Ticket #4145 - build failure with assembly module enabled
kkremitzki
Re: build failure with assembly module enabled
Postby kkremitzki » Tue Dec 24, 2019 9:23 pm
waebbl wrote:
Tue Dec 24, 2019 8:54 pm
BTW, if none of the developers currently care about the assembly workbench, what's the meaning of having an option for it in the cmake file? This option should be commented out until the workbench is back in a working state. At least a pointer noting that it doesn't build would be meaningful.
+1 on that.
vocx
Re: Ticket #4145 - build failure with assembly module enabled
Postby vocx » Wed Dec 25, 2019 1:09 am
waebbl wrote:
Tue Dec 24, 2019 9:15 pm
BTW, I can disable the option, or add a comment to the cmakefile fragment and prepare a PR if it's desired.
Well, that's what I mean. It's up to you to solve the issue if you think this is a problem.
jserink
Postby jserink » Wed Dec 25, 2019 12:40 pm
This is a known issue.
just put -assembly in your use flags and it builds fine.
Or, if you really need it, you can fix the assembly module.
Cheers,
john
Postby Kunda1 » Sat Jan 11, 2020 1:01 pm
so does workaround 'solve' it ?
ref: issue #4145
waebbl
Postby waebbl » Wed Feb 05, 2020 9:20 pm
ref: issue #4145
Yes, this will work, of course. I disabled the use flag for now, so it's no longer possible to try and build the assembly workbench on Gentoo.
But it wasn't a known issue. I've been maintaining the build script (ebuild) for Gentoo for one and a half year by now, and it built even with assembly use flag enabled whenever I tested it. And I didn't get any issue on github on this during the time.
Just when I did a full test of use flags again with 0.18.4 I noticed it's no longer building, then looked for an issue at the bug tracker and found the bug you mentioned and this thread.
