Restarting FreeCAD over and over again
Dimaxum
Re: Restarting FreeCAD over and over again
Post by Dimaxum »
Hi Kunda1,
Where do I add --ignore-gpu-blacklist as a flag?
Can you lead me to the right direction ... thanks.
Also is this including the -- 2 dashes?
Dimaxum
Art connects and inspires people :idea:
Dimaxum
Post by Dimaxum »
Kunda1 wrote: Tue Mar 30, 2021 10:42 am I've not installed conda and not running macOS but it's weird to see all that conda output before the FC welcome message. The errors look opengl/graphic card related but I'm not sure what. Cursory web search advises to add --ignore-gpu-blacklist as a flag
What happens if you do that?
Sorry for asking you, but did you give it up on me? I still have the same problem.
Please can you lead me to the direction where I have to put the command --ignore-gpu-blacklist
And can you tell me what happens when I do so?
Thank you for your effort and time.
Kind regards, Dimaxum
Post by Kunda1 »
Dimaxum wrote: Sun Apr 04, 2021 3:32 pm Sorry for asking you, but did you give it up on me? I still have the same problem.
Sorry about that. I'm not on macOS
My superficial proposed solution may not apply to FreeCAD. So I'm not sure.
I forget if you mentioned but have you tried the weekly-build .dmg to reproduce the issue?
https://github.com/FreeCAD/FreeCAD-AppI ... kly-builds
Dimaxum
Post by Dimaxum »
Kunda1 wrote: Sun Apr 04, 2021 4:22 pm
Hi Kunda1,
No I didn't ... I will download it later and try it. I will let you know.
By the way, is there a section on FC forum for Mac users where I can discuss this matter?
Dimaxum
looo
Post by looo »
Dimaxum wrote: Mon Apr 05, 2021 5:41 am
Hi Kunda1,
Dimaxum
Maybe this issue is related to the QT_MAC_WANTS_LAYER change we introduced to support bigsur. We recently pushed a change to not set this variable for systems not updated to bigsur. Maybe this already solves the issue. But it is only a guess.
The latest weekly build definitely has the fix included. So please report back if it works.
Dimaxum
Post by Dimaxum »
looo wrote: Mon Apr 05, 2021 7:17 am
Hi Kunda1,
Dimaxum
Hi there Lorenz,
What must I download ...?
Is it the DMG file or the source code ...?
Please let me know, thank you.
Dimaxum
Dimaxum wrote: Mon Apr 05, 2021 4:12 pm What must I download ...?
It should be sufficient to replace the contents of /path_to_FreeCAD/FreeCAD.app/Contents/MacOS/FreeCAD
with this:
#!/usr/bin/env bash
HERE=$(dirname "$(dirname "$0")")
cat ${HERE}/packages.txt
export PREFIX=${HERE}/Resources
export LD_LIBRARY_PATH=${PREFIX}/lib
export PYTHONHOME=${PREFIX}
# export QT_QPA_PLATFORM_PLUGIN_PATH=${PREFIX}/plugins
# export QT_XKB_CONFIG_ROOT=${PREFIX}/lib
export FONTCONFIG_FILE=/etc/fonts/fonts.conf
export FONTCONFIG_PATH=/etc/fonts
export LANG="UTF-8"  # https://forum.freecadweb.org/viewtopic.php?f=22&t=42644
export SSL_CERT_FILE=${PREFIX}/ssl/cacert.pem # https://forum.freecadweb.org/viewtopic.php?f=3&t=42825
export GIT_SSL_CAINFO=${PREFIX}/ssl/cacert.pem
if [[ `sw_vers -productVersion` > 10.99 ]] ; then
  export QT_MAC_WANTS_LAYER=1
fi
"${PREFIX}/bin/freecad" $@
or remove in your file the line
Dimaxum
Post by Dimaxum »
chrisb wrote: Mon Apr 05, 2021 5:34 pm
with this:
#!/usr/bin/env bash
fi
Hi Chrisb,
I think it worked ... I will do a view test and let you know if it is and stays stable ...
Thank you in frond for your patience and effort.
Dimaxum
Dimaxum
Post by Dimaxum »
with this:
#!/usr/bin/env bash
fi
Hi chrisb,
I deleted this line "export QT_MAC_WANTS_LAYER=1" and it worked.
Everything is stable now as it supposed to be.
Thanks again.
Where do I select this tread as "SOLVED"?
Dimaxum
You can edit the first post and prepend "[Solved]" to the subject.
