New build for Mac OS X 10.6 -- does it work?
peterl94
Postby peterl94 » Fri Aug 30, 2013 5:29 pm
I just did another build with my osx-app branch for Mac OS X 10.6 (x86_64), and was wondering if my build works for anyone else. The only thing that I know doesn't work is the help -- everything else should work fine. The app can be downloaded here.
It may or may not work on newer version of OS X. If you do try it on a new version of OS X, you will need to install XQuartz because I didn't bundle the X11 libraries with the app.
Thanks,
Peter
peterl94
Re: New build for Mac OS X 10.6 -- does it work?
Postby peterl94 » Sun Sep 01, 2013 4:47 am
I got the chance to try my build on mac running 10.8 today, and confirmed that it does work on mountain lion if you have XQuartz installed.
o0l10
Postby o0l10 » Mon Sep 02, 2013 11:37 pm
Also verified that it works on 10.8, though only to see if I could import your build's freeCAD lib into python like the wiki describes. (I can't; dynlibs aren't linked in a way that the importer likes. Same issue as the release .app :? )
(Can you tell me how you got SoQt built? I've brewed coin and then qt but the soqt source build always fails on the qt symbols ... :evil: )
peterl94
Postby peterl94 » Tue Sep 03, 2013 5:13 pm
Well, thanks for tying it anyway. I think I might know of a way that a relocatable .app could be built with out using @executable_path... I'll give it a try it when I have the time.
For this build, I used the binary package of Qt and compiled everything else manually, but I have used homebrew to install all of the dependencies before. In both cases I didn't run into any errors when building SoQt. Though, come to think of it, I did have to create homebrew recipes for some libraries, but I don't remember if SoQt was one of them. Maybe you can post more about the error in your build problems thread.
sayluv
Postby sayluv » Sun Sep 08, 2013 11:16 pm
thanks Peter. I have that installed now.
moonman91
Postby moonman91 » Sun Oct 06, 2013 1:02 pm
It seems to work fine for me too on MAC OS X 10.6.8.
