conda build win 10 stopped working since Link merge
sgrogan
Re: conda build win 10 stopped working since Link merge
Postby sgrogan » Tue Oct 15, 2019 9:57 pm
Syres wrote:
Sun Oct 13, 2019 8:49 am
preferences such as Stylesheet are correct but others such as the Start Wb aren't open as expected.
I changed my settings to match yours. I get the same behavior in the libpack and conda version.
What exactly isn't working?
And TIA for the continued support.
Syres
Postby Syres » Wed Oct 16, 2019 8:17 am
I thought it best to sleep on it and with a fresh methodical review, I know what's wrong but a little head scratching as to why.
Basically all the time I've been doing these tests I've had the -l log switch at the end of the shortcut. What I wasn't aware of is it can affect the GUI, so with the log switch enabled and running from E:\Data\My Downloads\.. the GUI loads as below with no workbench combo box and numerous toolbars suddenly disabled/enabled:
I then have to restore my user.cfg and system.cfg files but with the log switch removed from the shortcut all is back to normal:
So to clarify, this is the qt.conf that I'm using and no other changes made to files or folders:
[Paths]
TargetSpec = win32-msvc
HostSpec = win32-msvc
Prefix=..
So I'm happy that with the tweaked qt.conf that the build is portable, thanks for the efforts.
Syres
Postby Syres » Thu Oct 17, 2019 8:20 am
@sgrogan, just incase you're not aware, I had to copy src\bin\Lib\site-packages\collada over to the latest Conda build from one of my older builds in order to import a DAE file.
easyw-fc
Postby easyw-fc » Tue Nov 12, 2019 10:37 am
Hi @sgrogan
I have an issue on a clean profile using the latest conda build with Start as default WB...
Here my errors:
Msg: FreeCAD 0.19, Libs: 0.19R18686 (Git)
Log: Time = Tue Nov 12 09:59:59 2019
Log: AppDataSkipVendor = true
Log: AppHomePath = C:/FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015/
Log: AppIcon = freecad
Log: AppTempPath = C:\Users\userC\AppData\Local\Temp\
Log: BinPath = C:/FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git master
Log: BuildRevision = 18686 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2019/11/06 15:46:08
Log: BuildRevisionHash = f0cdad7f708c0185961cd7185e366df22e041d02
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: Console = 0
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Qt WebEngine ICU data not found at C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library/resources. Trying parent directory...
Log: Qt WebEngine ICU data not found at C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library. Trying application directory...
Log: Qt WebEngine ICU data not found at C:/FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015/bin. Trying fallback directory... The application MAY NOT work.
Log: Installed Qt WebEngine locales directory not found at location C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library/translations\qtwebengine_locales. Trying application directory...
Log: Id: 7524: SymInit: Symbol-SearchPath: '.;C:\FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015\bin', symOptions: 534, UserName: 'userC'
Log: Id: 7524: OS-Version: 6.2.9200 () 0x100-0x1
Log: Id: 7524: C:\FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015\lib\Start.pyd:Start.pyd (00007FFDA52D0000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\FreeCAD_0.19.18686_x64_Conda_Py3QT5-WinVS2015\lib\Start.pyd'
Log: Id: 7524: C:\WINDOWS\SYSTEM32\edputil.dll:edputil.dll (00007FFDA0F00000), size: 278528 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\SYSTEM32\edputil.dll', fileVersion: 6.2.15063.447
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6FD8F239)
Log: Id: 7524: 00007FFD6FD8F239 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlSchemeHandler::qt_static_metacall
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6FD14D8E)
Log: Id: 7524: 00007FFD6FD14D8E (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlSchemeHandler::qt_static_metacall
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD702B458D)
Log: Id: 7524: 00007FFD702B458D (Qt5WebEngineCore_conda): (filename not available): GetHandleVerifier
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6FCE0297)
Log: Id: 7524: 00007FFD6FCE0297 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlRequestInfo::navigationType
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E8D069C)
Log: Id: 7524: 00007FFD6E8D069C (Qt5WebEngineCore_conda): (filename not available): QtWebEngineCore::WebContentsAdapter::webContents
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E8D1350)
Log: Id: 7524: 00007FFD6E8D1350 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlScheme::operator!=
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E8C236C)
Log: Id: 7524: 00007FFD6E8C236C (Qt5WebEngineCore_conda): (filename not available): QtWebEngineCore::WebContentsAdapter::WebContentsAdapter
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD94F43835)
Log: Id: 7524: 00007FFD94F43835 (Qt5WebEngineWidgets_conda): (filename not available): QWebEngineHistoryItem::url
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD94F43B7B)
