32Bit version for Windows? 0.19? 0.18.4?
Re: 32Bit version for Windows? 0.19? 0.18.4?
Laptops and desktops are standard hardware and it seems they update pretty well with new versions of OS. Tablets are much tougher to upgrade and many run 32 bit, I don't need 32 bit but I hope it can continue to be built.
Anyway tablets much run with an ARM processor which AFAIK isn't officially supported ATM.
I would very much like to see a 32 bit version of FreeCAD V.19. My old computer won't even run the 64 bit version of V.18
I sure hope there is a 32 bit version of .19 soon.
Thanks,
GWB
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 2.7.14
OCC version: 7.2.0
Thanks,
GWB
OS: Windows 7
OCC version: 7.2.0
Hello and welcome
Since you have a 64-bit OS running there why would it not run 64-bit apps? Please post in the Help subforum with a description of the problems you experience trying to run the 64-bit versions of FreeCAD. Check here Start_up_and_Configuration about how to produce a log file and attach it to your post.
It really isn't that the computer won't run the 64 bit version. It seems to run it fine. However my video driver won't do rotation and panning. For example if I go to rotate a Part Design workbench view it will jerk. I have the navigation setup for "gesture" and it works just fine in the 32 bit version but in the 64 bit version it is nearly unusable. I press the left mouse button to do a rotate and move it and the view on the screen won't move then it will suddenly jerk in the direction I moved the mouse. The rotation isn't smooth like it is in the 32 bit version.
Thanks,
Gary
OS: Windows 7
OCC version: 7.2.0
Thanks,
Gary
OS: Windows 7
OCC version: 7.2.0
I think the difference isn't 32bit vs 64bit, but rather the version of QT that the respective builds use.
The 32bit build uses QT4 and the 64bit uses QT5.
On the 64bit version you can try to navigate to the bin directory and find the file openglsw.dll and rename it to opengl.dll, then restart FreeCAD. See if the problem goes away.
"fight the good fight"
I will give this a try.
If this works should I try if for version .19 also?
Thanks
Thanks
This is for 0.19, sorry not to be clear.
Got it. I'll see if I can get time to try it in the next couple of days. Things are kind of hectic around my place right now. I'll let you know how it goes.
Thanks,
Gary
Thanks,
Gary
Sorry it has taken me so long to get back to this but life has gotten in the way. I did a lot of searching and I have not been able to find the file <openglsw.dll> I can find may *.dll files but not this one. Do you have any other suggestions?
Thanks,
Gary
Thanks,
Gary
