SOLVED: python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll not found
HarryvL
Re: python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll not found
Post by HarryvL »
Thanks Werner. Do you run some kind of automatic script at start up or type this manually every time you run FC?
Founder
Post by wmayer »
HarryvL wrote: Tue Oct 22, 2019 11:08 am Thanks Werner. Do you run some kind of automatic script at start up or type this manually every time you run FC?
I have created a .bat file for the debug and release versions.
For the debug version:
set PATH=C:\Projects\FreeCADLibs_12.1.3_x64_VC15\bin;%PATH%
start FreeCAD_d.exe --write-log %1 %2 %3
For the release version:
set PATH=C:\Projects\FreeCADLibs_12.1.3_x64_VC15\bin;C:\Tools\git\bin;%PATH%
start FreeCAD.exe --write-log %1 %2 %3
The files are inside FreeCAD's bin directory. Instead of double-clicking the .exe file you have to double-click the .bat file.
HarryvL
Post by HarryvL »
Thanks.
debrasteed
Post by debrasteed »
I never had all three of the error at same time but all three are related to each other. All the three python3.dll, Qt5Windgets.dll, Qt5Gui.dll and Qt5Core.dll not found are common error which occurs while installing or running any program on PC. I reccommend you go through a steps where you can fix by ease the qt5core.dll error.
HarryvL
Post by HarryvL »
wmayer wrote: Tue Oct 22, 2019 11:26 am
Hi Werner, I finally got around to trying this (setting the path to the ..."FreeCADLibs_12.1.3_x64_VC15\bin"... directory). Unfortunately I still get the same errors. I could not locate the ..."git\bin"... directory on my system. Could that be the reason?
Founder
Post by wmayer »
Is the path name I used in the .bat file the same as on your PC?
No.
HarryvL
Post by HarryvL »
wmayer wrote: Mon Jan 20, 2020 2:48 pm
No.
I replaced your path to the full path (from root c:\) to my FreeCADLibs_12.1.3_x64_VC15\bin directory.
HarryvL
Post by HarryvL »
What files is FC looking for when generating the error “no module named ...”? A .py or .dll or .... ?
HarryvL
Post by HarryvL »
This is what I have in the bat file:
set PATH=C:\Users\hvlan\Documents\FC_019\FreeCADLibs_12.1.2_x64_VC15\bin;%PATH%
HarryvL
Post by HarryvL »
After some Googling I tried to install PySide2 through
pip install PySide2
I now get a different set of error messages that may shed some light on what is going on?
During initialization the error "DLL load failed: The specified procedure could not be found." occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\AddonManager\InitGui.py
Please look into the log file for further information
During initialization the error "DLL load failed: The specified procedure could not be found." occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Arch\InitGui.py
During initialization the error "DLL load failed: The specified procedure could not be found." occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Draft\InitGui.py
During initialization the error "invalid syntax (<string>, line 41)" occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\OpenSCAD\InitGui.py
During initialization the error "DLL load failed: The specified procedure could not be found." occurred in C:\Users\hvlan\Documents\FC_019\build\Mod\Tux\InitGui.py
<class 'ImportError'>: DLL load failed: The specified procedure could not be found.
PS: I don't see a "log file" in the bin directory
