FC18/19 on VirtualBox Windows 10 Guest Possible?
wandererfan
Postby wandererfan » Sat Sep 21, 2019 12:10 pm
Has anybody succeeded in running FreeCAD v18/19 on a Windows 10 guest under VirtualBox on ubuntu18/mint19?
Guest additions and expansion pack are installed on the VM. The hardware is an HP laptop with Nvidia graphics.
The best I've managed so far is to display the Start page and a Drawing module page. Anything involving the 3d view, displays black screen, garbles the display or crashes FreeCAD.
I've tried the "black screen" solutions and all the available VB video drivers (VBSVGA, VMSVGA, etc). I frequently get the message "Access violation" before/during the black screen.
I've tried a couple of different versions from the 0.19_pre page, including the conda build. Also tried 18.3 from the releases page.
A potential clue is that I can't run blender either. Blender complains that it needs at least OpenGL 3.3, then refuses to start.
I'm out of ideas.
sgrogan
Re: FC18/19 on VirtualBox Windows 10 Guest Possible?
Postby sgrogan » Sat Sep 21, 2019 1:41 pm
I'm out of ideas.
Maybe this helps https://superuser.com/questions/779070/ ... virtualbox
Also, does the QT4 version work?
kkremitzki
Postby kkremitzki » Sat Sep 21, 2019 3:07 pm
I could have sworn I have done this with a Windows 7 VM, but just now I tested with a Windows 10 VM, using libvirt instead of VirtualBox, and it didn't work either, with the same black screen behavior you described.
sgrogan
Postby sgrogan » Sat Sep 21, 2019 3:27 pm
I wonder if I am missing packaging some QT5 plugin? We have seen this in other areas.
Anybody want to try , with all the plugins, I can make a package of all the plugins.
EDIT: I put a package here: https://github.com/sgrogan/FreeCAD/rele ... /PY3.7-win plugins.7z
copy all the sub-folders of the plugins directory to FreeCAD/bin
EDIT2: The package is for the Libpack 12.x.x builds
mlampert
Postby mlampert » Sat Sep 21, 2019 7:05 pm
I had a similar issue with Linux as a guest - IIRC I had to turn off all video accelerations.
I just checked for the System I have the "PAE/NX", "VT-x/AMD-V" and "Nested Paging" enabled, but not "Nested VT-x/AMD-V".
HTH,
Markus
wandererfan
Postby wandererfan » Sun Sep 22, 2019 12:16 am
Might have helped a bit. v0.18 stayed up long enough to make a new document, add a cube and sphere, then save. After that it just disappeared. I haven't be able to duplicate that little bit of success.
I'll mess about a little more, but it looks like I'm out of luck.
Samshah
Postby Samshah » Sun Sep 22, 2019 10:45 am
FreeCad Windows same black screen problem.
On Ubuntu 18.04...the the freecad 18.03,,drawing portion is alright but .....FEM is compile with Calculix...but not working...
So have a stable release atleast.
Too many confusions.
sgrogan
Postby sgrogan » Mon Sep 23, 2019 10:37 pm
Interesting. Can you get past the black screen. I don't understand the QT5 plugin stuff. They are loaded at runtime, I think, so I don't know how to test.
wandererfan
Postby wandererfan » Mon Sep 23, 2019 10:42 pm
Only got past the black screen the one time. I can see start page, Preferences or the QGraphicsView for sample Drawings, but as soon as I try the 3D view it either dies completely or gives the black screen.
Graphics on VirtualBox seems to be a big problem judging by the number of Google hits.
sgrogan
Postby sgrogan » Mon Sep 23, 2019 10:53 pm
Can you run the self-tests from FreeCADCmd.exe?
