I did a pull this morning of the master branch, at:
cc0af9b4dde98121b1476fe98ab2392d953b9a46 (8 Apr 2021 12:29)
55>D:\work\libpack\FreeCADLibs_12.5.2_x64_VC17\include\boost/python/detail/unwind_type.hpp(37): error C3861: 'unwind_type': identifier not found
5>QuantityParser.c(1568,35): error C2664: 'void Quantity_yyerror(char *)': cannot convert argument 1 from 'const char [13]' to 'char *'
5>QuantityParser.c(1568,16): message : Conversion from string literal loses const qualifier (see /Zc:strictStrings)
61>D:\work\libpack\FreeCADLibs_12.5.2_x64_VC17\include\boost\polygon\voronoi_builder.hpp(160,18): error C7626: unnamed class used in typedef name cannot declare members other than non-static data members, member enumerations, or member classes (compiling source file D:\work\github\FreeCAD\src\3rdParty\salomesmesh\src\StdMeshers\SMESH_MAT2d.cpp)
68>D:\work\github\FreeCAD\src\Mod\Mesh\App\WildMagic4\Wm4TRational.inl(696,1): error C2446: '<=': no conversion from 'int' to 'unsigned int *'
68>D:\work\github\FreeCAD\src\Mod\Mesh\App\WildMagic4\Wm4TRational.inl(656,26): message : Conversion from integral type to pointer type requires reinterpret_cast, C-style cast or function-style cast
67>D:\work\libpack\FreeCADLibs_12.5.2_x64_VC17\include\eigen3\Eigen\src/Core/util/Meta.h(454,25): error C2039: 'result_of': is not a member of 'std'
67>D:\work\github\FreeCAD\src\App/ObjectIdentifier.h(463): message : see declaration of 'std'
Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19042.
The C compiler identification is MSVC 19.28.29913.0
The CXX compiler identification is MSVC 19.28.29913.0
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.28.29910/bin/Hostx64/x64/cl.exe - skipped
Detecting C compile features
Detecting C compile features - done
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.28.29910/bin/Hostx64/x64/cl.exe - skipped
Detecting CXX compile features
Detecting CXX compile features - done
Compiler: MSVC, version: 19.28.29913.0
prefix: C:/Program Files (x86)/FreeCAD
bindir: bin
datadir: data
docdir: doc
includedir: include
libdir: lib
cmake: 3.18.0-rc3
PyCXX found:
Headers: D:/work/github/FreeCAD/src
Sources: D:/work/github/FreeCAD/src/CXX
Version: 6.2.8
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Doxygen not found, will not build documentation.
PyCXX found:
Version: 6.2.8
CMake Warning (dev) at C:/Program Files/CMake/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:273 (message):
The package name passed to `find_package_handle_standard_args` (OCC) does
not match the name of the calling package (OpenCasCade). This can lead to
problems in calling code that expects `find_package` result variables
(e.g., `_FOUND`) to follow a certain pattern.
cMake/FindOpenCasCade.cmake:120 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
cMake/FreeCAD_Helpers/SetupOpenCasCade.cmake:4 (find_package)
CMakeLists.txt:51 (SetupOpenCasCade)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found OCE/OpenCASCADE version: 7.5.0
-- OCE/OpenCASCADE include directory: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/inc
-- OCE/OpenCASCADE shared libraries directory: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib
HUHUH: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/cmake/vtk-8.2/VTKTargets.cmake
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Check for medfile (libmed and libmedc) ...
Found Boost: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include (found suitable version "1.67.0", minimum required is "1.55") found components: filesystem program_options regex system thread chrono date_time atomic
Found Netgen: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/cmake
Found NETGEN version 6.2, calculated: 395734
Coin3D libraries found
Shiboken2Config: Using default python: .cp38-win_amd64
SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: 'D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/include'
SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
libshiboken built for Release
PySide2 Python module found at D:\work\libpack\FreeCADLibs_12.5.2_x64_VC17\bin\lib\site-packages\PySide2.
