Maybe the answer is somewhere in https://forum.freecadweb.org/viewtopic.php?f=4&t=51345 ?geraldfuchs wrote: ↑Mon Jan 18, 2021 10:20 am I tried to use docker for compile/build, on a MacOS and the compile/build process works, no error messages, though it took quite long.
Ticket #3821 - Docker env build container, now with FEM!
Re: Ticket #3821 - Docker env build container, now with FEM!
I just thought to give that a try since the homebrew solution (for Big Sur) still has some lackings. But at 39% I got Too bad
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
src/App/CMakeFiles/FreeCADApp.dir/build.make:428: recipe for target 'src/App/CMakeFiles/FreeCADApp.dir/DocumentObserverPython.cpp.o' failed
make[2]: *** [src/App/CMakeFiles/FreeCADApp.dir/DocumentObserverPython.cpp.o] Error 4
make[2]: *** Waiting for unfinished jobs....
Looks like this no longer works with HEAD
Different question: is X11 really required for a pure build on macOS?
CMake Error at cMake/FreeCAD_Helpers/CompilerChecksAndSetups.cmake:39 (message):
FreeCAD 0.20 and later requires C++17. G++ must be 7.3 or later, the used
version is 6.3.0
vejmarie wrote: pinged by pinger macro
- vejmarie
You do not need X11 for a build on macOS. Which compiler version are you using GCC or CLang ? Most of our build are based on CLang and XCode. Can you give a try with GCC 10 at least. It is available with homebrewpilhuhn wrote: ↑Sun Mar 21, 2021 10:56 am Looks like this no longer works with HEAD
Different question: is X11 really required for a pure build on macOS?Code: Select all
CMake Error at cMake/FreeCAD_Helpers/CompilerChecksAndSetups.cmake:39 (message): FreeCAD 0.20 and later requires C++17. G++ must be 7.3 or later, the used version is 6.3.0
- vejmarie
@vjemarie This is with the docker build (as the thread subject says). The outdated gcc is inside that docker image and not the host one, so I can't just brew install the new one.
I suspect that this failure affects everyone trying to use this way of building independent of the host OS.
I tried to follow the Compile with Docker guide on my MacOS 11.2.3 Big Sur , Apple M1 chip. This is as far as I could get
david@Davids-Air ~ % docker run -it --rm -v $fc_source:/mnt/source -v $fc_build:/mnt/build -e "DISPLAY" -e "QT_X11_NO_MITSHM=1" -v /tmp/.X11-unix:/tmp/.X11-unix:ro registry.gitlab.com/daviddaish/freecad_docker_env:latest
WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
root@c6b1550084a6:~#
Is there anything I can do to fix problem?
Hi there!
I haven't checked, but maybe someone else is already compiling FreeCAD for the M1 based machines. Not an easy task anyway...
Regards!
The problem is that the building tools (compiler, linker, etc.) are for intel based machines, and the new M1 is an arm based machine: the Docker image that @David_D created should be refactored for this purpose. Maybe you can try to use his Docker image creation script as a template to create a new one changing the building toolchain.DavidA380 wrote: ↑Tue May 11, 2021 11:04 pm I tried to follow the Compile with Docker guide on my MacOS 11.2.3 Big Sur , Apple M1 chip. This is as far as I could get
Regards!
Same issue now a year later, the container has too old build tools so it cannot build 0.20.
What's the status of the docker container, is it abandoned and everyone is building without docker?
