I am a newbie FreeCad user. Version 18 (appimage) is installed on my Linux Mint 64bit desktop, and is running. I am trying to work myself through some simple scenarios. I ran into problem in parametric modelling. Trying to load "Macro EasyAlias" with the Add-On Manager - it just spins on loading macros. It seems to be searching for the Freecad wiki, but can't find it.
What should I do?
unable to add-on macros
Re: unable to add-on macros
Hi and welcome to the forum!
Try FreeCAD 0.19.
0.18 will most probably not be fixed.
Try FreeCAD 0.19.
Thanks, that did it. Being unfamiliar with FreeCad, I thought it to be safer to stay with the 'stable' version. Obviously wrong.
Well, kind-off worked, but not really.
Got the following error message:
[ File "/home/ralph/.FreeCAD/Macro/EasyAlias.FCMacro", line 137, in <module>
FreeCAD.Console.PrintError("Error. Unable to set alias: "+getCellContent(s,ci).replace(' ','_')+" for spreadsheet: "+str(s)+" cell "+cellIndexToAddress(getCellIndexNextColumn(ci))+"\n")
File "/home/ralph/.FreeCAD/Macro/EasyAlias.FCMacro", line 112, in getCellContent
return sheet.get(address)
<class 'ValueError'>: Invalid address or property.
/quote]
The parameter name is actually 'Planter.SidePanel.Tenon.vOffset', but I realize that the macro is supposed to replace a space by an underline. So I offered that form to the macro, but it still balked.
Can you install other macros? Then you should contact the author of the macro, it may need upgraded to current Python.