Found Matplotlib: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/lib/site-packages/matplotlib (found version "3.3.3")
Platform is 64-bit, set -D_OCC64
D:/work/github/FreeCAD/build/src/Base/TypePy.cpp
D:/work/github/FreeCAD/build/src/Base/BaseClassPy.cpp
D:/work/github/FreeCAD/build/src/Base/BoundBoxPy.cpp
D:/work/github/FreeCAD/build/src/Base/CoordinateSystemPy.cpp
D:/work/github/FreeCAD/build/src/Base/PersistencePy.cpp
D:/work/github/FreeCAD/build/src/Base/VectorPy.cpp
D:/work/github/FreeCAD/build/src/Base/MatrixPy.cpp
D:/work/github/FreeCAD/build/src/Base/RotationPy.cpp
D:/work/github/FreeCAD/build/src/Base/PlacementPy.cpp
D:/work/github/FreeCAD/build/src/Base/AxisPy.cpp
D:/work/github/FreeCAD/build/src/Base/UnitPy.cpp
D:/work/github/FreeCAD/build/src/Base/QuantityPy.cpp
D:/work/github/FreeCAD/build/src/App/DocumentPy.cpp
D:/work/github/FreeCAD/build/src/App/DocumentObjectPy.cpp
D:/work/github/FreeCAD/build/src/App/ExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/ExtensionContainerPy.cpp
D:/work/github/FreeCAD/build/src/App/DocumentObjectExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/GroupExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/LinkBaseExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/DocumentObjectGroupPy.cpp
D:/work/github/FreeCAD/build/src/App/GeoFeaturePy.cpp
D:/work/github/FreeCAD/build/src/App/GeoFeatureGroupExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/OriginGroupExtensionPy.cpp
D:/work/github/FreeCAD/build/src/App/PartPy.cpp
D:/work/github/FreeCAD/build/src/App/ComplexGeoDataPy.cpp
D:/work/github/FreeCAD/build/src/App/PropertyContainerPy.cpp
D:/work/github/FreeCAD/build/src/App/MaterialPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Points/App/PointsPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Mesh/App/FacetPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Mesh/App/MeshFeaturePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Mesh/App/MeshPointPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Mesh/App/MeshPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcOfConicPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcOfCirclePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcOfParabolaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BodyBasePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ConicPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/CirclePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcOfEllipsePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/EllipsePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/HyperbolaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ParabolaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/OffsetCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryIntExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryStringExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryBoolExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryDoubleExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometryCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BoundedCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TrimmedCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeometrySurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/LinePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/LineSegmentPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/PointPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BezierCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BSplineCurvePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/PlanePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ConePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/CylinderPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/SpherePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ToroidPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BezierSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BSplineSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/OffsetSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/PlateSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/PartFeaturePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/AttachExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Part2DObjectPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/AttachEnginePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeEdgePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeFacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeShellPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeSolidPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeVertexPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/TopoShapeWirePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BRepOffsetAPI_MakeFillingPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/BRepFeat/MakePrismPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeomPlate/BuildPlateSurfacePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeomPlate/CurveConstraintPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/GeomPlate/PointConstraintPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Part/App/ShapeUpgrade/UnifySameDomainPy.cpp
D:/work/github/FreeCAD/build/src/Mod/PartDesign/App/BodyPy.cpp
D:/work/github/FreeCAD/build/src/Mod/PartDesign/App/FeaturePy.cpp
D:/work/github/FreeCAD/build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/SketchObjectPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/SketchGeometryExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/ExternalGeometryExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/GeometryFacadePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/ExternalGeometryFacadePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/ConstraintPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Sketcher/App/SketchPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Robot/App/Robot6AxisPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Robot/App/TrajectoryPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Robot/App/WaypointPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Robot/App/RobotObjectPy.cpp