Log: Id: 7524: 00007FFD94F43B7B (Qt5WebEngineWidgets_conda): (filename not available): QWebEnginePage::QWebEnginePage
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD94F43ACD)
Log: Id: 7524: 00007FFD94F43ACD (Qt5WebEngineWidgets_conda): (filename not available): QWebEnginePage::QWebEnginePage
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD94F53DEF)
Log: Id: 7524: 00007FFD94F53DEF (Qt5WebEngineWidgets_conda): (filename not available): QWebEngineView::settings
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC35A0A)
Log: Id: 7524: 00007FFD8FC35A0A (WebGui): (filename not available): WebGui::WebView::WebView
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC35340)
Log: Id: 7524: 00007FFD8FC35340 (WebGui): (filename not available): WebGui::BrowserView::BrowserView
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC3343B)
Log: Id: 7524: 00007FFD8FC3343B (WebGui): (filename not available): WebGui::BrowserView::getName
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC32E68)
Log: Id: 7524: 00007FFD8FC32E68 (WebGui): (filename not available): WebGui::BrowserView::getName
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDB2B25834)
Log: Id: 7524: 00007FFDB2B25834 (FreeCADBase): (filename not available): method_varargs_call_handler
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639DFF4)
Log: Id: 7524: 00007FFD9639DFF4 (python37): (filename not available): PyMethodDef_RawFastCallKeywords
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639DA83)
Log: Id: 7524: 00007FFD9639DA83 (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD963A3D09)
Log: Id: 7524: 00007FFD963A3D09 (python37): (filename not available): PyEval_EvalFrameDefault
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639D554)
Log: Id: 7524: 00007FFD9639D554 (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9637F233)
Log: Id: 7524: 00007FFD9637F233 (python37): (filename not available): PyArg_Parse_SizeT
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639F457)
Log: Id: 7524: 00007FFD9639F457 (python37): (filename not available): PyObject_FastCallKeywords
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639F1E6)
Log: Id: 7524: 00007FFD9639F1E6 (python37): (filename not available): PyObject_FastCallKeywords
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639DB6B)
Log: Id: 7524: 00007FFD9639DB6B (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD963A3252)
Log: Id: 7524: 00007FFD963A3252 (python37): (filename not available): PyEval_EvalFrameDefault
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9639E2DC)
Log: Id: 7524: 00007FFD9639E2DC (python37): (filename not available): PyEval_EvalCodeWithName
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9636B8C3)
Log: Id: 7524: 00007FFD9636B8C3 (python37): (filename not available): PyEval_EvalCodeEx
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9636B821)
Log: Id: 7524: 00007FFD9636B821 (python37): (filename not available): PyEval_EvalCode
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9636B7CB)
Log: Id: 7524: 00007FFD9636B7CB (python37): (filename not available): PyArena_Free
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9636B6F5)
Log: Id: 7524: 00007FFD9636B6F5 (python37): (filename not available): PyRun_StringFlags
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDB2B5E42B)
Log: Id: 7524: 00007FFDB2B5E42B (FreeCADBase): (filename not available): Base::InterpreterSingleton::runString
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC98D54)
Log: Id: 7524: 00007FFD8FC98D54 (StartGui): (filename not available): StartGui::Workbench::loadStartPage
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8FC987F2)
Log: Id: 7524: 00007FFD8FC987F2 (StartGui): (filename not available): StartGui::Workbench::activated
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD9675A671)
Log: Id: 7524: 00007FFD9675A671 (FreeCADGui): (filename not available): Gui::Application::activateWorkbench
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD967779F6)
Log: Id: 7524: 00007FFD967779F6 (FreeCADGui): (filename not available): Gui::Application::runApplication
Log: Id: 7524: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7BED6457C)
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7BED6457C)
Log: Id: 7524: 00007FF7BED6457C (FreeCAD): (filename not available): (function-name not available)
Log: Id: 7524: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7BED65974)
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7BED65974)
Log: Id: 7524: 00007FF7BED65974 (FreeCAD): (filename not available): (function-name not available)
Log: Id: 7524: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7BED64DAF)
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7BED64DAF)
Log: Id: 7524: 00007FF7BED64DAF (FreeCAD): (filename not available): (function-name not available)
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDBD292774)
Log: Id: 7524: 00007FFDBD292774 (KERNEL32): (filename not available): BaseThreadInitThunk
Log: Id: 7524: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDBDF70D51)
Log: Id: 7524: 00007FFDBDF70D51 (ntdll): (filename not available): RtlUserThreadStart
Log: *** Unhandled Exception!
Log:    ExpCode: 0x80000003
Log:    ExpFlags: 0
Log:    ExpAddress: 0x6FD8F239
Conda just starts correctly if I use i.e. Part as default WB
sgrogan
Postby sgrogan » Tue Nov 12, 2019 9:56 pm
Should be fixed now. Sorry for the inconvenience.
easyw-fc
Postby easyw-fc » Wed Nov 13, 2019 8:39 am
Hi @Chris,
I still have the issue:
Msg: FreeCAD 0.19, Libs: 0.19R18719 (Git)
Log: Time = Wed Nov 13 09:32:33 2019
Log: AppHomePath = C:/FreeCAD/
Log: Application = FieryCAD 19.0
Log: BinPath = C:/FreeCAD/bin\
Log: BuildRevision = 18719 (Git)
Log: BuildRevisionDate = 2019/11/11 21:04:10
Log: BuildRevisionHash = c021ff70debb106b27d03ed1707f4b05fcf385a6
Log: Console = 0
Log: Loading GUI of Part module... done
Log: Qt WebEngine ICU data not found at C:/FreeCAD/bin. Trying fallback directory... The application MAY NOT work.
Log: Id: 9676: SymInit: Symbol-SearchPath: '.;C:\FreeCAD\bin', symOptions: 534, UserName: 'userC'
Log: Id: 9676: OS-Version: 6.2.9200 () 0x100-0x1
Log: Id: 9676: C:\FreeCAD\bin\FreeCAD.exe:FreeCAD.exe (00007FF7981D0000), size: 159744 (result: 0), SymType: '-nosymbols-', PDB: 'C:\FreeCAD\bin\FreeCAD.exe'
Log: Id: 9676: C:\WINDOWS\SYSTEM32\ntdll.dll:ntdll.dll (00007FFDBDF00000), size: 1945600 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\SYSTEM32\ntdll.dll', fileVersion: 6.2.15063.608
Log: Id: 9676: C:\WINDOWS\System32\KERNEL32.DLL:KERNEL32.DLL (00007FFDBD280000), size: 712704 (result: 0), SymType: '-exported-', PDB:
Log: Id: 9676: C:\WINDOWS\SYSTEM32\edputil.dll:edputil.dll (00007FFDA0F00000), size: 278528 (result: 0), SymType: '-exported-', PDB: 'C:\WINDOWS\SYSTEM32\edputil.dll', fileVersion: 6.2.15063.447
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E22F239)
Log: Id: 9676: 00007FFD6E22F239 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlSchemeHandler::qt_static_metacall
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E1B4D8E)
Log: Id: 9676: 00007FFD6E1B4D8E (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlSchemeHandler::qt_static_metacall
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E75458D)
Log: Id: 9676: 00007FFD6E75458D (Qt5WebEngineCore_conda): (filename not available): GetHandleVerifier
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6E180297)
Log: Id: 9676: 00007FFD6E180297 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlRequestInfo::navigationType
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6CD7069C)
Log: Id: 9676: 00007FFD6CD7069C (Qt5WebEngineCore_conda): (filename not available): QtWebEngineCore::WebContentsAdapter::webContents
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6CD71350)
Log: Id: 9676: 00007FFD6CD71350 (Qt5WebEngineCore_conda): (filename not available): QWebEngineUrlScheme::operator!=
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD6CD6236C)
Log: Id: 9676: 00007FFD6CD6236C (Qt5WebEngineCore_conda): (filename not available): QtWebEngineCore::WebContentsAdapter::WebContentsAdapter
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71C23835)
Log: Id: 9676: 00007FFD71C23835 (Qt5WebEngineWidgets_conda): (filename not available): QWebEngineHistoryItem::url
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71C23B7B)
Log: Id: 9676: 00007FFD71C23B7B (Qt5WebEngineWidgets_conda): (filename not available): QWebEnginePage::QWebEnginePage
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71C23ACD)
Log: Id: 9676: 00007FFD71C23ACD (Qt5WebEngineWidgets_conda): (filename not available): QWebEnginePage::QWebEnginePage
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71C33DEF)
Log: Id: 9676: 00007FFD71C33DEF (Qt5WebEngineWidgets_conda): (filename not available): QWebEngineView::settings
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71885A0A)
Log: Id: 9676: 00007FFD71885A0A (WebGui): (filename not available): WebGui::WebView::WebView
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71885340)
Log: Id: 9676: 00007FFD71885340 (WebGui): (filename not available): WebGui::BrowserView::BrowserView
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD7188343B)
Log: Id: 9676: 00007FFD7188343B (WebGui): (filename not available): WebGui::BrowserView::getName
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD71882E68)
Log: Id: 9676: 00007FFD71882E68 (WebGui): (filename not available): WebGui::BrowserView::getName
