Animation WB Not Installing/Loading
I have a clean install of FreeCAD as below on a clean install of openSUSE Leap. I have used the Addon manager to install several additional workbenches all of which seem to be ok except the animation workbench which is not loading. Addon manager shows it as being installed and the files are present in ~/.FreeCAD/Mod/animation, however it is not listed in the Workbench dropdown menu and files I have previously created using the animation WB no longer work
Does anyone have an idea where to look next (missing python library maybe?)
Thanks
OS: openSUSE Leap 15.1
Version: 0.18.Unknown
Python version: 3.6.5
Qt version: 5.9.7
Coin version: 3.1.3
Thanks
Qt version: 5.9.7
Coin version: 3.1.3
Re: Animation WB Not Installing/Loading
Check report view. I think Animation WB has a problem with Qt5.
- microelly2
I need more information what goes wrong.
In my environment it still works fine:
OS: Ubuntu 14.04.6 LTS (Unity/ubuntu)
Version: 0.19.18403 (Git) AppImage
Hash: 0717b4fc23ef1db70964c3977d25e2fe46a739d1
Python version: 3.7.3
Qt version: 5.12.5
Qt version: 5.12.5
What do you need?
I get after starting Freecad in report view the message
If I load a model using Animation WB (from a post in the german forum) I get
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /Users/cb/Library/Preferences/FreeCAD/Mod/animation/InitGui.py
Please look into the log file for further information
File "/Users/cb/Library/Preferences/FreeCAD/Mod/animation/Animation.py", line 30, in <module>
matplotlib.rcParams['backend.qt4']='PySide'
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/lib/python3.7/site-packages/matplotlib/__init__.py", line 808, in __setitem__
f"{key} is not a valid rc parameter (see rcParams.keys() for "
<class 'KeyError'>: 'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'
- microelly2
In Report View I have "During initialization the error No module named 'matplotlib' occurred in /home/user/.FreeCAD/Mod/animation/InitGui.py
Please look into the log file for further information"
I have python2-matplotlib installed but there are also python2-matplotlib-qt4 and python2-matplotlib-qt5 available. There are also all 3 available for python3
Are any of these likeky to work or do I need to wait for the update with matplotlib removed?
To answer my own question I installed python3-matplotlib and whatever dependencies this has and the Animation WB now loads and seems to work ok (at least with my simple animations)
Thanks
Thanks
Sorry if I'm a bit late to this thread. I've got the same message as chrisb:
I followed the same solution as on the github issue: https://github.com/microelly2/Animation/issues/35
By commenting out line 30 in animation.py the message is gone.
The remaining question is whether this line is doing anything useful, or rather what functionality could be broken by not having it? I haven't been able to find anything broken by doing this, but happy to test if anyone can suggest anything. Or does it break things for other OS's (I only have MacOS)?
# matplotlib.rcParams['backend.qt4']='PySide'
- microelly2
I think we can remove matplotlib functionality from animation wb.duncandoo wrote: ↑Sat Feb 08, 2020 11:18 am
To display information of the tracks can be done with other tools.
I will delete the code from the project.
