VR)
00:18:34 O: -- Doxygen:             not found
configuration flags:
-DFREECAD_BUILD_DEBIAN=ON
-DBUILD_QT5=ON
-DBUILD_FEM_NETGEN=ON
-DBUILD_FLAT_MESH=ON
-DFREECAD_USE_PYBIND11=ON
-DFREECAD_USE_PCL=ON
-DPYTHON_EXECUTABLE=/usr/bin/python3
-DCMAKE_BUILD_TYPE=RelWithDebInfo
-DCMAKE_CXX_FLAGS="-Wall -DHAVE_SWIG=1 -fpermissive -g -O2 -fdebug-prefix-map=/build/freecad-daily-0.19+git201906240013~daily=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" -DCMAKE_C_FLAGS="-Wall -fpermissive -g -O2 -fdebug-prefix-map=/build/freecad-daily-0.19+git201906240013~daily=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2"
-DCMAKE_SHARED_LINKER_FLAGS="-Wl,-z,relro -Wl,-z,now"
-DLIB_SUFFIX=""
-DCMAKE_INSTALL_PREFIX="/usr/lib/freecad-daily"
-DCMAKE_INSTALL_DATADIR="/usr/share/freecad-daily"
-DCMAKE_INSTALL_LIBDIR="/usr/lib/freecad-daily/lib"
-DCMAKE_INSTALL_DOCDIR="/usr/share/doc/freecad-daily-doc
sgrogan
Re: compile with netgen for FEM meshing
Postby sgrogan » Mon Jun 24, 2019 8:58 pm
On Windows the 12.1.2 libpack builds use OCC 7.3, NetGen 6.2, and internal SMESH
These builds use PY 3.6, we have seen some stuff with PY3.7?
reox
Postby reox » Tue Jun 25, 2019 7:52 am
hmm so maybe py3.7 is the culprit?
The thing is, there is not 3.6 on debian... stretch uses 3.5 and buster 3.7
but on stretch this will not compile as the dependencies are missing
looo
Postby looo » Tue Jun 25, 2019 8:03 am
py3.7 in general shouldn't be the problem. At least on linux meshing with netgen in fem-workbench works.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
looo
Postby looo » Tue Jun 25, 2019 9:41 am
Didn't see netgen isn't used anymore for weekly conda-builds (win).
https://ci.appveyor.com/project/looooo/ ... true#L1070
reox
Postby reox » Tue Jun 25, 2019 9:51 am
hm, yes it kind of works, I get a mesh, but the display is complete crap. Maybe someone can create a small mesh with netgen and post it here? If it shows the same number of nodes, edges, ... but the display is broken too, we would have some indicator where the error is coming from.
UR_
Postby UR_ » Tue Jun 25, 2019 10:03 am
Screenshot 002.png (85.53 KiB) Viewed 618 times
FEMMeshNetgen.FCStd
(348.19 KiB) Downloaded 11 times
Version: 0.19.17127 (Git)
Hash: 00f082c97de187da3917fa29d8868b1be9c323e0
Python version: 3.7.1
Qt version: 5.6.2
reox
Postby reox » Tue Jun 25, 2019 4:43 pm
As soon as I recompute the mesh:
looks like the netgen is the culprit?
Is it possible to test netgen without freecad? I.e.
$ netgen -something -whatever generic_testfile
and compare the output?
maybe 6.2.1810 does work? But this is hanging in the NEW queue:(
UR_
Postby UR_ » Tue Jun 25, 2019 6:52 pm
netgen standalone can be obtained by: https://ngsolve.org/downloads
external meshing workflow will be:
- export FreeCAD geometry as .brep file
- import into netgen standalone
- mesh with netgen
- set export format to "Abaqus"
- export mesh (don't forget to set extension explicitly to .inp)
- import .inp into FreeCAD FEM analysis
example (netgen 6.2.1903):
cylinder external meshed by netgen.zip
(29.04 KiB) Downloaded 10 times
reox
Postby reox » Tue Jun 25, 2019 7:53 pm
thanks for the documentation!
I tried with the cylinder from your FC file and set the mesh to "very fine":
1 solid(s)
Preparing visualization (deflection = 0.01) ... done
 Face 1 / 3 (parameter space projection)
 Face 2 / 3 (parameter space projection)
 Face 3 / 3 (parameter space projection)
 Optimize Surface 1
 Optimize Surface 2
 Optimize Surface 3
 Meshing subdomain 1 of 1
 Delaunay meshing
 start tetmeshing
 Success !
 2426 points, 12278 elements
 Remove Illegal Elements
 Volume Optimization
 Meshing done, time = 4.35895 sec
 Export mesh to file /home/reox/tmp/ngtest/mesh.inp.... Please Wait!
 Export mesh to file /home/reox/tmp/ngtest/mesh.inp, format is Abaqus Format
I can open the resulting inp file no problem at all and it still looks the same as in netgen.
So I would suspect that SMESH is the problem here as I can confirm that freecad is handling meshes fine and netgen is producing them correctly.
It almost looks like that the NETGENPlugin_Mesher class is not working correctly?
From the git log I see that it should work with 6.2 - see git commit 55160cf50db0b433c9dd13e9e3573ae8c19fa190
Which is interesting, as there is the folder src/3rdParty/salomesmesh/src/NETGEN which says something about netgen 4.5... maybe this folder should be removed?
anyways, I double checked in the build that the NETGEN_VERSION is set correctly, it is set to 393728 == (6 << 16) + (2 << 8).
In the build log I only see a few warnings about redefinitions and casts regarding the NETGENPlugin, but nothing which concerns me (but I'm no C++ pro by any means)
I stripped the lines from the full log: https://files.reox.at/NETGENPlugin_build.txt (due to parallel build, there are some unrelated lines as well)
maybe someone finds a clue there?
