Restarting FreeCAD over and over again
Re: Restarting FreeCAD over and over again
Postby chrisb » Mon Mar 29, 2021 6:52 am
Dimaxum wrote:
Mon Mar 29, 2021 5:05 am
I don't understand it what you say ... can you explain it clearer.
- Go to the post above
- click the pencil button at the right top of the post
- mark the terminal output (which by the way presumably is not the contents of the log file, but they are presumably almost identical)
- hit the button </> above the edit field
- hit the button Submit.
Dimaxum
Postby Dimaxum » Mon Mar 29, 2021 8:23 am
Dimaxum wrote:
Sun Mar 28, 2021 4:05 pm
This is what Terminal says ...
As I can see is that there are a view ERRORS I the report?
What they mean I don't know.
Dimaxum
Last login: Sun Mar 28 17:23:18 on ttys000
iMac:~ gebruiker$ /Applications/FreeCAD.app/Contents/MacOS/FreeCAD --write-log
# packages in environment at /Users/runner/work/FreeCAD-AppImage/FreeCAD-AppImage/conda/osx/APP/FreeCAD.app/Contents/Resources:
# Name                    Version                   Build  Channel
appdirs                   1.4.4              pyh9f0ad1d_0    conda-forge
arpack                    3.7.0                hff0ca13_2    conda-forge
blas                      2.17                   openblas    conda-forge
blinker                   1.4                        py_1    conda-forge
boost                     1.72.0           py38h89463c3_1    conda-forge
boost-cpp                 1.72.0               hd067f63_4    conda-forge
brotlipy                  0.7.0           py38h5406a74_1001    conda-forge
bzip2                     1.0.8                hc929b4f_4    conda-forge
c-ares                    1.17.1               h0d85af4_1    conda-forge
ca-certificates           2020.12.5            h033912b_0    conda-forge
cairo                     1.16.0            h4ec454a_1007    conda-forge
calculix                  2.17                 hd362bd0_2    conda-forge
certifi                   2020.12.5        py38h50d1736_1    conda-forge
cffi                      1.14.5           py38ha97d567_0    conda-forge
chardet                   4.0.0            py38h50d1736_1    conda-forge
coin3d                    4.0.0             h6a6324e_1010    conda-forge
cryptography              3.4.6            py38h1fa4640_0    conda-forge
curl                      7.75.0               h06286d4_0    conda-forge
cycler                    0.10.0                     py_2    conda-forge
decorator                 4.4.2                      py_0    conda-forge
docutils                  0.16             py38h50d1736_3    conda-forge
expat                     2.2.10               h1c7c35f_0    conda-forge
ezdxf                     0.15.2           py38h94cab2e_0    conda-forge
ffmpeg                    4.3.1                hb787a4c_2    conda-forge
flann                     1.9.1             hed988e5_1008    conda-forge
fontconfig                2.13.1            hd23ceaa_1004    conda-forge
freecad                   0.19.1           py38h3eadfbe_0    conda-forge
freecad.asm3              0.10.2            pyhf0f75e1_16    freecad/label/dev
freeimage                 3.18.0               h446b61c_7    conda-forge
freetype                  2.10.4               h4cff582_1    conda-forge
future                    0.18.2           py38h50d1736_3    conda-forge
gettext                   0.19.8.1          h7937167_1005    conda-forge
gitdb                     4.0.5              pyhd8ed1ab_1    conda-forge
gitpython                 3.1.14             pyhd8ed1ab_0    conda-forge
gmp                       6.2.1                h2e338ed_0    conda-forge
gmpy2                     2.1.0b1          py38haf64e2c_1    conda-forge
gnutls                    3.6.13               h756fd2b_1    conda-forge
graphite2                 1.3.13            h2e338ed_1001    conda-forge
harfbuzz                  2.8.0                h159f659_0    conda-forge
hdf4                      4.2.13            h71d84a9_1004    conda-forge
hdf5                      1.10.6          nompi_h34ad4e8_1111    conda-forge
icu                       68.1                 h74dc148_0    conda-forge
idna                      2.10               pyh9f0ad1d_0    conda-forge
ifcopenshell              v0.6.0           py38he2be11e_3    conda-forge
ilmbase                   2.5.5                hfab91a5_0    conda-forge
