Hi, whenever I create a new file on freecad it instantly crashes.
The os is Debian Buster and FreeCAD version 0.18.
When running "freecad -l" in the shell the following is the result:
FreeCAD 0.18, Libs: 0.18R
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly.
#0 /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0xb3413120
freecad crahes every time when creating a new file on debian buster
Re: freecad crahes every time when creating a new file on debian buster
This looks like OpenGL not properly set up. Do other OpenGL-based apps such as Blender run?
- kkremitzki
I think this is the Raspberry Pi 4 bug that has been discussed elsewhere.
