I'm having the same problem again. In R0.16, I was able to solve it by using the 32 bit version, just like I did with the prior revisions. However it has gotten worse now with R0.17-Pre. Should I be submitting a tracker report to get this on the official list?
Here is some additional information about the problem with the DLL.
c:\Windows\System32>dir *TK*
Volume in drive C has no label.
Volume Serial Number is 3CE0-0E00
Directory of c:\Windows\System32
06/16/2009 10:01 AM 93,728 nvhotkey.dll
04/10/2009 11:11 PM 158,208 softkbd.dll
2 File(s) 251,936 bytes
0 Dir(s) 21,920,063,488 bytes free
In CMD I do depends.exe --> open --> c:\program files (x86)\freecad_0.17.12920_x86_dev_win\bin\FREECAD.EXE then I get this error message. I click OK and it goes away.
Dependency Walker
Errors were detected when processing "c:\program files (x86)\freecad_0.17.12920_x86_dev_win\bin\FREECAD.EXE". See the log window for details.
OK
At this point with Win32, I can not get F7 to show up. So Lets try Win64 version.
In CMD I do depends.exe --> open --> c:\program files (x86)\freecad_0.17.12920_x64_dev_win\bin\FREECAD.EXE then F7 then OK, and when FreeCAD opens I switch to the "Part Design" workbench. I then get this error message.
Workbench failure
DLL load failed: The specified procedure could not be found.
OK
In Depends, I see these files with yellow ? marks next to them.
IESHIMS.DLL
CGGL
LIBCGGL
LIBCGGL.DYLIB
LIBCGGL.SO
PART.PYD
PARTGUI.PYD
SKETCHER.PYD
WINTAB32.DLL
PC is Vista 64 bit with automatic updates installed and PC functions very well.
I tried to attach the Depends DWI file, but even as a 7zip file it complains that 2 megs it to large.
Is there information I can provide to help with this issue? Is there some way I can get this to function? Should I create a tracker item such that this is on the official list and doesn't fall through the forum cracks?
Thanks in advance. It's a great program, can't wait to start using the new stuff in 0.17.
