QMessageBox on Fedora Rawhide
mdhill
Postby mdhill » Sat Jan 25, 2020 6:22 pm
Building from git fails with:
‘QMessageBox’ has not been declared
The same build yesterday succeeded but FreeCAD would crash opening a file:
#0  /lib64/libc.so.6(+0x3cac0) [0x7fcc7b857ac0]
Today I tried flatpak-builder with FreeCAD git master and got the same QMessageBox error.
Mike
OS: "Fedora release 32 (Rawhide)" (GNOME/gnome)
Version: 0.19.19367 (Git)
Hash: 26aed44d4fe92e711da8611c02edfe9e9c6f53b9
Python version: 2.7.17
OCC version: 6.9.1.oce-0.18
vocx
Re: QMessageBox on Fedora Rawhide
Postby vocx » Sat Jan 25, 2020 7:51 pm
Yes, this just happened due to some changes upstream. I'm sure it will be resolved by the end of the day.
Besides that, I just want to point out that you are using obsolete packages. You should not use Python 2 nor Qt4 any more. Use Python 3 and Qt5.
Also, the OCCT "community edition" that you are using OCE 6.9.x has not been used in many years. You should be using a 7.x version, preferably OCCT 7.3.
OCCT 7.4 was released recently, but I'm not sure if packagers have it running well in every system yet, so I still advice to use 7.3.
mdhill
Postby mdhill » Sat Jan 25, 2020 8:55 pm
Thanks, perfect.
Mike
vocx
Postby vocx » Sun Jan 26, 2020 5:02 pm
This problem should be solved with git commit a226801f1b.
See Compile Fail Current Master.
mdhill
Postby mdhill » Mon Jan 27, 2020 1:02 pm
Works, thanks.
mdhill
Postby mdhill » Mon Jan 27, 2020 3:06 pm
Also fixed the ancient dependency issue by forcing the upgrade of SIMVoleon, which was stuck on python2.