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD97675834)
Log: Id: 9676: 00007FFD97675834 (FreeCADBase): (filename not available): method_varargs_call_handler
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6DFF4)
Log: Id: 9676: 00007FFD92E6DFF4 (python37): (filename not available): PyMethodDef_RawFastCallKeywords
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6DA83)
Log: Id: 9676: 00007FFD92E6DA83 (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E73D09)
Log: Id: 9676: 00007FFD92E73D09 (python37): (filename not available): PyEval_EvalFrameDefault
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6D554)
Log: Id: 9676: 00007FFD92E6D554 (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E4F233)
Log: Id: 9676: 00007FFD92E4F233 (python37): (filename not available): PyArg_Parse_SizeT
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6F457)
Log: Id: 9676: 00007FFD92E6F457 (python37): (filename not available): PyObject_FastCallKeywords
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6F1E6)
Log: Id: 9676: 00007FFD92E6F1E6 (python37): (filename not available): PyObject_FastCallKeywords
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6DB6B)
Log: Id: 9676: 00007FFD92E6DB6B (python37): (filename not available): PyFunction_FastCallDict
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E73252)
Log: Id: 9676: 00007FFD92E73252 (python37): (filename not available): PyEval_EvalFrameDefault
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E6E2DC)
Log: Id: 9676: 00007FFD92E6E2DC (python37): (filename not available): PyEval_EvalCodeWithName
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E3B8C3)
Log: Id: 9676: 00007FFD92E3B8C3 (python37): (filename not available): PyEval_EvalCodeEx
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E3B821)
Log: Id: 9676: 00007FFD92E3B821 (python37): (filename not available): PyEval_EvalCode
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E3B7CB)
Log: Id: 9676: 00007FFD92E3B7CB (python37): (filename not available): PyArena_Free
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD92E3B6F5)
Log: Id: 9676: 00007FFD92E3B6F5 (python37): (filename not available): PyRun_StringFlags
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD976AE42B)
Log: Id: 9676: 00007FFD976AE42B (FreeCADBase): (filename not available): Base::InterpreterSingleton::runString
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD718E8D54)
Log: Id: 9676: 00007FFD718E8D54 (StartGui): (filename not available): StartGui::Workbench::loadStartPage
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD718E87F2)
Log: Id: 9676: 00007FFD718E87F2 (StartGui): (filename not available): StartGui::Workbench::activated
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8E3BA671)
Log: Id: 9676: 00007FFD8E3BA671 (FreeCADGui): (filename not available): Gui::Application::activateWorkbench
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFD8E3D7A04)
Log: Id: 9676: 00007FFD8E3D7A04 (FreeCADGui): (filename not available): Gui::Application::runApplication
Log: Id: 9676: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7981D457C)
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7981D457C)
Log: Id: 9676: 00007FF7981D457C (FreeCAD): (filename not available): (function-name not available)
Log: Id: 9676: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7981D5974)
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7981D5974)
Log: Id: 9676: 00007FF7981D5974 (FreeCAD): (filename not available): (function-name not available)
Log: Id: 9676: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF7981D4DAF)
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FF7981D4DAF)
Log: Id: 9676: 00007FF7981D4DAF (FreeCAD): (filename not available): (function-name not available)
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDBD292774)
Log: Id: 9676: 00007FFDBD292774 (KERNEL32): (filename not available): BaseThreadInitThunk
Log: Id: 9676: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFDBDF70D51)
Log: Id: 9676: 00007FFDBDF70D51 (ntdll): (filename not available): RtlUserThreadStart
Log:    ExpFlags: 0
Log:    ExpAddress: 0x6E22F239
and the debug log:
[1013/101734.619:ERROR:icu_util.cc(177)] Invalid file descriptor to ICU data received.
