conda build win 10 stopped working since Link merge
UR_
Re: conda build win 10 stopped working since Link merge
Postby UR_ » Sat Aug 24, 2019 8:16 am
Anybody has to check, if patch is located correctly inside #ifndef _PreComp_ clause, because I'm building without PCH :(
looo
Postby looo » Mon Aug 26, 2019 7:13 am
What about a PR?
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
UR_
Postby UR_ » Mon Aug 26, 2019 8:15 am
wmayer wrote::bell:
realthunder
Postby realthunder » Mon Aug 26, 2019 8:21 am
I see, the problem is caused by missing array header. I think you'll need to include the array header in App/PreCompiled.h as well.
easyw-fc
Postby easyw-fc » Sun Sep 01, 2019 1:45 pm
Any news on this? Win Conda builds are still pre-Link3 merge...
looo
Postby looo » Sun Sep 01, 2019 1:52 pm
I guess we are running into build-time limitations. Maybe switching windows to azzure will solve this issue.
There were also changes to the doc-install location. So I guess the error reported by ci is because of the wrong doc-dir which I wanted to delete.
https://ci.appveyor.com/project/looooo/ ... 3452#L8688
https://github.com/looooo/freecad-feeds ... ild.sh#L45
If anyone knows where the new location of the docs is please post them here.
looo
Postby looo » Tue Sep 03, 2019 11:01 am
After trying another time, it seems like we are running into 2h limitation of appveyor. I will do a local build for now, but I guess at some point it would be nice to find a better solution. Going to azure shouldn't be too much work, but the logs are not in order for the win-azure build.
UR_
Postby UR_ » Tue Sep 03, 2019 11:51 am
Just finished without problems :crossed_fingers:
OS: Windows 10 (10.0)
Version: 0.19.18040 (Git)
Hash: 94f6f984e06ddc168b5f9fe4fb95b160a1028717
Python version: 3.7.3
Qt version: 5.9.7
Unfortunately couldn't upgrade from qt 5.9.7 to qt 5.12.1 :(
(conda is complaining)
looo
Postby looo » Tue Sep 03, 2019 2:45 pm
qt5.12 environment for freecad shouldn't be a problem. Do you have any additional deps?
UR_
Postby UR_ » Tue Sep 03, 2019 5:07 pm
No additional deps - env used only for build
(freecad-dev) C:\Users\aio>conda list
# packages in environment at C:\Users\aio\Miniconda3\envs\freecad-dev:
# Name                    Version                   Build  Channel
boost-cpp                 1.70.0               h6a4c333_2    conda-forge
bzip2                     1.0.8                hfa6e2cd_0    conda-forge
ca-certificates           2019.6.16            hecc5488_0    conda-forge
certifi                   2019.6.16                py37_1    conda-forge
clang                     8.0.1                he980bc4_0    conda-forge
clang-tools               8.0.1                he980bc4_0    conda-forge
clangdev                  8.0.1                         0    conda-forge
clangxx                   8.0.1                         0    conda-forge
coin3d                    4.0.0             h1df4a3b_1006    conda-forge
curl                      7.65.3               h4496350_0    conda-forge
cycler                    0.10.0                     py_1    conda-forge
eigen                     3.3.7             he980bc4_1000    conda-forge
expat                     2.2.5             habb2df7_1003    conda-forge
freecad                   0.19.pre        py37h206906e_34    freecad/label/dev
freetype                  2.10.0               h563cfd7_1    conda-forge
future                    0.17.1                py37_1000    conda-forge
gitdb2                    2.0.5                      py_0    conda-forge
gitpython                 3.0.2                      py_0    conda-forge
hdf4                      4.2.13            hf8e6fe8_1002    conda-forge
hdf5                      1.10.5          nompi_ha405e13_1103    conda-forge
icu                       64.2                 he025d50_1    conda-forge
intel-openmp              2019.4                      245
jpeg                      9c                hfa6e2cd_1001    conda-forge
jsoncpp                   1.8.4             h1ad3211_1001    conda-forge
kiwisolver                1.1.0            py37he980bc4_0    conda-forge
krb5                      1.16.3            hdd46e55_1001    conda-forge
libblas                   3.8.0                    12_mkl    conda-forge
