No module named 'Qt
Re: No module named 'Qt
Yes i have pyside2 installed, , Send you some images of the library installed for freecad, for me this error is a mistery
It's seems that not recognize qt and pysyde2 for those modules , When i start FreeCAD, I cant find theses workbenchs
The pictures you show are just 'credits'. It doesn't tell what is installed or not.
This is indeed weird that only those 2 are triggering errors. Will have a deeper look.
Does Linux Mint have a downstream FreeCAD package maintainer? I can't find one on the list in [WIP] FreeCAD Packagers and Package Status
When i tried to reinstall PySide2, the console reply me that , i have le pyside2 installed
- kkremitzki
https://pages.charlesreid1.com/dont-sudo-pip/
Your build info shows a Python 3 build, but pip is a Python 2 command.
The error happens in two external workbenches. Therefore, remove the Animation and the NodeEditor directories under ~/.FreeCAD/Mod/. If FreeCAD starts, then you can investigate the problem by installing only one of the problematic workbenches, and trying again.alpis wrote: ↑Mon Jan 20, 2020 1:40 pm ...
During initialization the error "No module named 'Qt'" occurred in /home/optica1/.FreeCAD/Mod/Animation/InitGui.py
Please look into the log file for further information
During initialization the error "No module named 'Qt'" occurred in /home/optica1/.FreeCAD/Mod/NodeEditor-master/InitGui.py
If you are going to update your PySide2, you have to use pip3, so it uses the correct version for Python3.
However, isn't Linux Mint a version of Ubuntu? In this case, just install using apt; you don't need to call pip3 for this.
sudo apt install python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtwidgets
Hello everyone, I finally managed to run the module 'Animation', I installed Pisyde2 for python3, (thanks 'VOCX'), I deleted the animation module, and reinstalled it. Now it works, thank you!!
