Attempting to build on newly installed Debian 10.9.
Can someone enlighten me on the following result?
-- Found Python3: /usr/local/bin/python3.7 (found version "3.7.3") found components: Interpreter Development
CMake Error at /usr/share/cmake-3.13/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Failed to find XercesC (missing: XercesC_LIBRARY XercesC_INCLUDE_DIR
XercesC_VERSION)
Call Stack (most recent call first):
/usr/share/cmake-3.13/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake-3.13/Modules/FindXercesC.cmake:98 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
cMake/FreeCAD_Helpers/SetupXercesC.cmake:4 (find_package)
CMakeLists.txt:48 (SetupXercesC)
-- Configuring incomplete, errors occurred!
See also "/home/mac/freecad-build/CMakeFiles/CMakeOutput.log".
See also "/home/mac/freecad-build/CMakeFiles/CMakeError.log".
make: *** No targets specified and no makefile found. Stop.
Determining if the include file GL/gl.h exists failed with the following output:
Change Dir: /home/mac/freecad-build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTC_fa0d0/fast"
/usr/bin/make -f CMakeFiles/cmTC_fa0d0.dir/build.make CMakeFiles/cmTC_fa0d0.dir/build
make[1]: Entering directory '/home/mac/freecad-build/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_fa0d0.dir/CheckIncludeFile.c.o
/usr/bin/cc -o CMakeFiles/cmTC_fa0d0.dir/CheckIncludeFile.c.o -c /home/mac/freecad-build/CMakeFiles/CMakeTm
p/CheckIncludeFile.c
/home/mac/freecad-build/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:10: fatal error: GL/gl.h: No such file or direc
tory
#include <GL/gl.h>
compilation terminated.
make[1]: *** [CMakeFiles/cmTC_fa0d0.dir/build.make:66: CMakeFiles/cmTC_fa0d0.dir/CheckIncludeFile.c.o] Error 1
make[1]: Leaving directory '/home/mac/freecad-build/CMakeFiles/CMakeTmp'
make: *** [Makefile:121: cmTC_fa0d0/fast] Error 2
Run Build Command:"/usr/bin/make" "cmTC_81e3a/fast"
/usr/bin/make -f CMakeFiles/cmTC_81e3a.dir/build.make CMakeFiles/cmTC_81e3a.dir/build
Building C object CMakeFiles/cmTC_81e3a.dir/CheckIncludeFile.c.o
/usr/bin/cc -o CMakeFiles/cmTC_81e3a.dir/CheckIncludeFile.c.o -c /home/mac/freecad-build/CMakeFiles/CMakeTm
tory
#include <GL/gl.h>
make[1]: *** [CMakeFiles/cmTC_81e3a.dir/build.make:66: CMakeFiles/cmTC_81e3a.dir/CheckIncludeFile.c.o] Error 1
make: *** [Makefile:121: cmTC_81e3a/fast] Error 2
