FreeCAD 0.18.4 fails to build with vtk 9.0
hobbes1069
Re: FreeCAD 0.18.4 fails to build with vtk 9.0
Post by hobbes1069 »
I tested building with vtk 9.0 and I think I got the CMake stuff mostly worked out as it failed during compiling for obvious reasons.
I wanted to make sure i didn't mess anything up for vtk < 9.0 so I did a standard build in Fedora Rawhide and ran into this:
builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp: In member function 'PyObject* Part::GeometryPy::getExtensionOfType(PyObject*)':
/builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp:273:134: error: call of overloaded 'Tuple(size_t)' is ambiguous
  273 |                 PyObject* cpy = static_cast<GeometryExtensionPy *>(ext->getPyObject())->copy(Py::new_reference_to(Py::Tuple(size_t(0))));
In file included from /usr/include/CXX/Objects.hxx:42,
                 from /builddir/build/BUILD/freecad/src/Base/GeometryPyCXX.h:27,
                 from /builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp:40:
/usr/include/CXX/Python3/Objects.hxx:2260:18: note: candidate: 'Py::Tuple::Tuple(int)'
 2260 |         explicit Tuple( int size=0 )
/usr/include/CXX/Python3/Objects.hxx:2247:18: note: candidate: 'Py::Tuple::Tuple(PyObject*, bool)'
 2247 |         explicit Tuple( PyObject *pyob, bool owned = false )
/usr/include/CXX/Python3/Objects.hxx:2234:11: note: candidate: 'Py::Tuple::Tuple(const Py::Tuple&)'
 2234 |     class Tuple: public Sequence
/usr/include/CXX/Python3/Objects.hxx:2234:11: note: candidate: 'Py::Tuple::Tuple(Py::Tuple&&)'
/builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp: In member function 'PyObject* Part::GeometryPy::getExtensionOfName(PyObject*)':
/builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp:307:130: error: call of overloaded 'Tuple(size_t)' is ambiguous
  307 |             PyObject* cpy = static_cast<GeometryExtensionPy *>(ext->getPyObject())->copy(Py::new_reference_to(Py::Tuple(size_t(0))));
/builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp: In member function 'PyObject* Part::GeometryPy::getExtensions(PyObject*)':
/builddir/build/BUILD/freecad/src/Mod/Part/App/GeometryPyImp.cpp:441:41: error: call of overloaded 'Tuple(size_t)' is ambiguous
  441 |                 Py::Tuple args(size_t(0));
Founder
Post by wmayer »
Here is a branch where I can build smesh with vtk9: https://github.com/wwmayer/FreeCAD/comm ... fa8f90411e
Now there are open several FIXME's. But I don't know what to do.
hobbes1069
I still would like an answer to my questions I asked earlier...
https://forum.freecadweb.org/viewtopic. ... 10#p408172
But for now I'll go ahead and commit my changes to the fork.
https://github.com/hobbes1069/FreeCAD/c ... d72f952645
Thanks,
Richard
qingfeng.xia
Post by qingfeng.xia »
After upgrade to Ubuntu 20.04, vtk-dev is broken ,so I can not compile freecad-daily any more, so I build my vtk9. When I built freecad upstream master latest 0.19, I run into problem with SalomeMesh, I know there are already some in-progress work to upgrade salome mesh, I hope once salomemesh updated it may solve the problem. ‘
vtkAbstractCellLinks*’ to ‘vtkCellLinks*’
/usr/local/include/vtk-9.0/vtkSmartPointer.h:195:3: note: candidate is: ‘vtkSmartPointer<ArrayType>::operator T*() const [with T = vtkAbstractCellLinks]’ <near match>
  195 |   operator T*() const noexcept { return static_cast<T*>(this->Object); }
/usr/local/include/vtk-9.0/vtkSmartPointer.h:195:3: note:   no known conversion from ‘vtkAbstractCellLinks*’ to ‘vtkCellLinks*’
/opt/FreeCAD/src/3rdParty/salomesmesh/src/SMDS/SMDS_Mesh.cpp: In member function ‘void SMDS_Mesh::dumpGrid(std::string)’:
/opt/FreeCAD/src/3rdParty/salomesmesh/src/SMDS/SMDS_Mesh.cpp:4771:51: error: invalid conversion from ‘vtkAbstractCellLinks*’ to ‘vtkCellLinks*’ [-fpermissive]
 4771 |         vtkCellLinks *links = myGrid->GetCellLinks();
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/build.make:167: src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o] Error 1
Ubuntu 18.04 LTS 64bit, python3, always work with latest FreeCAD daily build
Working on Cfd module for FreeCAD, FreeCAD_Module_Develop_Guide
https://github.com/ukaea/parallel-preprocessor/
https://github.com/qingfengxia/Cfd
looo
Post by looo »
wmayer wrote: Sat Jun 13, 2020 1:55 pm Here is a branch where I can build smesh with vtk9: https://github.com/wwmayer/FreeCAD/comm ... fa8f90411e
I see 4 different issues.
