0.19 Snap Preview needs "testers"
Cpl_Detritus
Re: 0.19 Snap Preview needs "testers"
Post by Cpl_Detritus »
Sorry a total noob here but I didn't catch the answer to the initial question:
What is snap and why do we need it?
ppd
Post by ppd »
From https://snapcraft.io/docs/getting-started
A snap is a bundle of an app and its dependencies that works without modification across many different Linux distributions. Snaps are discoverable and installable from the Snap Store, an app store with an audience of millions.
Snaps are a package format that is primarily used on Ubuntu, but is usable on quite a few Linux distributions: https://snapcraft.io/docs/installing-snapd
Tightly coupled with the package format is the store: https://snapcraft.io/store, with the idea here being quite similar to the Play Store on Android or Apple's App Store.
User benefits are in essence:
- easy app discovery and easy installation
- auto-updates (see below)
- snaps run in confinement (like permissions on Android) and can only affect the host system in clearly defined and declared ways (plugs & sockets)
The developer benefits include:
- Defined platform ("base"). A snap will run on many different distributions without changes. Packaging is thus quite easy.
- Auto updates by default. Users will get the most up-to-date versions very quickly
- Channels. Providing nightly builds in channel "latest/edge" while at the same time providing releases in channel "latest/stable" makes it easy serve all kinds of users ("need latest features" vs. "need stable software")
A very similar technology exists and FreeCAD is also published as such: Flatpaks (https://flatpak.org/)
Try FreeCAD from the Snap Store: Stable releases (in latest/stable) & daily builds (in latest/edge). Supports installing additional python packages via pip!
Cpl_Detritus
Sounds like some good things mixed with some bad things.
For example why do I get the feeling that Canonical is trying to build a fence around open software and call it an 'ecosystem'. Why is this not an open standard instead of something that only Canonical owns and controls?
ppd
Post by ppd »
Indeed.
For the record: Snapd (https://github.com/snapcore/snapd/), the program that installs & launches snaps, and snapcraft (https://github.com/snapcore/snapcraft/), the tool used to create snap packages, are both FOSS.
As to why the snap store is not (yet) open source: https://www.youtube.com/watch?v=x8MgktKqjsU
gbtw
Post by gbtw »
Hi, it was actually fortunate / unfortunate that 0.19 doesn't seem to work on the ppa since updating to KUbuntu 20.04 that i tried the beta snap.
The application launches but none of the text is available and i guess the font config warnings pertain to its xml :?: missing configuration.
I get the following when starting the application from the console:
FreeCAD 0.19, Libs: 0.19R20940 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Fontconfig warning: line 5: unknown element "its:rules"
Fontconfig warning: line 6: unknown element "its:translateRule"
Fontconfig error: line 6: invalid attribute 'translate'
Fontconfig error: line 6: invalid attribute 'selector'
Fontconfig error: line 7: invalid attribute 'xmlns:its'
Fontconfig error: line 7: invalid attribute 'version'
Fontconfig warning: line 9: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/65-fonts-persian.conf", line 34: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 36: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 36: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/69-unifont.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/69-unifont.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/80-delicious.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/80-delicious.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/90-synthetic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/90-synthetic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 6: invalid attribute 'version'
Fontconfig error: Cannot load default config file
/usr/share/libdrm/amdgpu.ids: No such file or directory
On relaunch I get the following additional message:
mkdir: cannot create directory '/home/gbtw/snap/freecad/10/.config': File exists
Maybe add a simple thing to the bash script to check if directory doens't exist and then do the mkdir.
if [ ! -d "path" ]; then
	mkdir path
fi
Hope it helps
Dugi
Post by Dugi »
Hi
I'm trying to use freecad 0.19 with Trails addon in Ubuntu 20.10.
https://github.com/joelgraff/freecad.trails
I've installed addon manually with git clone --recursive in ~/nap/freecad/current/.FreeCAD/Mod
And I have problem.
When I'm trying to use "Import point" icon, i'm getting:
20:13:10  Running the Python command 'Import Point File' failed:
  File "/home/dugi/snap/freecad/18/.FreeCAD/Mod/trails/freecad/trails/geomatics/point/ImportPointFile.py", line 110, in Activated
    UI.setWindowFlags(QtCore.Qt.Window)
Internal C++ object (PySide2.QtWidgets.QDialog) already deleted.
When I had 18.04 with freecad daily from ppa, and this addon, it was working.
I have python3-pyside2.qtwidgets installed.
