I compiled the git version today completely new and it still doesn't work.
I am using Arch linux with the latest updates.
Hardware is a Matebook X with a intel core i5-7200, 8gb ram
Information about my graphic card:
sudo lspci -vnn | grep VGA -A 12
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 620 [8086:5916] (rev 02) (prog-if 00 [VGA controller])
Subsystem: Huawei Technologies Co., Ltd. Device [19e5:3e02]
Flags: bus master, fast devsel, latency 0, IRQ 132
Memory at a0000000 (64-bit, non-prefetchable) [size=16M]
Memory at 90000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
./FreeCAD_0.19-24291-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.19, Libs: 0.19R24291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
libGL error: MESA-LOADER: failed to open iris: /tmp/.mount_FreeCA0OWWup/usr/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: /tmp/.mount_FreeCA0OWWup/usr/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/dri)
Any help is apreciated.
