cmake -DCMAKE_BUILD_TYPE="Release" -DBUILD_QT5=1 -DCMAKE_INSTALL_PREFIX="./.." ../FreeCAD-git/ -DPYTHON_EXECUTABLE="/usr/local/bin/python3.7" -DPYTHON_INCLUDE_DIR="/usr/local/Cellar/python/3.7.4_1/Frameworks/Python.framework/Versions/3.7/include/python3.7m" -DPYTHON_LIBRARY="/usr/local/Cellar/python/3.7.4_1/Frameworks/Python.framework/Versions/3.7/lib/libpython3.7.dylib" -DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt/5.13.0/lib/cmake;/usr/local/Cellar/qtwebkit/5.212-72cfbd_3/lib/cmake"
-- The C compiler identification is AppleClang 10.0.0.10001044
-- The CXX compiler identification is AppleClang 10.0.0.10001044
-- Check for working C compiler: /usr/local/opt/ccache/libexec/cc
-- Check for working C compiler: /usr/local/opt/ccache/libexec/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/local/opt/ccache/libexec/c++
-- Check for working CXX compiler: /usr/local/opt/ccache/libexec/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Compiler: AppleClang, version: 10.0.0.10001044
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- Force BOOST_PP_VARIADICS=1 for clang
-- prefix: /Users/japie/FreeCAD
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.15.3
-- Detected Homebrew install at /usr/local
-- Found PythonInterp: /usr/local/bin/python3.7 (found version "3.7.4")
-- Found PythonLibs: /usr/local/Cellar/python/3.7.4_1/Frameworks/Python.framework/Versions/3.7/lib/libpython3.7.dylib (found suitable exact version "3.7.4")
CMake Warning at /usr/local/lib/cmake/boost_filesystem-1.71.0/libboost_filesystem-variant-shared.cmake:59 (message):
Target Boost::filesystem already has an imported location
'/usr/local/lib/libboost_filesystem-mt.dylib', which will be overwritten
with '/usr/local/lib/libboost_filesystem.dylib'
Call Stack (most recent call first):
/usr/local/lib/cmake/boost_filesystem-1.71.0/boost_filesystem-config.cmake:43 (include)
/usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake:117 (find_package)
/usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake:182 (boost_find_component)
/usr/local/Cellar/cmake/3.15.3/share/cmake/Modules/FindBoost.cmake:443 (find_package)
CMakeLists.txt:625 (find_package)
CMake Warning at /usr/local/lib/cmake/boost_program_options-1.71.0/libboost_program_options-variant-shared.cmake:59 (message):
Target Boost::program_options already has an imported location
'/usr/local/lib/libboost_program_options-mt.dylib', which will be
overwritten with '/usr/local/lib/libboost_program_options.dylib'
/usr/local/lib/cmake/boost_program_options-1.71.0/boost_program_options-config.cmake:43 (include)
CMake Warning at /usr/local/lib/cmake/boost_regex-1.71.0/libboost_regex-variant-shared.cmake:59 (message):
Target Boost::regex already has an imported location
'/usr/local/lib/libboost_regex-mt.dylib', which will be overwritten with
'/usr/local/lib/libboost_regex.dylib'
/usr/local/lib/cmake/boost_regex-1.71.0/boost_regex-config.cmake:43 (include)
CMake Warning at /usr/local/lib/cmake/boost_system-1.71.0/libboost_system-variant-shared.cmake:59 (message):
Target Boost::system already has an imported location
'/usr/local/lib/libboost_system-mt.dylib', which will be overwritten with
'/usr/local/lib/libboost_system.dylib'
/usr/local/lib/cmake/boost_system-1.71.0/boost_system-config.cmake:43 (include)
-- Found Boost: /usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version "1.71.0", minimum required is "1.48") found components: filesystem program_options regex system thread
-- Found Xerces-C: /usr/local/lib/libxerces-c.so
-- Found ZLIB: /usr/lib/libz.dylib (found version "1.2.11")
-- PyCXX found:
-- Headers: /Users/japie/FreeCAD/FreeCAD-git/src
-- Sources: /Users/japie/FreeCAD/FreeCAD-git/src/CXX
-- Version: 6.2.8
-- Found OCC: /usr/local/include/opencascade (found version "7.3.0")
-- -- Found OCE/OpenCASCADE version: 7.3.0
-- -- OCE/OpenCASCADE include directory: /usr/local/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/local/lib
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/local/include
-- Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
-- We guess that libmed was built using hdf5-serial version
-- Checking for one of the modules 'hdf5-serial'
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /usr/local/Cellar/hdf5/1.10.5_1/lib/libhdf5.dylib;/usr/local/opt/szip/lib/libsz.dylib;/usr/lib/libz.dylib;/usr/lib/libdl.dylib;/usr/lib/libm.dylib (found version "1.10.5")
-- Checking for one of the modules 'ompi-cxx'
CMake Warning at CMakeLists.txt:778 (message):
mpi.h was not found. Check for error above.
