But I've been adding icons to the AddonManager so they display correctly in the UI. The .qrc file is where the icons are registered in order to be displayed.
I don't know what could be the issue either... pyrcc works ok here with the current AddonManager qrc file...
Maybe some of the new icons that contains something that your version of pyrcc doesn't like?
If you're wiling to help debugging this, maybe you could browse through the recently added icons ( https://github.com/FreeCAD/FreeCAD/comm ... /Resources ) and delete their entries from AddonManager.qrc (the actual svg file can stay there) until we find the culprit?
yorik wrote: ↑Thu Aug 15, 2019 5:36 pm
It builds for me but I get an error about AirPlaneDesign_workbench_icon.svg file not found
In the source the icon is named AirPlaneDesign_workbench-icon.svg
I get a similar error with the Arch_rc.py where for some reason the generated file is too small because somehow it gets truncated. I wonder if the pyrcc tool has a problem.
