[Fixed] conda build 0.19.20381 broken
UR_
Postby UR_ » Fri Apr 03, 2020 10:08 am
Since conda updated to occt 7.4.0 build 4
(freecad) C:\Users\aio\Miniconda3>conda list occt
# packages in environment at C:\Users\aio\Miniconda3\envs\freecad:
# Name                    Version                   Build  Channel
occt                      7.4.0                h823b557_4    conda-forge
FreeCAD build finishes but most workbenches (eg. Sketcher) failed to load because dlls aren't found.
Had to downgrade to build 3 to get a working FreeCAD build.
(freecad) C:\Users\aio\Miniconda3>conda install occt=7.4.0=*_3
Any suggestions?
Markymark
Re: conda build 0.19.20381 broken
Postby Markymark » Sat Apr 04, 2020 3:07 pm
Same issue here with 0.19.20310 (current binaries from guthub).
Let me know if further information is needed.
_______________________________________
OS: Windows 8.1 (6.3)
Version: 0.19.20310 (Git)
Hash: 2cac4898d7d62276fbbaaef5b4cecb9bfdd29a33
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
looo
Postby looo » Sat Apr 04, 2020 3:44 pm
Vtk support was added recently:
https://github.com/conda-forge/occt-feedstock/pull/38
Can you give feedback which libraries are missing?
sgrogan
Postby sgrogan » Sat Apr 04, 2020 3:57 pm
During initialization the error "DLL load failed while importing Part: The specified module could not be found." occurred in freecad.asm3
  File "<string>", line 144, in InitApplications
  File "C:\Users\Chris\Downloads\FreeCAD_0.19.20310-Win-Conda_vc14.x-x86_64\bin\lib\importlib\__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "C:\Users\Chris\Downloads\FreeCAD_0.19.20310-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\init_gui.py", line 3, in <module>
    from .utils import mainlogger as logger
  File "C:\Users\Chris\Downloads\FreeCAD_0.19.20310-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\utils.py", line 10, in <module>
    import FreeCAD, FreeCADGui, Part, Draft
ImportError: DLL load failed while importing Part: The specified module could not be found.
EDIT: When switching to Sketcher
DLL load failed while importing SketcherGui: The specified module could not be found.
  File "<string>", line 43, in Initialize
I'll install depends.exe and try to be more specific.
looo
Postby looo » Sat Apr 04, 2020 8:49 pm
The package occt-7.4.0-h823b557_4.tar.bz2 looks totally wrong. Should be marked as broken soon.
edit: should be fixed