Performing Test _flag_found
Performing Test _flag_found - Failed
D:/work/github/FreeCAD/build/src/Mod/Import/App/StepShapePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Fem/App/FemMeshPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Fem/App/FemPostPipelinePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Spreadsheet/App/SheetPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/CommandPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/PathPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/ToolPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/TooltablePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/AreaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/FeatureAreaPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/VoronoiPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/VoronoiCellPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/VoronoiEdgePy.cpp
D:/work/github/FreeCAD/build/src/Mod/Path/App/VoronoiVertexPy.cpp
Found Boost: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include (found version "1.67.0") found components: python38
found Boost: 1_67
boost-incude dirs are: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include
boost-python lib is:
boost_LIBRARY_DIRS is: D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib
Boost_LIBRARIES is: optimizedD:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/boost_python38-vc141-mt-x64-1_67.libdebugD:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/boost_python38-vc141-mt-gd-x64-1_67.lib
area module (for Path Workbench) will be installed to: lib
D:/work/github/FreeCAD/build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
D:/work/github/FreeCAD/build/src/Mod/Measure/App/MeasurementPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawPagePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewDimExtentPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawHatchPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawLeaderLinePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawRichAnnoPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/GeomFormatPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/CenterLinePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/CosmeticEdgePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/CosmeticVertexPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawTilePy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawTileWeldPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/DrawWeldSymbolPy.cpp
D:/work/github/FreeCAD/build/src/Mod/TechDraw/App/CosmeticExtensionPy.cpp
Created file D:/work/github/FreeCAD/build/doc/freecad.qch
D:/work/github/FreeCAD/build/src/Gui/DocumentPy.cpp
D:/work/github/FreeCAD/build/src/Gui/PythonWorkbenchPy.cpp
D:/work/github/FreeCAD/build/src/Gui/ViewProviderPy.cpp
D:/work/github/FreeCAD/build/src/Gui/ViewProviderDocumentObjectPy.cpp
D:/work/github/FreeCAD/build/src/Gui/ViewProviderExtensionPy.cpp
D:/work/github/FreeCAD/build/src/Gui/WorkbenchPy.cpp
D:/work/github/FreeCAD/build/src/Gui/SelectionObjectPy.cpp
D:/work/github/FreeCAD/build/src/Gui/LinkViewPy.cpp
D:/work/github/FreeCAD/build/src/Gui/ViewProviderLinkPy.cpp
D:/work/github/FreeCAD/build/src/Gui/AxisOriginPy.cpp
D:/work/github/FreeCAD/build/src/Gui/CommandPy.cpp
Summary report
Compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.28.29910/bin/Hostx64/x64/cl.exe (19.28.29913.0)
Flags: /DWIN32 /D_WINDOWS /W3 /GR /EHsc
Standard: Requires C++20
Python: 3.8.6 [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/python.exe] [.cp38-win_amd64]
PCL: not enabled
pybind11: not enabled
Boost: 1.67.0 (106700)
XercesC: 3.2.2 [optimized;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/xerces-c_3.lib;debug;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/xerces-c_3D.lib] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include]
ZLIB: 1.2.11
PyCXX: 6.2.8 [D:/work/github/FreeCAD/src]
OCC: 7.5.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/inc]
SMESH: build internal
MEDFile: 4.0.0 [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/medC.lib] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include]
HDF5:
VTK: 8.2.0
NETGEN: 6.2.2006 (6.2.2006-19-gb37a3e6c) [-DNO_PARALLEL_THREADS;-DOCCGEOMETRY;-DNETGEN_VERSION=395734] [] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include/include;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include] [nglib] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include/include;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include]
SWIG: 4.0.2
Eigen3 3.3.90
Qt5Core: 5.15.1
Qt5Network: 5.15.1
Qt5Xml: 5.15.1
Qt5XmlPatterns: 5.15.1
Qt5Widgets: 5.15.1
Qt5PrintSupport: 5.15.1
Qt5OpenGL: 5.15.1
Qt5Svg: 5.15.1
Qt5UiTools: 5.15.1
Qt5Concurrent: 5.15.1
Qt5WebEngineWidgets: 5.15.1
Qt5WinExtras: 5.15.1
Shiboken2: 5.15.0 [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/cmake/Shiboken2-5.15.0] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include/shiboken2;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/include]
PySide2: 5.15.0 [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include/PySide2]
PySide2Tools: [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/uic.exe] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/bin/rcc.exe]
Freetype: 2.10.1
OpenGL: opengl32
OpenGLU: [glu32][]
Coin3D: 4.0.1 [optimized;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/Coin4.lib;debug;D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/lib/Coin4d.lib] [D:/work/libpack/FreeCADLibs_12.5.2_x64_VC17/include]
Pivy: 0.6.6
Matplotlib: 3.3.3
Rift: not enabled (BUILD_VR)
Doxygen: not found
Copying libpack dependency directories to build directory for Windows MSVC build.
... end copying.
Copying libpack 'bin' directory to build directory.
... done copying libpack 'bin' directory.
Copying plugins to build directory.
Created install commands for INSTALL target.
Now run 'cmake --build D:/work/github/FreeCAD/build' to build FreeCAD
Configuring done
Generating done
Thanks,
Dan
