AppImage 0.19.17349 - Test Framework test errors
Postby Kunda1 » Mon Jul 15, 2019 10:59 am
Ran Test Framework on the following FC version and found 3 errors:
OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.17349 (Git) AppImage
Hash: 7eccda34d090ab641b29fa4be24c515cfa39c601
Python version: 3.7.3
Qt version: 5.9.7
File "/tmp/.mount_FreeCADoqw5c/usr/lib/python3.7/unittest/case.py", line 59, in testPartExecutor
yield
File "/tmp/.mount_FreeCADoqw5c/usr/lib/python3.7/unittest/case.py", line 615, in run
testMethod()
File "/tmp/.mount_FreeCADoqw5c/usr/Mod/Fem/femtest/testsolverframework.py", line 232, in test_solver_framework
ret = testtools.compare_files(startinfo_given, startinfo_totest)
File "/tmp/.mount_FreeCADoqw5c/usr/Mod/Fem/femtest/utilstest.py", line 180, in compare_files
file2 = open(file_name2, 'r')
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/FEM_unittests/FEM_solverframework/ELMERSOLVER_STARTINFO'
yield
testMethod()
File "/tmp/.mount_FreeCADoqw5c/usr/Mod/PartDesign/TestPartDesignGui.py", line 202, in testMoveSingleFeature
self.assertEqual(len(self.BodySource.Group), 0, "Source body feature count is wrong")
File "/tmp/.mount_FreeCADoqw5c/usr/lib/python3.7/unittest/case.py", line 839, in assertEqual
assertion_func(first, second, msg=msg)
File "/tmp/.mount_FreeCADoqw5c/usr/lib/python3.7/unittest/case.py", line 832, in _baseAssertEqual
raise self.failureException(msg)
AssertionError: 1 != 0 : Source body feature count is wrong
yield
testMethod()
File "/tmp/.mount_FreeCADoqw5c/usr/Mod/PartDesign/TestPartDesignGui.py", line 145, in testRefuseToMoveSingleFeature
self.assertEqual(len(self.BodySource.Group), 3, "Source body feature count is wrong")
AssertionError: 4 != 3 : Source body feature count is wrong
looo
Re: AppImage 0.19.17349 - Test Framework test errors
Postby looo » Tue Jul 16, 2019 1:56 pm
is this still valid for the latest available build (17360)? I skipped tests for one of the earlier builds.
minimalistic blog: https://looooo.github.io/mini-blog/
Postby Kunda1 » Tue Jul 16, 2019 3:10 pm
Yes, can reproduce them on
Version: 0.19.17360 (Git) AppImage
Hash: 348160d4ea970f5f6d0850272c04800c0222c8ba
Qt version: 5.9.7
looo
Postby looo » Tue Jul 16, 2019 7:49 pm
For me everything is green:
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Qt version: 5.9.7
Postby Kunda1 » Tue Jul 23, 2019 10:42 pm
bernd wrote:
@bernd can you reproduce the FEM test issues?
triplus
Postby triplus » Sun Aug 25, 2019 10:52 pm
Is this still an issue, and if yes, is it specific to AppImage?
Postby Kunda1 » Tue Aug 27, 2019 12:09 am
Just ran test framework on latest appimage
results: https://pastebin.com/F0GbNfza
Version: 0.19.17798 (Git) AppImage
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Qt version: 5.9.7
triplus
Postby triplus » Tue Aug 27, 2019 1:38 pm
Great, will take a closer look over the weekend.
Postby Kunda1 » Tue Aug 27, 2019 5:23 pm
Much thanks
triplus
Postby triplus » Sat Oct 05, 2019 3:13 pm
There was one SSL related issue detected in the log file, mentioned here:
https://forum.freecadweb.org/viewtopic. ... 79#p338679
This issue was AppImage specific and it should be fixed now. Other issues are more or less related to external modules and are likely not related to AppImage. Like CADExchanger module, missing import FreeCAD statement. But i couldn't reproduce it, therefore you might have an older version of the module installed. Part-o-magic likely newer was tested in Test framework environment, hence a few errors.
DeepSOIC wrote:
