Compile with -DCMAKE_BUILD_TYPE=Debug
Gift
Re: Compile with -DCMAKE_BUILD_TYPE=Debug
Post by Gift »
otool -l /opt/homebrew/opt/python3.9/bin/python3
/opt/homebrew/opt/python3.9/bin/python3:
Load command 0
      cmd LC_SEGMENT_64
  cmdsize 72
  segname __PAGEZERO
   vmaddr 0x0000000000000000
   vmsize 0x0000000100000000
  fileoff 0
 filesize 0
  maxprot 0x00000000
 initprot 0x00000000
   nsects 0
    flags 0x0
Load command 1
      cmd LC_SEGMENT_64
  cmdsize 472
  segname __TEXT
   vmaddr 0x0000000100000000
   vmsize 0x0000000000004000
  fileoff 0
 filesize 16384
  maxprot 0x00000005
 initprot 0x00000005
   nsects 5
    flags 0x0
Section
  sectname __text
   segname __TEXT
      addr 0x0000000100003a1c
      size 0x0000000000000308
    offset 14876
     align 2^2 (4)
    reloff 0
    nreloc 0
     flags 0x80000400
 reserved1 0
 reserved2 0
Section
  sectname __stubs
   segname __TEXT
      addr 0x0000000100003d24
      size 0x00000000000000cc
    offset 15652
     align 2^2 (4)
    reloff 0
    nreloc 0
     flags 0x80000408
 reserved1 0 (index into indirect symbol table)
 reserved2 12 (size of stubs)
Section
  sectname __stub_helper
   segname __TEXT
      addr 0x0000000100003df0
      size 0x00000000000000e4
    offset 15856
     align 2^2 (4)
    reloff 0
    nreloc 0
     flags 0x80000400
 reserved1 0
 reserved2 0
Section
  sectname __cstring
   segname __TEXT
      addr 0x0000000100003ed4
      size 0x00000000000000d3
    offset 16084
     align 2^0 (1)
    reloff 0
    nreloc 0
     flags 0x00000002
 reserved1 0
 reserved2 0
Section
  sectname __unwind_info
   segname __TEXT
      addr 0x0000000100003fa8
      size 0x0000000000000058
    offset 16296
     align 2^2 (4)
    reloff 0
    nreloc 0
     flags 0x00000000
 reserved1 0
 reserved2 0
Load command 2
      cmd LC_SEGMENT_64
  cmdsize 152
  segname __DATA_CONST
   vmaddr 0x0000000100004000
  fileoff 16384
 filesize 16384
  maxprot 0x00000003
 initprot 0x00000003
   nsects 1
    flags 0x10
Section
  sectname __got
      size 0x0000000000000020
    offset 16384
     align 2^3 (8)
    reloff 0
    nreloc 0
     flags 0x00000006
 reserved1 17 (index into indirect symbol table)
 reserved2 0
Load command 3
      cmd LC_SEGMENT_64
  cmdsize 312
  segname __DATA
   vmaddr 0x0000000100008000
  fileoff 32768
 filesize 16384
  maxprot 0x00000003
 initprot 0x00000003
   nsects 3
    flags 0x0
Section
  sectname __la_symbol_ptr
   segname __DATA
      size 0x0000000000000088
    offset 32768
     align 2^3 (8)
    reloff 0
    nreloc 0
     flags 0x00000007
 reserved1 21 (index into indirect symbol table)
 reserved2 0
Section
  sectname __data
   segname __DATA
      addr 0x0000000100008088
      size 0x0000000000000008
    offset 32904
     align 2^3 (8)
    reloff 0
    nreloc 0
     flags 0x00000000
 reserved1 0
 reserved2 0
Section
  sectname __bss
   segname __DATA
      addr 0x0000000100008090
      size 0x0000000000001000
    offset 0
     align 2^0 (1)
    reloff 0
    nreloc 0
     flags 0x00000001
 reserved1 0
 reserved2 0
Load command 4
      cmd LC_SEGMENT_64
  cmdsize 72
  segname __LINKEDIT
   vmaddr 0x000000010000c000
  fileoff 49152
 filesize 1864
  maxprot 0x00000001
 initprot 0x00000001
   nsects 0
    flags 0x0
Load command 5
            cmd LC_DYLD_INFO_ONLY
        cmdsize 48
     rebase_off 49152
    rebase_size 8
       bind_off 49160
      bind_size 72
  weak_bind_off 0