-- Found SWIG: /usr/local/bin/swig (found version "4.0.1")
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.3.7", minimum required is "2.91.0")
-- Found Freetype: /usr/local/lib/libfreetype.dylib (found version "2.10.1")
-- Found OpenGL: /System/Library/Frameworks/OpenGL.framework
-- Found OpenGLU: /System/Library/Frameworks/OpenGL.framework
-- Coin3D libraries found
-- Could NOT find Spnav (missing: SPNAV_LIBRARY SPNAV_INCLUDE_DIR)
-- Shiboken2Config: Using default python: -python2.7
-- libshiboken built for Release
-- PYTHON_CONFIG_SUFFIX: .cpython-37m-darwin
matplotlib not found, Plot module won't be available.
-- Platform is 64-bit, set -D_OCC64
-- /Users/japie/FreeCAD/build/src/Base/BaseClassPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/BoundBoxPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/CoordinateSystemPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/PersistencePy.cpp
-- /Users/japie/FreeCAD/build/src/Base/VectorPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/MatrixPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/RotationPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/PlacementPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/AxisPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/UnitPy.cpp
-- /Users/japie/FreeCAD/build/src/Base/QuantityPy.cpp
-- /Users/japie/FreeCAD/build/src/App/DocumentPy.cpp
-- /Users/japie/FreeCAD/build/src/App/DocumentObjectPy.cpp
-- /Users/japie/FreeCAD/build/src/App/ExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/ExtensionContainerPy.cpp
-- /Users/japie/FreeCAD/build/src/App/DocumentObjectExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/GroupExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/LinkBaseExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/DocumentObjectGroupPy.cpp
-- /Users/japie/FreeCAD/build/src/App/GeoFeaturePy.cpp
-- /Users/japie/FreeCAD/build/src/App/GeoFeatureGroupExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/OriginGroupExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/App/PartPy.cpp
-- /Users/japie/FreeCAD/build/src/App/ComplexGeoDataPy.cpp
-- /Users/japie/FreeCAD/build/src/App/PropertyContainerPy.cpp
-- /Users/japie/FreeCAD/build/src/App/MaterialPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Points/App/PointsPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Mesh/App/FacetPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Mesh/App/MeshPointPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Mesh/App/MeshPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcOfConicPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BodyBasePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ConicPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/CirclePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/EllipsePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/HyperbolaPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ParabolaPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/OffsetCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryIntExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryStringExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryBoolExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryDoubleExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometryCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BoundedCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/LinePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/LineSegmentPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/PointPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BezierCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BSplineCurvePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/PlanePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ConePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/CylinderPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/SpherePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/ToroidPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BezierSurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/PlateSurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/PartFeaturePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/AttachExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Part2DObjectPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/AttachEnginePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/PartDesign/App/BodyPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/PartDesign/App/FeaturePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/SketchGeometryExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/ExternalGeometryExtensionPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Sketcher/App/SketchPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Robot/App/TrajectoryPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Robot/App/WaypointPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Robot/App/RobotObjectPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Import/App/StepShapePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Fem/App/FemMeshPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/CommandPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/PathPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/ToolPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/TooltablePy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/AreaPy.cpp
-- /Users/japie/FreeCAD/build/src/Mod/Path/App/FeatureAreaPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- Could NOT find Boost: missing: python37 (found /usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake (found version "1.71.0"))
-- Could NOT find Boost: missing: python3 (found /usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake (found version "1.71.0"))
CMake Error at /usr/local/lib/cmake/Boost-1.71.0/BoostConfig.cmake:117 (find_package):
Could not find a package configuration file provided by "boost_python"
(requested version 1.71.0) with any of the following names:
boost_pythonConfig.cmake
boost_python-config.cmake
Add the installation prefix of "boost_python" to CMAKE_PREFIX_PATH or set
"boost_python_DIR" to a directory containing one of the above files. If
"boost_python" provides a separate development package or SDK, be sure it
has been installed.
src/Mod/Path/libarea/CMakeLists.txt:26 (find_package)
-- Configuring incomplete, errors occurred!
See also "/Users/japie/FreeCAD/build/CMakeFiles/CMakeOutput.log".