libcblas                  3.8.0                    12_mkl    conda-forge
libclang                  8.0.1                he980bc4_0    conda-forge
libcurl                   7.65.3               h4496350_0    conda-forge
libiconv                  1.15              hfa6e2cd_1005    conda-forge
liblapack                 3.8.0                    12_mkl    conda-forge
libllvm8                  8.0.1                h21ff451_0    conda-forge
libnetcdf                 4.6.2             h376842a_1003    conda-forge
libpng                    1.6.37               h7602738_0    conda-forge
libssh2                   1.8.2                h642c060_2    conda-forge
libtiff                   4.0.10            h6512ee2_1003    conda-forge
libxml2                   2.9.9                h9ce36c8_5    conda-forge
libxslt                   1.1.33               heafd4d3_0    conda-forge
llvm-tools                8.0.1                h1ad3211_0    conda-forge
llvmdev                   8.0.1                h1ad3211_0    conda-forge
lz4-c                     1.8.3             he025d50_1001    conda-forge
matplotlib                3.1.1                    py37_1    conda-forge
matplotlib-base           3.1.1            py37h2852a4a_1    conda-forge
mkl                       2019.4                      245
netgen                    6.2.1808        py37h58e452a_1006    conda-forge
numpy                     1.17.1           py37hc71023c_0    conda-forge
occt                      7.3.0             hd7db75f_1004    conda-forge
openssl                   1.1.1c               hfa6e2cd_0    conda-forge
pip                       19.2.3                   py37_0    conda-forge
pivy                      0.6.5a2          py37h729ed8e_2    conda-forge
pthreads-win32            2.9.1                hfa6e2cd_3    conda-forge
pybind11                  2.3.0            py37he980bc4_2    conda-forge
pyparsing                 2.4.2                      py_0    conda-forge
pyqt                      5.9.2            py37h6538335_2    conda-forge
pyside2                   5.9.0a1          py37h0555040_0    conda-forge
python                    3.7.3                h510b542_1    conda-forge
python-dateutil           2.8.0                      py_0    conda-forge
pyyaml                    5.1.2            py37hfa6e2cd_0    conda-forge
qt                        5.9.7                h506e8af_3    conda-forge
setuptools                41.2.0                   py37_0    conda-forge
sip                       4.19.8          py37h6538335_1000    conda-forge
six                       1.12.0                py37_1000    conda-forge
smesh                     8.3.0.2              h90a28c1_6    conda-forge
smmap2                    2.0.5                      py_0    conda-forge
soqt                      1.6.0a            h729ed8e_1002    conda-forge
sqlite                    3.29.0               hfa6e2cd_1    conda-forge
swig                      4.0.1                         0    conda-forge
tbb                       2019.8               he980bc4_0    conda-forge
tbb-devel                 2019.8               he980bc4_0    conda-forge
tk                        8.6.9             hfa6e2cd_1002    conda-forge
tornado                   6.0.3            py37hfa6e2cd_0    conda-forge
vc                        14.1                 h0510ff6_4
vs2015_runtime            14.15.26706          h3a45250_4
vtk                       8.2.0           py37hf8bee71_203    conda-forge
wheel                     0.33.6                   py37_0    conda-forge
wincertstore              0.2                   py37_1002    conda-forge
xerces-c                  3.2.2             h6538335_1004    conda-forge
xz                        5.2.4             h2fa13f4_1001    conda-forge
yaml                      0.1.7             hfa6e2cd_1001    conda-forge
zlib                      1.2.11            h2fa13f4_1005    conda-forge
zstd                      1.4.0                hd8a0e53_0    conda-forge
but unfortunately troubles while upgrading qt
(freecad-dev) C:\Users\aio>conda install qt=5.12.1
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: |
Found conflicts! Looking for incompatible packages.
This can take several minutes.  Press CTRL-C to abort.
failed
CondaError: KeyboardInterrupt
Terminate batch job (Y/N)? y
:shock:
