Compiling on Windows - Won't Compile Wix
jfreak53
Postby jfreak53 » Fri Apr 26, 2013 6:33 pm
I have been trying to compile on Windows 7 for some days now without success. The compile works fine and the application starts up without problems and works just fine. But Wix won't make an installer no matter what I do. I do have Wix installed:
http://i.imgur.com/yiQ8iDb.png
But first off when I run the cMake config app I get no Wix installer option to check:
http://i.imgur.com/OXpmcHG.png
As you can see there is no FREECAD_BUILD_INSTALLER checkbox. I have Visual C++ Express 2008 installed for my compile and Wix 3.7.
When I run the Build it works, but when it tries to compile the INSTALL trunk I get all kinds of errors:
------ Build started: Project: Fem, Configuration: Release Win32 ------
Linking...
LINK : fatal error LNK1181: cannot open input file 'MEFISTO2.lib'
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\src\Mod\Fem\App\Fem.dir\Release\BuildLog.htm"
Fem - 1 error(s), 0 warning(s)
------ Build started: Project: MeshPart, Configuration: Release Win32 ------
Linking...
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\src\Mod\MeshPart\App\MeshPart.dir\Release\BuildLog.htm"
MeshPart - 1 error(s), 0 warning(s)
------ Build started: Project: MeshPartGui, Configuration: Release Win32 ------
Linking...
LINK : fatal error LNK1181: cannot open input file '..\App\Release\MeshPart.lib'
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\src\Mod\MeshPart\Gui\MeshPartGui.dir\Release\BuildLog.htm"
MeshPartGui - 1 error(s), 0 warning(s)
------ Build started: Project: FemGui, Configuration: Release Win32 ------
Linking...
LINK : fatal error LNK1181: cannot open input file '..\App\Release\Fem.lib'
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\src\Mod\Fem\Gui\FemGui.dir\Release\BuildLog.htm"
FemGui - 1 error(s), 0 warning(s)
------ Build started: Project: ALL_BUILD, Configuration: Release Win32 ------
Building Custom Rule C:/Users/Land/Desktop/freecad-0.13.1830/freecad-0.13.1830/CMakeLists.txt
CMake is re-running because C:\Users\Land\Desktop\FreeCAD-Bin\CMakeFiles\generate.stamp dependency file is missing.
-- prefix: C:/Program Files/FreeCAD_trunk
-- datadir: data
-- docdir: doc
-- includedir: include
CMake Error at CMakeLists.txt:153 (message):
  Could not find neither LibPack 6.x nor 7.x in specified
  location:C:/Users/Land/Desktop/freecad-0.13.1830/freecad-0.13.1830
-- Could NOT find SWIG (missing:  SWIG_EXECUTABLE SWIG_DIR)
SWIG was not found, build no SWIG binding for pivy
-- Platform is 32-bit
CMake Warning (dev) at src/3rdParty/Pivy/CMakeLists.txt:41 (target_link_libraries):
  Link library type specifier "debug" is followed by specifier "optimized"
  instead of a library name.  The first specifier will be ignored.
This warning is for project developers.  Use -Wno-dev to suppress it.
  Link library type specifier "optimized" is followed by specifier "debug"
CMake Error at src/3rdParty/Pivy/CMakeLists.txt:41 (target_link_libraries):
  The "optimized" argument must be followed by a library.
-- Configuring incomplete, errors occurred!
Project : error PRJ0019: A tool returned an error code from "Building Custom Rule C:/Users/Land/Desktop/freecad-0.13.1830/freecad-0.13.1830/CMakeLists.txt"
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\ALL_BUILD.dir\Release\BuildLog.htm"
ALL_BUILD - 1 error(s), 0 warning(s)
------ Build started: Project: INSTALL, Configuration: Release Win32 ------
Performing Post-Build Event...
-- Install configuration: "Release"
CMake Error at src/cmake_install.cmake:31 (FILE):
  file cannot create directory: C:/Program Files/FreeCAD_trunk/doc.  Maybe
  need administrative privileges.
  cmake_install.cmake:32 (INCLUDE)
Project : error PRJ0019: A tool returned an error code from "Performing Post-Build Event..."
Build log was saved at "file://c:\Users\Land\Desktop\FreeCAD-Bin\INSTALL.dir\Release\BuildLog.htm"
INSTALL - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 7 failed, 50 up-to-date, 0 skipped ==========
And Wix never creates the installer.
Site Admin
Re: Compiling on Windows - Won't Compile Wix
Postby wmayer » Sun Apr 28, 2013 2:48 pm
Check the error messages:
Linking...
MEFISTO2.lib is missing. Haven't you built the project for it? (See the Solution Explorer of VS)
Which LibPack yo you use? Go for 8.x.
You don't need to trigger the INSTALL target. Once the build is finished you have to run the "BuildInstaller.bat" script (src/WindowsInstaller). And you have to adjust the file to your needs, e.g. the WiX location.
jfreak53
Postby jfreak53 » Mon Apr 29, 2013 9:05 pm
As far as that goes I did a Build Project as the Wiki said to do, it built everything that I know of.
I am using Version 8.1 of LibPack
FreeCADLibs_8.1_x86_VC9
No where can I find that src/WindowsInstaller in my src directory:
http://i.imgur.com/co5pLAL.png
http://i.imgur.com/b91pvUh.png
Site Admin
Postby wmayer » Tue Apr 30, 2013 1:21 pm
You have downloaded a source tarball rather than doing a checkout with git. Our tarballs don't include the WindowsInstaller directory but you can download it manually, then.
pperisin
Postby pperisin » Sun May 05, 2013 12:21 pm
when I am building installer for win:
1 - I copy entire content of libpack into source directory
2 - I make in-source build (set it with cmake to have both directories to be source dir)
3 - compile
4 - (because of 2 bugs) modify stuff described here:
https://sourceforge.net/apps/mantisbt/f ... hp?id=1120
5 - run BuildInstaller.bat
Regards,
Petar
pperisin
Postby pperisin » Sun May 05, 2013 12:23 pm
P.S. - there is first 0.14 unstable added to downloads today. I'm currently adding 7z of it.
pperisin
Postby pperisin » Wed May 15, 2013 12:24 am
pperisin wrote:Hi,
3 - compile
Regards,
Petar
Number 4 wass fixed by werner, recently. so no need to edit anything any more