jasper                    1.900.1           h636a363_1006    conda-forge
jinja2                    2.11.3             pyh44b312d_0    conda-forge
jpeg                      9d                   hbcb3906_0    conda-forge
jsoncpp                   1.8.4             ha1b3eb9_1002    conda-forge
jxrlib                    1.1                  h35c211d_2    conda-forge
kiwisolver                1.3.1            py38hd9c93a9_1    conda-forge
krb5                      1.17.2               h60d9502_0    conda-forge
lame                      3.100             h35c211d_1001    conda-forge
lcms2                     2.12                 h577c468_0    conda-forge
libblas                   3.8.0               17_openblas    conda-forge
libcblas                  3.8.0               17_openblas    conda-forge
libclang                  11.1.0          default_he082bbe_0    conda-forge
libcurl                   7.75.0               h8ef9fac_0    conda-forge
libcxx                    11.1.0               habf9029_0    conda-forge
libedit                   3.1.20191231         h0678c8f_2    conda-forge
libev                     4.33                 haf1e3a3_1    conda-forge
libffi                    3.3                  h046ec9c_2    conda-forge
libgfortran               4.0.0           7_5_0_h1a10cd1_20    conda-forge
libgfortran4              7.5.0               h1a10cd1_20    conda-forge
libglib                   2.68.0               hd556434_1    conda-forge
libiconv                  1.16                 haf1e3a3_0    conda-forge
liblapack                 3.8.0               17_openblas    conda-forge
liblapacke                3.8.0               17_openblas    conda-forge
libllvm11                 11.1.0               hd011deb_0    conda-forge
libnetcdf                 4.7.4           nompi_h9d8a93f_107    conda-forge
libnghttp2                1.43.0               h07e645a_0    conda-forge
libopenblas               0.3.10          openmp_h63d9170_5    conda-forge
libopencv                 4.5.1            py38h3a1a88b_0    conda-forge
libpng                    1.6.37               h7cec526_2    conda-forge
libpq                     13.1                 h052a64a_2    conda-forge
libraw                    0.20.2               hefd3b78_1    conda-forge
libredwg                  0.11.3876        py38h9cb336a_0    conda-forge
libssh2                   1.9.0                h52ee1ee_6    conda-forge
libtiff                   4.2.0                h355d032_0    conda-forge
libwebp-base              1.2.0                h0d85af4_2    conda-forge
libxml2                   2.9.10               h802ca4f_3    conda-forge
libxslt                   1.1.33               h5739fc3_2    conda-forge
llvm-openmp               11.1.0               hda6cdc1_0    conda-forge
lxml                      4.6.2            py38h7d97eb6_1    conda-forge
lz4-c                     1.9.2                hb1e8313_3    conda-forge
markupsafe                1.1.1            py38h5406a74_3    conda-forge
matplotlib-base           3.3.4            py38hb24f337_0    conda-forge
meshpy                    2020.1           py38he9f00de_0    conda-forge
mpc                       1.1.0             ha57cd0f_1009    conda-forge
mpfr                      4.0.2                h72d8aaf_1    conda-forge
mpmath                    1.2.1              pyhd8ed1ab_0    conda-forge
mysql-common              8.0.23               h694c41f_1    conda-forge
mysql-libs                8.0.23               hbeb7981_1    conda-forge
ncurses                   6.2                  h2e338ed_4    conda-forge
netgen                    6.2.1808        py38h65d59e6_1007    conda-forge
nettle                    3.6                  hedd7734_0    conda-forge
nine                      1.1.0                      py_0    conda-forge
nspr                      4.30                 hcd9eead_0    conda-forge
nss                       3.47                 hc0980d9_0    conda-forge
numpy                     1.20.1           py38h64deac9_0    conda-forge
occt                      7.4.0                ha4584bc_7    conda-forge
olefile                   0.46               pyh9f0ad1d_1    conda-forge
opencamlib                2019.07          py38hb02f84c_3    conda-forge
opencv                    4.5.1            py38h50d1736_0    conda-forge
openexr                   2.5.5                h7fa7ffa_0    conda-forge
