[solved] conda: win: build-errors 20191201
Founder
Re: conda: win: build-errors 20191201
Post by wmayer »
I was able to build FreeCAD and pass all the self tests, I can switch to the ReverseEngineering WB. Is there a way to test if this actually worked and there will not be problems at runtime?
You can do
import ReverseEngineering
dir(ReverseEngineering)
If it lists e.g. "triangulate" then pcl is enabled. In case there were serious binary incompatibilities then FreeCAD would have crashed as soon as loading the workbench.
UR_
Post by UR_ »
Last build 0.19.18827 finished successfully.
changed:
-D Boost_NO_CMAKE=TRUE
to:
-D Boost_NO_BOOST_CMAKE:BOOL=ON
:man_facepalming:
I will install and test PCL once looo's PR has been merged
https://github.com/conda-forge/pcl-feedstock/pull/18
looo
Post by looo »
UR_ wrote: Thu Dec 05, 2019 8:48 am I will install and test PCL once looo's PR has been merged
If you want to accelerate the process you can clone the pcl-feedstck (my fork) and call conda-build on it and upload to the anaconda freecad-channel.
requrements:
conda install conda-build anaconda-client
build procedure:
git clone https://github.com/conda-forge/pcl-feedstock
cd pcl-feedstock
git remote add looooo https://github.com/looooo/pcl-feedstock
git fetch --all
git chekout patch-1
conda build . -m .ci_support\win_cxx_compilervs2015vc14.yaml
once installed you can upload to the freecad organization by:
anaconda upload <package-name> -u freecad -c dev
But you have to create an account for https://anaconda.org/ first + I need to add you to the maintainers.
Just in case you want to accelerate the conda-packaging... ;)
looo
Post by looo »
test-package uploaded: https://anaconda.org/freecad/pcl/files
now looking if it works: https://dev.azure.com/sppedflyer/feedst ... buildId=70
Right now I haven't changed any pcl cmake-configs at build time. So this might fail.
looo
Post by looo »
seems like it is now also working for windows:
['__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'approxSurface', 'featureSegmentation', 'filterVoxelGrid', 'gridProjection', 'marchingCubesHoppe', 'marchingCubesRBF', 'normalEstimation', 'poissonReconstruction', 'regionGrowingSegmentation', 'sampleConsensus', 'triangulate', 'viewTriangulation']
With the dynamical linked boost library I do not have to replace any cmake configs. For conda-dorge it is suggested to use dynamic linking where possible. Also it makes totally sense to align all platforms as much as possible.
OS: Windows 10 (10.0)
Version: 0.19.18829 (Git)
Hash: 186d52ffd47696fadcd91369365e97f084051e7b
Python version: 3.7.3
Qt version: 5.12.5
Locale: German/Austria (de_AT)
sgrogan
Post by sgrogan »
Ahh, so I bet before your fix FreeCAD was using the static boost libs, when looo and enabled PCL, PCL's config forced the static boost libs, hence the same error. I wonder if
-D Boost_NO_BOOST_CMAKE=TRUE
works? The key doesn't exist, so maybe when creating it from the command line it's necessary to specify the BOOL, I created mine in the cmake-gui and set BOOL that way.
wmayer wrote: Thu Dec 05, 2019 3:07 amYou can do
Thanks, it worked so I guess my workaround worked.
looo wrote: Thu Dec 05, 2019 7:35 pm seems like it is now also working for windows:
Great
This was a good thread it looks like all of our problems are solved and we have the Reverseengineering WB available on Conda Win now :)
Thanks for the guidance in this thread wmayer!
"fight the good fight"
