Ubuntu 16.04 - error libfreecadgui.so
Vince-Fr
Postby Vince-Fr » Sun Nov 10, 2019 6:08 pm
I am using Ubuntu 16.04 and I have installed freecad 0.18 with repository "ppa:freecad-maintainers/freecad-stable".
When I want to start I have the error:
"freecad: error while loading shared libraries: libFreeCADGui.so: cannot open shared object file: No such file or directory"
Thank you in advance.
kkremitzki
Re: Ubuntu 16.04 - error libfreecadgui.so
Postby kkremitzki » Sun Nov 10, 2019 7:16 pm
Can you provide the output of the command
dpkg -l | grep freecad
please?
Edit: Nvm, was able to reproduce this myself. I'll try to fix it shortly.
kkremitzki
Postby kkremitzki » Sun Nov 10, 2019 8:50 pm
I found the problem! It was a renaming mistake between version 0.19 and 0.18 in the packaging files:
libfreecad-python2-0.18.install
libfreecad-python3-0.19.install
I will be triggering a build shortly which will provide the fix. Thank you for reporting this.
Vince-Fr
Postby Vince-Fr » Mon Nov 11, 2019 11:08 am
Hi kkremitzki, Thank you for your help.