openglider                0.06               pyh9f0ad1d_0    conda-forge
openh264                  2.1.1                hfd3ada9_0    conda-forge
openjpeg                  2.4.0                h6cbf5cd_0    conda-forge
openssl                   1.1.1j               hbcf498f_0    conda-forge
pandas                    1.2.3            py38h1588c1c_0    conda-forge
parabem                   0.3.0            py38hd9c93a9_0    conda-forge
pcl                       1.11.1               h7984e4d_1    conda-forge
pcre                      8.44                 hb1e8313_0    conda-forge
pillow                    8.1.2            py38h83525de_0    conda-forge
pip                       21.0.1             pyhd8ed1ab_0    conda-forge
pivy                      0.6.6            py38h07f26b5_0    conda-forge
pixman                    0.40.0               hbcb3906_0    conda-forge
ply                       3.11                       py_1    conda-forge
py-opencv                 4.5.1            py38h9bb44b7_0    conda-forge
pycollada                 0.7.1                      py_0    conda-forge
pycparser                 2.20               pyh9f0ad1d_2    conda-forge
pyexcel-ezodf             0.3.4                      py_0    conda-forge
pyopenssl                 20.0.1             pyhd8ed1ab_0    conda-forge
pyparsing                 2.4.7              pyh9f0ad1d_0    conda-forge
pyside2                   5.13.2           py38hc6340e1_4    conda-forge
pysocks                   1.7.1            py38h50d1736_3    conda-forge
python                    3.8.8           h4e93d89_0_cpython    conda-forge
python-dateutil           2.8.1                      py_0    conda-forge
python_abi                3.8                      1_cp38    conda-forge
pythonocc-core            7.4.1            py38hd3de0cb_0    conda-forge
pytools                   2021.2             pyhd8ed1ab_0    conda-forge
pytz                      2021.1             pyhd8ed1ab_0    conda-forge
pyyaml                    5.4.1            py38h5406a74_0    conda-forge
qhull                     2020.2               h940c156_0    conda-forge
qt                        5.12.9               h126340a_4    conda-forge
qt.py                     1.2.2                      py_0    conda-forge
readline                  8.0                  h0678c8f_2    conda-forge
requests                  2.25.1             pyhd3deb0d_0    conda-forge
scipy                     1.4.1            py38h38b60c6_3    conda-forge
setuptools                49.6.0           py38h50d1736_3    conda-forge
six                       1.15.0             pyh9f0ad1d_0    conda-forge
smesh                     8.3.0.3         py38h7dac498_10    conda-forge
smmap                     3.0.5              pyh44b312d_0    conda-forge
solvespace                2.4.1            py38h281f984_0    freecad/label/dev
soqt                      1.6.0                h02c1c16_0    conda-forge
sqlite                    3.34.0               h17101e1_0    conda-forge
svgwrite                  1.4.1              pyhd8ed1ab_0    conda-forge
sympy                     1.7.1            py38h50d1736_1    conda-forge
tbb                       2020.2               h940c156_4    conda-forge
tk                        8.6.10               h0419947_1    conda-forge
tornado                   6.1              py38h5406a74_1    conda-forge
urllib3                   1.26.4             pyhd8ed1ab_0    conda-forge
vtk                       8.2.0           py38h3f69d5f_218    conda-forge
wheel                     0.36.2             pyhd3deb0d_0    conda-forge
x264                      1!161.3030           h35c211d_0    conda-forge
xerces-c                  3.2.3                hd3a8c1e_2    conda-forge
xlrd                      2.0.1              pyhd8ed1ab_3    conda-forge
xlutils                   2.0.0              pyh9f0ad1d_0    conda-forge
xlwt                      1.3.0                      py_1    conda-forge
xz                        5.2.5                haf1e3a3_1    conda-forge
yaml                      0.2.5                haf1e3a3_0    conda-forge
zlib                      1.2.11            h7795811_1010    conda-forge
zstd                      1.4.8                h62961b2_0    conda-forge
FreeCAD 0.19, Libs: 0.19R24276 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
GVA error: Not detecting IGPU in IORegistry!