1.
#ifdef VTK_CELL_ARRAY_V2
//FIXME: vtk9
#else
  pts[0] = node->getVtkId();
#endif
2.
      vtkIdType oldLoc; //FIXME: vtk9
#else
      vtkIdType oldLoc = this->Locations->GetValue(j);
#endif
3.
//FIXME: vtk9
#else
          pts[i] = localClonedNodeIds[oldpt];
#endif
4.
//FIXME: vtk9
  this->Links = SMDS_CellLinks::New();
  //this->Links->Allocate(this->GetNumberOfPoints());
  this->Links->Register(this);
  //this->Links->BuildLinks(this, this->Connectivity);
  this->Links->Delete();
#else
#endif
hobbes1069
Has anyone asked VTK upstream what the v9 equivalent is to these?
looo
Post by looo »
hobbes1069 wrote: Mon Oct 12, 2020 12:23 pm Has anyone asked VTK upstream what the v9 equivalent is to these?
I don't think so. The only relevant topic I found was this one:
https://discourse.vtk.org/t/upcoming-ch ... array/2066
As we are quite stuck with this issue, it's a good idea to ask upstream how to proceed.
Founder
Post by wmayer »
I again had a look at the vtk9 source code and it looks the recipe to port smesh code is to use the overloaded version of vtkUnstructuredGrid::GetCellPoints().
For vtk8 or earlier the smesh code is of this form:
  vtkIdType npts = 0;
  vtkIdType* pts = 0;
  grid->GetCellPoints(myVtkID, npts, pts);
which used
void GetCellPoints(vtkIdType cellId, vtkIdType& npts, vtkIdType*& pts)
In vtk9 the 3rd argument has become const so that in the calling instance it's not possible any more to modify the array.
In vtk8 & vtk9 we still have this overloaded version:
void GetCellPoints(vtkIdType cellId, vtkIdList* ptIds) override;
In the vtk9 code I found an example how to modify an element in the list. The above code has to be changed to
  vtkNew<vtkIdList> cellPoints;
  grid->GetCellPoints(myVtkID, cellPoints.GetPointer());
  cellPoints->SetId(0, node->getVtkId());
looo
Post by looo »
wmayer wrote: Mon Oct 12, 2020 2:13 pm I again had a look at the vtk9 source code and it looks the recipe to port smesh code is to use the overloaded version of vtkUnstructuredGrid::GetCellPoints().
Some light at the end of the tunnel. :)
Does this solves all four of the fixme's?
Founder
Post by wmayer »
All FIXME's are solved now but in one case I am not sure if it's the right way:
void SMDS_UnstructuredGrid::BuildLinks()
  // Remove the old links if they are already built
  if (this->Links)
    this->Links->UnRegister(this);
  GetLinks()->Allocate(this->GetNumberOfPoints());
  GetLinks()->Register(this);
//FIXME: vtk9
  GetLinks()->BuildLinks(this); // <<<<<<<<<< ============== this->Connectivity cannot be passed any more
  GetLinks()->Delete();
#else
#endif
Anyway the branch https://github.com/wwmayer/FreeCAD/tree/smesh_vtk9.0 is ready for testing...
