[Solved] [patch] for: FreeCADGui compilation error because of DlgSettings3DView.ui
uwestoehr
Post by uwestoehr »
I get now:
2>------ Build started: Project: FreeCADGui, Configuration: Release x64 ------
2>Generating ui_DlgSettings3DView.h
2>uic: Error in line 142, column 3 : Unexpected element b
2>File 'D:/FreeCADGit/src/Gui/DlgSettings3DView.ui' is not valid
Here's a patch:
DlgSettings3DView.txt
patch
(1.64 KiB) Downloaded 27 times
diff --git "a/src/Gui/DlgSettings3DView.ui" "b/src/Gui/DlgSettings3DView.ui"
index 40b01a38b..b899b8790 100644
--- "a/src/Gui/DlgSettings3DView.ui"
+++ "b/src/Gui/DlgSettings3DView.ui"
@@ -139,7 +139,7 @@ VBOs offer substantial performance gains because the data resides
 in the graphics memory rather than the system memory and so it
 can be rendered directly by GPU.
-<b>Note</b>: Sometimes this feature may lead to a host of different issues ranging
+&lt;b&gt;Note:&lt;b/&gt; Sometimes this feature may lead to a host of different issues ranging
 from graphical anomalies to GPU crash bugs. Remember to report this setting
 is enabled when seeking support on the FreeCAD forums.</string>
         </property>
@@ -165,15 +165,15 @@ is enabled when seeking support on the FreeCAD forums.</string>
         </item>
         <item>
          <widget class="QComboBox" name="renderCache">
-           <property name="toolTip">
-            <string>'Render Caching' is another way to say 'Rendering Acceleration'.
+          <property name="toolTip">
+           <string>'Render Caching' is another way to say 'Rendering Acceleration'.
 There are 3 options available to achieve this:
 1) 'Auto' (default), let Coin3D decide where to cache.
 2) 'Distributed', manually turn on cache for all view provider root node.
 3) 'Centralized', manually turn off cache in all nodes of all view provider, and
 only cache at the scene graph root node. This offers the fastest rendering speed
 but slower response to any scene changes.</string>
-           </property>
+          </property>
           <property name="currentIndex">
            <number>0</number>
           </property>
vocx
Re: [patch] for: FreeCADGui compilation error because of DlgSettings3DView.ui
Post by vocx »
uwestoehr wrote: Sat Oct 05, 2019 4:28 pm I get now:
This will explicitly show the less than and greater than symbols as brackets, <b>Note</b>
However, I think the intention is to produce a bold text. I'm not sure if this is possible at all. In a tooltip, bold is not really important, so I just remove the tags.
vocx wrote: Sat Oct 05, 2019 6:02 pm
bernd wrote: Sat Oct 05, 2019 5:58 pm
[ 11%] Generating ui_DlgSettings3DView.h
Pull request #2584: Gui: fix DlgSettings3DView.ui, remove bold tags <b> because it causes an error in compilation
bernd
Post by bernd »
uwestoehr
Post by uwestoehr »
vocx wrote: Sat Oct 05, 2019 6:19 pm This will explicitly show the less than and greater than symbols as brackets, <b>Note</b>
Yes.
vocx wrote: Sat Oct 05, 2019 6:19 pm However, I think the intention is to produce a bold text. I'm not sure if this is possible at all. In a tooltip, bold is not really important, so I just remove the tags.
If bold is required the tooltip can be formatted in HTML. I agree with you that the bold text is not necessary and can be omitted.
Thanks for your fix.
Post by Kunda1 »
Sorry about that. That was my fault.
