If first prints the splash loader image, but then gets killed immediately.
Here is the
freecad --write-log
Msg: FreeCAD 0.19, Libs: 0.19R24291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Log: Time = Fri Apr 30 10:46:15 2021
Log: AppDataSkipVendor = true
Log: AppHomePath = /usr/lib/freecad/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /usr/lib/freecad/bin/
Log: BuildRepositoryURL = /startdir/FreeCAD
Log: BuildRevision = 24291 (Git)
Log: BuildRevisionBranch = makepkg
Log: BuildRevisionDate = 2021/04/15 09:17:08
Log: BuildRevisionHash = 7b5e18a0759de778b74d3a5c17eba9cb815035ac
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: CSF_IGESDefaults = /usr/share/opencascade/resources/XSTEPResource
Log: CSF_LANGUAGE = us
Log: CSF_MDTVTexturesDirectory = /usr/share/opencascade/resources/Textures
Log: CSF_PluginDefaults = /usr/share/opencascade/resources/StdResource
Log: CSF_SHMessage = /usr/share/opencascade/resources/SHMessage
Log: CSF_STEPDefaults = /usr/share/opencascade/resources/XSTEPResource
Log: CSF_StandardDefaults = /usr/share/opencascade/resources/StdResource
Log: CSF_XCAFDefaults = /usr/share/opencascade/resources/StdResource
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
Log: Debug = 0
Log: DocPath = /usr/lib/freecad/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: LoggingFile = 1
Log: LoggingFileName = /home/greg/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = /usr/NX/bin /home/greg/micropython:/home/greg/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/opt/cuda/bin:/opt/cuda/nsight_compute:/opt/cuda/nsight_systems/bin:/home/greg/.dotnet/tools:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
Log: PYTHONPATH =
Log: PythonSearchPath = /usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/greg/.FreeCAD/system.cfg
Log: UserAppData = /home/greg/.FreeCAD/
Log: UserHomePath = /home/greg
Log: UserParameter = /home/greg/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing /usr/lib/freecad/Mod/Part... done
Log: Init: Initializing /usr/lib/freecad/Mod/Image... done
Log: Init: Initializing /usr/lib/freecad/Mod/PartDesign... done
Log: Init: Initializing /usr/lib/freecad/Mod/Points... done
Log: Init: Initializing /usr/lib/freecad/Mod/Fem... done
Log: Init: Initializing /usr/lib/freecad/Mod/Path... done
Log: Init: Initializing /usr/lib/freecad/Mod/Idf... done
Log: Init: Initializing /usr/lib/freecad/Mod/TechDraw... done
Log: Init: Initializing /usr/lib/freecad/Mod/Draft... done
Log: Init: Initializing /usr/lib/freecad/Mod/MeshPart... done
Log: Init: Initializing /usr/lib/freecad/Mod/Material... done
Log: Init: Initializing /usr/lib/freecad/Mod/Raytracing... done
Log: Init: Initializing /usr/lib/freecad/Mod/Mesh... done
Log: Init: Initializing /usr/lib/freecad/Mod/Show(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Tux(Init.py not found)... ignore
Log: Init: Initializing /usr/lib/freecad/Mod/Robot... done
Log: Init: Initializing /usr/lib/freecad/Mod/Measure... done
Log: Init: Initializing /usr/lib/freecad/Mod/Sketcher... done
Log: Init: Initializing /usr/lib/freecad/Mod/Web... done
Log: Drawing became obsolete in 0.17; consider using TechDraw instead.
Log: Init: Initializing /usr/lib/freecad/Mod/Drawing... done
Log: Init: Initializing /usr/lib/freecad/Mod/Spreadsheet... done
Log: Init: Initializing /usr/lib/freecad/Mod/Import... done
Log: Init: Initializing /usr/lib/freecad/Mod/Test... done
Log: Init: Initializing /usr/lib/freecad/Mod/Surface... done
Log: Init: Initializing /usr/lib/freecad/Mod/ReverseEngineering... done
Log: Init: Initializing /usr/lib/freecad/Mod/Arch... done
Log: Init: Initializing /usr/lib/freecad/Mod/Start... done
Log: Init: Initializing /usr/lib/freecad/Mod/AddonManager... done
Log: Init: Initializing /usr/lib/freecad/Mod/Inspection... done
Log: Init: Initializing /usr/lib/freecad/Mod/OpenSCAD... done
Log: Using /usr/lib/freecad/Mod as module path!
Log: System path after init:
Log: /usr/lib/freecad/bin
Log: /usr/lib/freecad/Mod/Part
Log: /usr/lib/freecad/Mod/Image
Log: /usr/lib/freecad/Mod/PartDesign
Log: /usr/lib/freecad/Mod/Points
Log: /usr/lib/freecad/Mod/Fem
Log: /usr/lib/freecad/Mod/Path
Log: /usr/lib/freecad/Mod/Idf
Log: /usr/lib/freecad/Mod/TechDraw
Log: /usr/lib/freecad/Mod/Draft
Log: /usr/lib/freecad/Mod/MeshPart
Log: /usr/lib/freecad/Mod/Material
Log: /usr/lib/freecad/Mod/Raytracing
Log: /usr/lib/freecad/Mod/Show
Log: /usr/lib/freecad/Mod/Tux
Log: /usr/lib/freecad/Mod/Robot
Log: /usr/lib/freecad/Mod/Measure
Log: /usr/lib/freecad/Mod/Sketcher
Log: /usr/lib/freecad/Mod/Web
Log: /usr/lib/freecad/Mod/Drawing
Log: /usr/lib/freecad/Mod/Spreadsheet
Log: /usr/lib/freecad/Mod/Import
Log: /usr/lib/freecad/Mod/Test
Log: /usr/lib/freecad/Mod/Surface
Log: /usr/lib/freecad/Mod/ReverseEngineering
Log: /usr/lib/freecad/Mod/Arch
Log: /usr/lib/freecad/Mod/Start
Log: /usr/lib/freecad/Mod/AddonManager
Log: /usr/lib/freecad/Mod/Inspection
Log: /usr/lib/freecad/Mod/OpenSCAD
Log: /usr/NX/bin /home/greg/micropython
Log: /home/greg/.local/bin
Log: /usr/local/bin
Log: /usr/bin
Log: /bin
Log: /usr/local/sbin
Log: /opt/cuda/bin
Log: /opt/cuda/nsight_compute
Log: /opt/cuda/nsight_systems/bin
Log: /home/greg/.dotnet/tools
Log: /usr/lib/jvm/default/bin
Log: /usr/bin/site_perl
Log: /usr/bin/vendor_perl
Log: /usr/bin/core_perl
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: could not connect to display localhost:0.0
Log: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Log: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