GVA error: Not detecting valid offline codec!
GVA info: Successfully connected to the Intel plugin, offline Gen6
[1044:70147:0328/180326.632482:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.632547:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.634404:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.634458:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.635981:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.636018:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.636901:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.636926:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.637520:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.637543:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.638114:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.638136:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.638713:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.638736:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.639311:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.639338:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.640308:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.640361:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.641631:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.641684:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
Art connects and inspires people :idea:
Postby chrisb » Mon Mar 29, 2021 11:29 am
Variant 1: mark the text, click the button </>
Variant 2: prepend the characters "[ c o d e ]" without any spaces before the log text and the characters "[ / c o d e ]" after it.
it should look like this:
Dimaxum
Postby Dimaxum » Mon Mar 29, 2021 12:08 pm
chrisb,
I'am using Apple sinds the 80ties but I can follow you ...
I'am not a script writer and hardly or never use Terminal.
Please be a little clearer in your guidance to help me in this matter.
I really appreciated what you doing and have the patience to read an aswering my post/comments.
Dimaxum
Postby chrisb » Mon Mar 29, 2021 3:20 pm
It has nothing to do with the Mac, it is only about how you present the information here.
I sort of gave up and edited your post above. See the difference? You now can cleaarly see the indentations and it is clear where you wrote something and what parts you copied from the window.
Dimaxum
Postby Dimaxum » Mon Mar 29, 2021 3:50 pm
This takes a while to get it right.
I come to you asap ...
Thanks again for your effort.
Dimaxum
Dimaxum
Postby Dimaxum » Mon Mar 29, 2021 4:36 pm
Hope this is OKAY.
Please let me know if there are any thing I can do to?
Last login: Sun Mar 28 18:06:45 on ttys000
Appdirs 1.4.4 pyh9f0ad1d_0 conda-forge
Arpack 3.7.0 hff0ca13_2 conda-forge
Blas 2.17 openblas conda-forge
Blinker 1.4 py_1 conda-forge
Boost 1.72.0 py38h89463c3_1 conda-forge
[2461:70403:0329/173055.153285:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.153349:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.155091:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.155129:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.156517:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.156570:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.157514:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.157540:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.158159:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.158182:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.158752:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.158777:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.159349:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.159373:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.159944:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.159966:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.160710:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.160756:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[2461:70403:0329/173055.161929:ERROR:gl_context_cgl.cc(136)] Error creating context.
[2461:70403:0329/173055.161987:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
iMac:~ gebruiker$
Reason: put output in code tags
Postby Kunda1 » Mon Mar 29, 2021 4:54 pm
Mod edit: I added the code tags
Dimaxum
Postby Dimaxum » Tue Mar 30, 2021 5:17 am
Thanks Kunda1 for adding the code tags.
Kind regards,
Dimaxum
Postby Kunda1 » Tue Mar 30, 2021 10:42 am
I've not installed conda and not running macOS but it's weird to see all that conda output before the FC welcome message. The errors look opengl/graphic card related but I'm not sure what. Cursory web search advises to add --ignore-gpu-blacklist as a flag
What happens if you do that?
