Travis failures pybind11?
sgrogan
Postby sgrogan » Wed Oct 30, 2019 12:42 am
We are getting failures like this (Clang py3) https://travis-ci.org/FreeCAD/FreeCAD/j ... 4925#L4474
It's the same for gcc/py3
gcc/py2 passes because we are not -DBUILD_FEM_NETGEN=ON for this build
https://github.com/FreeCAD/FreeCAD/blob ... is.yml#L46
For Ubuntu 18.04 there is no netgen-headers package. https://packages.ubuntu.com/search?keyw ... en-headers
For Win it probably passes because pybind11 is available in the Libpack, I would bet it not actually used.
Anybody compiling themselves with 18.04?
Re: Travis failures pybind11?
Postby Kunda1 » Wed Oct 30, 2019 1:21 am
thanks for tracking this
kkremitzki
Postby kkremitzki » Wed Oct 30, 2019 3:21 am
I have gotten pybind11 + netgen builds working and tried turning them on for the daily builds today but forgot a few things, gonna trigger a new build soon.
sgrogan
Postby sgrogan » Wed Oct 30, 2019 8:54 pm
Thanks!
I just noticed that Travis is using the PPA so the missing netgen stuff for 18.04 (bionic) is not the problem. Do you know why no netgen in 18.04?
Do you know where the pybind11 dependency comes from? I can see that python3-netgen might need pybind11, but FreeCAD doesn't need python3-netgen.
sgrogan
Postby sgrogan » Thu Oct 31, 2019 8:21 pm
OK, I see now
usr/include/netgen/core/archive.hpp has this
#ifdef NETGEN_PYTHON
#include <pybind11/pybind11.h>
#endif // NETGEN_PYTHON
Site Admin
Postby wmayer » Sat Nov 02, 2019 10:38 am
Apparently there must have been changes on the netgen packages by adding the define NETGEN_PYTHON.
Yesterday I set-up a new native Xubuntu system where I ran exactly into the same issue.
To fix the build failure I have rejected the NETGEN_PYTHON define inside the salome netgen source files: git commit d276cc8d7a4f
While building the code (with clang) I got some further warnings that I haven't seen before:
In file included from /usr/include/netgen/include/../general/../core/profiler.hpp:9:0,
                 from /usr/include/netgen/include/../general/../core/ngcore.hpp:7,
                 from /usr/include/netgen/include/../general/myadt.hpp:20,
                 from /usr/include/netgen/include/../meshing/../include/myadt.hpp:1,
                 from /usr/include/netgen/include/../meshing/meshing.hpp:6,
                 from /usr/include/netgen/include/meshing.hpp:1,
                 from /usr/include/netgen/include/../occ/occgeom.hpp:12,
                 from /usr/include/netgen/include/occgeom.hpp:1,
                 from /home/werner/Projects/FreeCAD/src/3rdParty/salomesmesh/src/NETGENPlugin/NETGENPlugin_Mesher.cpp:88:
/usr/include/netgen/include/../general/../core/paje_trace.hpp: In member function ‘void ngcore::PajeTrace::StartTimer(int)’:
/usr/include/netgen/include/../general/../core/paje_trace.hpp:121:77: warning: missing initializer for member ‘ngcore::PajeTrace::TimerEvent::thread_id’ [-Wmissing-field-initializers]
           timer_events.push_back(TimerEvent{timer_id, GetTimeCounter(), true});
/usr/include/netgen/include/../general/../core/paje_trace.hpp: In member function ‘void ngcore::PajeTrace::StopTimer(int)’:
/usr/include/netgen/include/../general/../core/paje_trace.hpp:129:78: warning: missing initializer for member ‘ngcore::PajeTrace::TimerEvent::thread_id’ [-Wmissing-field-initializers]
           timer_events.push_back(TimerEvent{timer_id, GetTimeCounter(), false});
/usr/include/netgen/include/../general/../core/paje_trace.hpp: In member function ‘int ngcore::PajeTrace::StartTask(int, int, int, int)’:
/usr/include/netgen/include/../general/../core/paje_trace.hpp:139:102: warning: missing initializer for member ‘ngcore::PajeTrace::Task::stop_time’ [-Wmissing-field-initializers]
           tasks[thread_id].push_back( Task{thread_id, id, id_type, additional_value, GetTimeCounter()} );
/usr/include/netgen/include/../general/../core/paje_trace.hpp: In member function ‘void ngcore::PajeTrace::StartJob(int, const std::type_info&)’:
/usr/include/netgen/include/../general/../core/paje_trace.hpp:161:62: warning: missing initializer for member ‘ngcore::PajeTrace::Job::stop_time’ [-Wmissing-field-initializers]
           jobs.push_back( Job{job_id, &type, GetTimeCounter()} );
Then there is still this nasty warning about DLL_HEADER. In most of the netgen headers it's defined as:
#ifdef WIN32
   #if NGINTERFACE_EXPORTS || NGLIB_EXPORTS || nglib_EXPORTS
      #define DLL_HEADER   __declspec(dllexport)
   #else
      #define DLL_HEADER   __declspec(dllimport)
   #endif
#else
   #if __GNUC__ >= 4
      #define DLL_HEADER __attribute__ ((visibility ("default")))
   #else
      #define DLL_HEADER
   #endif
#endif
but in nglib.h the definition slightly differs:
#ifdef WIN32
   #ifdef NGLIB_EXPORTS || nglib_EXPORTS
   #else
   #endif
#else
   #define DLL_HEADER
#endif
Can these warning be fixed so that -- at least locally -- I can enable -Wpedantic -Werror ?
qingfeng.xia
Postby qingfeng.xia » Sat Nov 09, 2019 12:05 pm
I have updated salomemesh from 7.7 to 8.3, tetgen 6.2 has change that break smesh code in freecad. like excpetion and pybind11 macro, I fixed it by 2 latest commits.
https://github.com/qingfengxia/SMESH
further discussion on smesh is in another thread. https://forum.freecadweb.org/viewtopic. ... 17#p346117
how about keep salomemesh as a git submodule of freecad, perhaps it is not freecad's way
Ubuntu 18.04 LTS 64bit, python3, always work with latest FreeCAD daily build
Currently I mainly work on OpenFOAM + Fenics for CFD, FSI
https://github.com/qingfengxia/FreeCAD_Mod_Dev_Guide
https://github.com/qingfengxia/Cfd
kkremitzki
Postby kkremitzki » Sat Nov 09, 2019 3:15 pm
Git submodules can be quite a pain, I'm not sure moving it to that instead of simply a directory inside the master tree would have much benefit. (Especially from a packaging perspective.)
