Travis Build Failures in Robot WB
wandererfan
Postby wandererfan » Tue Sep 24, 2019 11:40 am
I see a couple of Travis failures in gcc/py2 builds - PR2552 and
PR2551 - that are related to Robot WB.
Should we be concerned?
CMakeFiles/Robot.dir/Robot6Axis.cpp.o: file not recognized: File truncated
src/Mod/Robot/App/CMakeFiles/Robot.dir/build.make:1262: recipe for target 'Mod/Robot/Robot.so' failed
make[2]: *** [Mod/Robot/Robot.so] Error 1
CMakeFiles/Makefile2:2978: recipe for target 'src/Mod/Robot/App/CMakeFiles/Robot.dir/all' failed
make[1]: *** [src/Mod/Robot/App/CMakeFiles/Robot.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
vocx
Re: Travis Build Failures in Robot WB
Postby vocx » Wed Sep 25, 2019 12:10 am
Robot hasn't been touched by people in years. Werner recently edited a few things to force strict ISO C++ compliance.
https://github.com/FreeCAD/FreeCAD/comm ... 63f54f375c
Before that, I remember pull request #2428, just to remove compiler warnings, nothing major.
But other than that, Robot compiles fine. It's only in Travis that it fails. Also, no error message with a specific line of code, just "File truncated". What does this mean?
File not recognized: File truncated GCC error
Kostyantyn Ivanov wrote: Just remove the object file.
This error most likely appeared after the previous build was interrupted and object file was not generated completely.
marcv81 wrote: Your CI system should not run incremental builds. Developers cannot afford to wait for a clean build after every edit; conversely a CI system cannot afford the lack of reliability inherent to incremental builds.
I don't think FreeCAD uses incremental builds, but maybe somebody should check? Who's responsible?
Rainer wrote: Another problem (with the same error) could be, that you are using the ccache for faster compilation. In this case, the corrupt *.o file is there as well. So for that reason you have to clean the cache with
ccache -C (note the upper case C!)
I think FreeCAD does use ccache in Travis, no?
Site Admin
Postby wmayer » Wed Sep 25, 2019 11:30 am
I also think it's a problem with ccache and that the object file is broken for some reason. Years ago I had a similar problem with ccache and I ended up in disabling ccache and removing its directory.
What we could try is to slightly modify the file Robot6Axis.cpp in the hope that the object file will be re-created.
sgrogan
Postby sgrogan » Wed Sep 25, 2019 1:05 pm
I have permissions to delete the cache if desired. Let me know.
Site Admin
Postby wmayer » Wed Sep 25, 2019 1:49 pm
git commit d40b4f66a improves some white spaces of Robot6Axis.cpp.
If the build then still fails please go ahead and clean-up the cache.
triplus
Postby triplus » Wed Sep 25, 2019 3:49 pm
Yes, this is a problem with ccache. Whenever "File truncated" issue is detected in the log file on Travis:
This should resolve it. A bit of background, on why such issue can occur from time to time:
https://forum.freecadweb.org/viewtopic.php?f=4&t=38657
Bionic (GCC) toolchain is slightly slower, compared to the Trusty one. 2 h 30 min time limit, currently set, therefore isn't enough anymore, to compile FreeCAD. A workaround is currently being used, that forcefully stops the build procedure at around 2 h 15 min. That gives Travis enough time to still upload created ccache. Restarting the build, or one of the next scheduled builds, will be able to use the existing ccache, and to complete faster. Now one of the possible issues, forcibly terminnating the build, can be the mentioned issue. On a local build such file can simply get deleted, on Travis, the easiest solution is to clear ccache.
P.S. Ideally somebody will ask Travis people if they can extend the time limit to 3 h. If granted, the workaround can get removed and we get to compile FreeCAD again without such potential issues. That is until FreeCAD grows again, and exceeds 3 h limit. ;)