 weak_bind_size 0
  lazy_bind_off 49232
 lazy_bind_size 336
     export_off 49568
    export_size 48
Load command 6
     cmd LC_SYMTAB
 cmdsize 24
  symoff 49632
   nsyms 23
  stroff 50152
 strsize 320
Load command 7
            cmd LC_DYSYMTAB
        cmdsize 80
      ilocalsym 0
      nlocalsym 1
     iextdefsym 1
     nextdefsym 1
      iundefsym 2
      nundefsym 21
         tocoff 0
           ntoc 0
      modtaboff 0
        nmodtab 0
   extrefsymoff 0
    nextrefsyms 0
 indirectsymoff 50000
  nindirectsyms 38
      extreloff 0
        nextrel 0
      locreloff 0
        nlocrel 0
Load command 8
          cmd LC_LOAD_DYLINKER
      cmdsize 32
         name /usr/lib/dyld (offset 12)
Load command 9
     cmd LC_UUID
 cmdsize 24
    uuid 68CAD6E1-30C1-31F7-974D-6D53E1EF22F4
Load command 10
      cmd LC_BUILD_VERSION
  cmdsize 32
 platform 1
    minos 11.0
      sdk 11.1
   ntools 1
     tool 3
  version 609.8
Load command 11
      cmd LC_SOURCE_VERSION
  cmdsize 16
  version 0.0
Load command 12
       cmd LC_MAIN
   cmdsize 24
  entryoff 14876
 stacksize 0
Load command 13
          cmd LC_LOAD_DYLIB
      cmdsize 112
         name /opt/homebrew/Cellar/python3.9/3.9.1_8/Frameworks/Python.framework/Versions/3.9/Python (offset 24)
   time stamp 2 Thu Jan  1 01:00:02 1970
      current version 3.9.0
compatibility version 3.9.0
Load command 14
          cmd LC_LOAD_DYLIB
      cmdsize 56
         name /usr/lib/libSystem.B.dylib (offset 24)
      current version 1292.60.1
compatibility version 1.0.0
Load command 15
      cmd LC_FUNCTION_STARTS
  cmdsize 16
  dataoff 49616
 datasize 16
Load command 16
      cmd LC_DATA_IN_CODE
  cmdsize 16
  dataoff 49632
 datasize 0
Load command 17
      cmd LC_CODE_SIGNATURE
  cmdsize 16
  dataoff 50480
 datasize 536
/opt/homebrew/opt/python3.9/Frameworks/Python.framework/Versions/3.9/lib/libpython3.9.dylib
points to
chennes
Post by chennes »
I just ran into this yesterday - I had to use the GUI version of cMake to get all the variables, including all three Python variables individually, set. Plus all the Qt5 variables individually.... it was a pain, but it worked in the end.
Chris Hennes
Pioneer Library System
Gift
Post by Gift »
chennes wrote: Sat Feb 20, 2021 6:02 am I just ran into this yesterday - I had to use the GUI version of cMake to get all the variables, including all three Python variables individually, set. Plus all the Qt5 variables individually.... it was a pain, but it worked in the end.
:o If I set all export stuff like homebrew it works.
Whatever, build type stays "Build type: Release" like natural constant.
Gift
Post by Gift »
Gift wrote: Fri Feb 19, 2021 4:26 pm :evil:
Homebrews std_cmake_args include already -DCMAKE_BUILD_TYPE=Release. So I get:
cmake
-DCMAKE_C_FLAGS_RELEASE=-DNDEBUG
-DCMAKE_CXX_FLAGS_RELEASE=-DNDEBUG
-DCMAKE_INSTALL_PREFIX=/opt/homebrew/Cellar/freecad/HEAD-2704221
-DCMAKE_INSTALL_LIBDIR=lib
-DCMAKE_FIND_FRAMEWORK=LAST
-DCMAKE_VERBOSE_MAKEFILE=ON
-Wno-dev
-DCMAKE_OSX_SYSROOT=/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk
-DBUILD_QT5=ON
-DUSE_PYTHON3=1
-DPYTHON_EXECUTABLE=/opt/homebrew/opt/python3.9/bin/python3
-std=c++14
-DCMAKE_CXX_STANDARD=14
-DBUILD_ENABLE_CXX_STD:STRING=C++14
-DBUILD_FEM_NETGEN=ON
-DBUILD_FEM=ON
-DBUILD_FEM_NETGEN:BOOL=ON
-DBUILD_WEB=OFF
-DBUILD_PATH=ON
-DFREECAD_USE_EXTERNAL_KDL=ON
The first one wins. :|
Replace standard build type.
