Full error message here:
CMake Warning at CMakeLists.txt:864 (find_package):
By not providing "FindQt5Network.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"Qt5Network", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Network" with
any of the following names:
Qt5NetworkConfig.cmake
qt5network-config.cmake
Add the installation prefix of "Qt5Network" to CMAKE_PREFIX_PATH or set
"Qt5Network_DIR" to a directory containing one of the above files. If
"Qt5Network" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:865 (find_package):
By not providing "FindQt5Xml.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Xml", but
Could not find a package configuration file provided by "Qt5Xml" with any
Qt5XmlConfig.cmake
qt5xml-config.cmake
Add the installation prefix of "Qt5Xml" to CMAKE_PREFIX_PATH or set
"Qt5Xml_DIR" to a directory containing one of the above files. If "Qt5Xml"
provides a separate development package or SDK, be sure it has been
installed.
CMake Warning at CMakeLists.txt:867 (find_package):
By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project
"Qt5Widgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Widgets" with
Qt5WidgetsConfig.cmake
qt5widgets-config.cmake
Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set
"Qt5Widgets_DIR" to a directory containing one of the above files. If
"Qt5Widgets" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:868 (find_package):
By not providing "FindQt5PrintSupport.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"Qt5PrintSupport", but CMake did not find one.
Could not find a package configuration file provided by "Qt5PrintSupport"
with any of the following names:
Qt5PrintSupportConfig.cmake
qt5printsupport-config.cmake
Add the installation prefix of "Qt5PrintSupport" to CMAKE_PREFIX_PATH or
set "Qt5PrintSupport_DIR" to a directory containing one of the above files.
If "Qt5PrintSupport" provides a separate development package or SDK, be
sure it has been installed.
CMake Warning at CMakeLists.txt:869 (find_package):
By not providing "FindQt5OpenGL.cmake" in CMAKE_MODULE_PATH this project
"Qt5OpenGL", but CMake did not find one.
Could not find a package configuration file provided by "Qt5OpenGL" with
Qt5OpenGLConfig.cmake
qt5opengl-config.cmake
Add the installation prefix of "Qt5OpenGL" to CMAKE_PREFIX_PATH or set
"Qt5OpenGL_DIR" to a directory containing one of the above files. If
"Qt5OpenGL" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:870 (find_package):
By not providing "FindQt5Svg.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Svg", but
Could not find a package configuration file provided by "Qt5Svg" with any
Qt5SvgConfig.cmake
qt5svg-config.cmake
Add the installation prefix of "Qt5Svg" to CMAKE_PREFIX_PATH or set
"Qt5Svg_DIR" to a directory containing one of the above files. If "Qt5Svg"
installed.
CMake Warning at CMakeLists.txt:871 (find_package):
By not providing "FindQt5UiTools.cmake" in CMAKE_MODULE_PATH this project
"Qt5UiTools", but CMake did not find one.
Could not find a package configuration file provided by "Qt5UiTools" with
Qt5UiToolsConfig.cmake
qt5uitools-config.cmake
Add the installation prefix of "Qt5UiTools" to CMAKE_PREFIX_PATH or set
"Qt5UiTools_DIR" to a directory containing one of the above files. If
"Qt5UiTools" provides a separate development package or SDK, be sure it has
been installed.
CMake Warning at CMakeLists.txt:872 (find_package):
been installed.
CMake Warning at CMakeLists.txt:873 (find_package):
By not providing "FindQt5Concurrent.cmake" in CMAKE_MODULE_PATH this
"Qt5Concurrent", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Concurrent"
Qt5ConcurrentConfig.cmake
qt5concurrent-config.cmake
Add the installation prefix of "Qt5Concurrent" to CMAKE_PREFIX_PATH or set
"Qt5Concurrent_DIR" to a directory containing one of the above files. If
"Qt5Concurrent" provides a separate development package or SDK, be sure it
has been installed.
CMake Warning at CMakeLists.txt:875 (find_package):
By not providing "FindQt5WebKitWidgets.cmake" in CMAKE_MODULE_PATH this
"Qt5WebKitWidgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5WebKitWidgets"
Qt5WebKitWidgetsConfig.cmake
qt5webkitwidgets-config.cmake
Add the installation prefix of "Qt5WebKitWidgets" to CMAKE_PREFIX_PATH or
set "Qt5WebKitWidgets_DIR" to a directory containing one of the above
files. If "Qt5WebKitWidgets" provides a separate development package or
SDK, be sure it has been installed.
CMake Error at CMakeLists.txt:880 (MESSAGE):
Qt5 libraries not found.
I searched for some solutions but still failed to compile. Do you have any idea how to fix it?
Thanks in advanced!
