New libpacks for Windows with Qt5.15, OCC7.5
apeltauer
Re: New libpacks for Windows with Qt5.12.6, OCC7.4
Post by apeltauer »
Update:
After debuging with Jean-Marie, now i can send fc files to the cloud.
You can find a 7z file with the compiled curl. This is a release build. I had to build curl without openssl support. Just enabled the winssl(scheme) support. Otherwise curl does not takte os specific ca certifications.
https://github.com/apeltauer/FreeCAD/re ... ag/openssl
Also on the github repo, a modified cloud wb cmake file can be found. Cmake then finds the curl lib and includes inside the libpack.
The cmake file needs some clean up and modifications for a debug build.
Post by Kunda1 »
apeltauer wrote: Mon Mar 02, 2020 5:42 pm Update:
Should we track these changes in a ticket ?
Edit: also: Awesome! 8-)
apeltauer
Post by apeltauer »
Kunda1 wrote: Mon Mar 02, 2020 5:51 pm
When we are ready, we need to make a clean commit with all the changes... for now we are checking what else we need :)
apeltauer
Post by apeltauer »
wmayer wrote: ping
Werner what is your opinion on building curl? I am not sure if i should rename the curl version i am build from source with winssl active. I had build curl with openssl support on, but then the ca verification failed. After digging around a found out that when building curl with only winssl active and openssl deactivated curl takes the ca certificates from windows. But i have found some threads in the internet that some tasks may fail if openssl is missing. So this is the reason why i am struggling with the name. A option would be to name the curl stuff with winssl support e.g. curl_winssl...
Opinions welcome.... :)
Founder
Post by wmayer »
apeltauer wrote: Mon Mar 02, 2020 7:11 pm Werner what is your opinion on building curl?
No idea what's best. I have never worked with curl and so it's hard for me to tell how to handle things.
apeltauer
Post by apeltauer »
wmayer wrote: Mon Mar 02, 2020 9:33 pm No idea what's best. I have never worked with curl and so it's hard for me to tell how to handle things.
Ok, thanks for your answer. I think for now i leave the naming. If we need an additional curl version we probably rename the new version ...
Post by Kunda1 »
@apeltauer thx again for your help :D
apeltauer
Post by apeltauer »
Update:
Manged to build curl and openssl for windows.
Now the cloud workbench also runs under Windows.
I have created a new LibPack (ver. 12.1.4) with curl and openssl check out:
https://github.com/apeltauer/FreeCAD/releases
Also i made some changes in the source code. Check out this pr: https://github.com/FreeCAD/FreeCAD/pull/3179
sgrogan
Post by sgrogan »
apeltauer wrote: Sun Mar 15, 2020 1:35 pm I have created a new LibPack (ver. 12.1.4) with curl and openssl check out:
Thanks for this.
I used the "12.1.4" version when I added ply and lxml to the Libpack, and we're using it here: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
Which in turn is used in https://github.com/FreeCAD/FreeCAD/blob ... s.yml#L248
How do you suggest resolving this conflict?
EDIT: With the new Libpack I get a test error in FEM for missing ply package. Adding the package to bin/site-packages fixes it. I used the latest PYPI version (It's pure python)
For info ply was provided in the FreeCAD source/binary by way of the OpenSCAD WB. It has been recently removed.
OS: Windows 10 (10.0)
Version: 0.19.20095 (Git)
Hash: 168ce605a16a3fc0319fd7262e2d90042bf0f8ae
Python version: 3.6.8
Qt version: 5.12.1
"fight the good fight"
apeltauer
Post by apeltauer »
Thanks for the hint.
sgrogan wrote: Mon Mar 16, 2020 8:53 pm How do you suggest resolving this conflict?
I will increase the version to 12.1.5. I will also try to add your suggested lib. When i am done will come back to this thread...