[1013/101734.619:FATAL:icu_util.cc(314)] Check failed: result.
Backtrace:
	QWebEngineUrlSchemeHandler::qt_static_metacall [0x000007FEBFA7E7C5+522805]
	QWebEngineUrlSchemeHandler::qt_static_metacall [0x000007FEBFA8F253+591043]
	QWebEngineUrlSchemeHandler::qt_static_metacall [0x000007FEBFA14A5B+89291]
	GetHandleVerifier [0x000007FEBFFB458D+5331485]
	QWebEngineUrlRequestInfo::navigationType [0x000007FEBF9E0297+13541271]
	QtWebEngineCore::WebContentsAdapter::webContents [0x000007FEBE5D069C+25276]
	QWebEngineUrlScheme::operator!= [0x000007FEBE5D1350+2384]
	QtWebEngineCore::WebContentsAdapter::WebContentsAdapter [0x000007FEBE5C236C+108]
	QWebEngineHistoryItem::url [0x000007FED56E3835+421]
	QWebEnginePage::QWebEnginePage [0x000007FED56E3B7B+139]
	QWebEnginePage::QWebEnginePage [0x000007FED56E3ACD+45]
	QWebEngineView::page [0x000007FED56F2B9D+45]
	WebGui::BrowserView::BrowserView [0x000007FED5724BB4+292]
	WebGui::BrowserView::getName [0x000007FED57230DB+2539]
	WebGui::BrowserView::getName [0x000007FED5722B28+1080]
	method_varargs_call_handler [0x000007FEE93F1FE4+324]
	PyMethodDef_RawFastCallKeywords [0x000007FED74BDFF4+932]
	PyFunction_FastCallDict [0x000007FED74BDA83+1555]
	PyEval_EvalFrameDefault [0x000007FED74C3D09+4601]
	PyFunction_FastCallDict [0x000007FED74BD554+228]
	PyArg_Parse_SizeT [0x000007FED749F233+647]
	PyObject_FastCallKeywords [0x000007FED74BF457+999]
	PyObject_FastCallKeywords [0x000007FED74BF1E6+374]
	PyFunction_FastCallDict [0x000007FED74BDB6B+1787]
	PyEval_EvalFrameDefault [0x000007FED74C3252+1858]
	PyEval_EvalCodeWithName [0x000007FED74BE2DC+428]
	PyEval_EvalCodeEx [0x000007FED748B8C3+155]
	PyEval_EvalCode [0x000007FED748B821+45]
	PyArena_Free [0x000007FED748B7CB+167]
	PyRun_StringFlags [0x000007FED748B6F5+137]
	Base::InterpreterSingleton::runString [0x000007FEE94217FB+187]
	StartGui::Workbench::loadStartPage [0x000007FED5788924+980]
	StartGui::Workbench::activated [0x000007FED57883C2+18]
	Gui::Application::activateWorkbench [0x000007FED80B0DD0+3232]
	Gui::Application::runApplication [0x000007FED80C67DE+6462]
	(No symbol) [0x000000013F4D457C]
	(No symbol) [0x000000013F4D5984]
	(No symbol) [0x000000013F4D4DBF]
	BaseThreadInitThunk [0x0000000076C8556D+13]
	RtlUserThreadStart [0x0000000076DE385D+29]
