I pulled out my old SpacePilot with the aim of using it on FreeCAD. It's an older device, but one still supported (just) by an older driver. I've installed the driver, and it works fine on SketchUp (my other CAD system).
I understand that this device works on FreeCAD using the 3Dmouse interface, and indeed I get a response when I operate the mouse. Problem is, I want to change so that zoom is configured on the forward/backward axis of the mouse, not the up/down axis. The driver utility allows me to switch between these two options, and this works for SketchUp. However, it doesn't work for FreeCAD.
Is there a way to manually adjust a configuration file for either 3DxWare or FreeCAD to re-orient the axes?
Windows 10
FreeCAD 0.18
3DxWare driver 10.4.10 Windows 64-bit
Regards,
Paul
3Dconnexion Space Pilot - Rotation/Zoom Issues
Re: 3Dconnexion Space Pilot - Rotation/Zoom Issues
Hi, I've managed to solve this myself. I found a reference on another post to customise->Spaceball. Have made changes and it works!
Thanks anyway...
Paul
Thanks anyway...
Paul
I haven't been able to find the page you found to fix your problem. I have the same problem as you described.
Edit: I found the answer, and it wasn't in fixing the 3DConnexion driver as I supposed it was. The solution is in FreeCAD itself. Go to Tools>Customize> Spaceball motion or buttons.
I now have the motion working nicely, but I haven't been able to get the buttons to work. I have the Space Pilot default buttons selected, and when I click on one of the buttons on the left panel, the correct function is highlighted on the right, but when I press the buttons on the Space Pilot, nothing happens. Does anyone know what I might be doing wrong?
