0.20 builds fail in freecad-daily PPA
Olav
Post by Olav »
I hope that whoever is in charge of the freecad-daily PPA is aware that the daily builds of FreeCAD 0.20 are failing for Ubuntu 16.04, 20.4 and 20.10? If so, I'll just wait until it's resolved. Otherwise perhaps someone should take a look.
The build for 18.04 seems to be working perfectly (and I use that on my main computer).
https://launchpad.net/~freecad-maintain ... /+packages
Founder
Re: 0.20 builds fail in freecad-daily PPA
Post by wmayer »
The build logs of the failures can be found here:
https://launchpad.net/~freecad-maintain ... d/21189320
https://launchpad.net/~freecad-maintain ... d/21189160
https://launchpad.net/~freecad-maintain ... d/21188894
debian/rules:39: recipe for target 'override_dh_auto_configure' failed
make[1]: *** [override_dh_auto_configure] Error 255
make[1]: Leaving directory '/<<PKGBUILDDIR>>'
debian/rules:3: recipe for target 'build' failed
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
In line 39 of https://git.launchpad.net/freecad/tree/debian/rules
override_dh_auto_configure:
	dh_auto_configure --builddirectory=debian/build-py3 -- \
	    $(extra_flags) \
	    $(py3_flags)
So, it apparently already fails when running the rules file and I guess that something must have changed with the packaging commands in newer Debian/Ubuntu versions.
mfraz74
Post by mfraz74 »
0.19 is building ok for 21.04 so is there anything different between these rules?
sgrogan
Post by sgrogan »
wmayer wrote: Thu Apr 08, 2021 2:39 pm debian/rules:39: recipe for target 'override_dh_auto_configure' failed
I think this is specific to the Xenial failure and is due to
CMake Error at CMakeLists.txt:2 (cmake_minimum_required):
CMake 3.10.2 or higher is required. You are running version 3.5.1
-- Configuring incomplete, errors occurred!
"tail -v -n +0 CMakeCache.txt"
==> CMakeCache.txt <==
wmayer wrote: Thu Apr 08, 2021 2:39 pm In line 39 of https://git.launchpad.net/freecad/tree/debian/rules
I don't think this is used anymore. I think the used rules file is from here: https://salsa.debian.org/science-team/f ... bian/rules
See the recipe contents at the end of here: https://code.launchpad.net/~freecad-mai ... ngle-build
I think the relevant part of the Focal log is
-- The imported target "vtkParseOGLExt" references the file
   "/usr/bin/vtkParseOGLExt-7.1"
but this file does not exist.  Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
   "/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkRenderingPythonTkWidgets" references the file
   "/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
   "/usr/bin/vtk"
-- The imported target "pvtk" references the file
   "/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/include
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- We guess that libmed was built using hdf5-openmpi version
-- Checking for one of the modules 'hdf5-openmpi'
-- Checking for one of the modules 'ompi-cxx'
-- Found SWIG: /usr/bin/swig4.0 (found version "4.0.1")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.7", minimum required is "2.91.0")
-- Performing Test _flag_found
-- Performing Test _flag_found - Success
-- Found Freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so (found version "2.10.1")
-- Checking for module 'Coin'
--   No package 'Coin' found
-- Coin3D libraries found
ModuleNotFoundError: No module named 'pivy'
-- Found Spnav: /usr/lib/libspnav.so
-- Shiboken2Config: Using default python: .cpython-38-x86_64-linux-gnu
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.5", minimum required is "3")
CMake Error at /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146 (message):
  Could NOT find PythonLibs (missing: PYTHON_INCLUDE_DIRS) (Required is at
  least version "3")
  /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake-3.16/Modules/FindPythonLibs.cmake:310 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.14.0/shiboken_helpers.cmake:318 (find_package)
  /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.14.0/Shiboken2Config.cpython-38-x86_64-linux-gnu.cmake:44 (shiboken_find_required_python)
  /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.14.0/Shiboken2Config.cmake:5 (include)
  cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:13 (find_package)
  CMakeLists.txt:75 (SetupShibokenAndPyside)
See also "/<<PKGBUILDDIR>>/debian/build-py3/CMakeFiles/CMakeOutput.log".
See also "/<<PKGBUILDDIR>>/debian/build-py3/CMakeFiles/CMakeError.log".
	cd debian/build-py3 && tail -v -n \+0 CMakeCache.txt
"fight the good fight"
Olav
Post by Olav »
Any progress on this? I still can't install FC 0.20 on Xubuntu 20.04 from the PPA.
Olav
Post by Olav »
Same question as before.
Is there something I can do? I'm afraid I know next to nothing about packaging. But I would be willing to test stuff out if that's helpful.
galou_breizh
Post by galou_breizh »
It looks that there is also an issue with pthreads on Ubuntu 20.04.
/usr/bin/ld: cannot find -lpthreads
Gaël
mfraz74
Post by mfraz74 »
Builds for 21.10 & 22.04 seem have been failing for a while, the last available version for 21.10 is 0.20~pre1~202109030345 and for 22.04 it is 0.20~pre1~202111101813.
Is it possible to get this fixed?
openBrain
Post by openBrain »
Bumping this thread because 21.10 & 22.04 were stuck since October 11, and now 21.04 is stuck also since January 26.
Is there some work ongoing ? Something to help ?
kkremitzki
Post by kkremitzki »
I had lost track of the issue but they should be fixed now.
