No module named 'Qt
alpis
No module named 'Qt
Post by alpis »
Hello everyone, I wanted to make a query about a problem that I have in some of the FreeCAD modules, since I have done a search and I have not found any reference. When I start the program, I get the error "No module named 'Qt'" occurred in /home/optica1/. FreeCAD/Mod/..."" being the modules that give me problems the module of "animation" and the module "Node editor", I use the operating system linux , "linux mint" and I have verified that I have installed Pysyde and Pyqt" and most libraries , . Any suggestions?. Thank you
Re: No module named 'Qt
Post by Kunda1 »
Please help us to help you.
What instructions are you following to install FreeCAD ?
What linux mint version are you running?
What version of FreeCAD are you trying to compile?
This sounds like a packaging issue specifically in Linux Mint. You need to make sure that Qt itself is installed on your machine.
openBrain
Post by openBrain »
alpis wrote: Mon Jan 20, 2020 12:37 pm Any suggestions?. Thank you
Yep. Please attach your full FreeCAD info so we know your setup. ;)
openBrain
Post by openBrain »
Kunda1 wrote: Mon Jan 20, 2020 12:53 pm What version of FreeCAD are you trying to compile?
From what I understand, this isn't a compile but an install issue. ;) FC is up & running but some modules trigger exceptions. ;)
Have you tried the AppImage? It should be self contained.
alpis
Post by alpis »
Hi, I download and run FreeCAD.AppImage, I have two versions of FreeCad 0.18 and 0.19 App , in both case i have the same problem.
My linux system is a LinuxMint, (ubuntu based) an the version of linux Mint is Silvya 18.3.
the comand that i used is ./FreeCad_0.19.AppImage , The error apears in the console Python and in the terminal
alpis
Post by alpis »
thaks for help me
openBrain
Post by openBrain »
Please provide your full FreeCAD info (About box -> Copy to clipboard).
Also post a complete copy of the errors.
alpis
Post by alpis »
the output of freeCad is
optica1@optica1-P5K-VM ~/FreeCad $ ./FreeCAD_0.19.AppImage
/tmp/.mount_FreeCAbbrgTS
FreeCAD 0.19, Libs: 0.19R19242 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Loading Assembly 4 WorkBench. © Zoltan Hubert
Interlocking laser cut workbench loaded
Sheet Metal workbench loaded
During initialization the error "No module named 'Qt'" occurred in /home/optica1/.FreeCAD/Mod/Animation/InitGui.py
Please look into the log file for further information
During initialization the error "No module named 'Qt'" occurred in /home/optica1/.FreeCAD/Mod/NodeEditor-master/InitGui.py
connect failed: No existe el archivo o el directorio (" file doesn't exist")
nouveau: kernel rejected pushbuf: No existe el archivo o el directorio (" file doesn't exist")
nouveau: ch8: krec 0 pushes 0 bufs 2 relocs 0
nouveau: ch8: buf 00000000 00000002 00000004 00000004 00000000
nouveau: ch8: buf 00000001 00000006 00000004 00000000 00000004
The info of free cad is
OS: Linux Mint 18.3 (X-Cinnamon/cinnamon)
Version: 0.19.19242 (Git) AppImage
Hash: 2d752745c298108a1d7ec756bd0ca57818c7a174
Python version: 3.7.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Spanish/Spain (es_ES)
openBrain
Post by openBrain »
OK, more clear.
You said you installed PySide, but did you precisely install PySide2 (the '2' version is important) ?
I'm not very familiar with Mint, but maybe following line can do the trick :
sudo pip install pyside2
