(Sorry, so far I have been unable to determine which version of FreeCAD I downloaded from github last week.)
When I run "make", I get "/freecad/Makefile.am:40: *** missing separator. Stop."
I've gone through Makefile.am, and all the tabs are tabs, not spaces,
Does anybody know what the missing separator in Makefile.am is?
make: missing separator: Makefile.am
"When the facts change, I change my mind. What do you do, sir?"
-- John Maynard Keynes
Re: make: missing separator: Makefile.am
Did you use CMake? Autotools is not supported any more.
Yes, I am using CMAKE. However, Makefile.am comes with the FreeCAD download from github.
Do you mean you downloaded the archived source in zip format rather than making a "git clone" in the console?
Edit: I just downloaded the zip file and the archive contains no Makefile.am...
2nd edit: it may be useful to indicate the url you got your FreeCAD sources from.
git clone git://git.code.sf.net/p/free-cad/code freecad
OK in your first post you mentioned GitHub which is a different repository, it's actually a mirror for the one at Sourceforge. The Github one allows you to download a zip file.
It's very odd, maybe try to update your sources to current with "git pull" then try again?
Is it a fresh compile or have you already compiled FreeCAD in the same folder? I think it is recommended to do an out-of-source build as it can sometimes avoid corruption problems.
What are the exact commands you entered to the terminal window?When I run "make", I get "/freecad/Makefile.am:40: *** missing separator. Stop."
