Installing FreeCAD on a Linux Server
veigh
Post by veigh »
Hi everyone!
I have tried to install FreeCAD (AppImage version) on my computer (Debian 10) and I have recorded a simple macro to convert a .step file to .stl
import FreeCAD
import Import
import Mesh
Import.open(u"abc/part.STEP")
__objs__=[]
__objs__.append(FreeCAD.getDocument("Unnamed").getObject("Solid"))
Mesh.export(__objs__,u"abc/Parte1.stl")
del __objs__
exit()
Then I have created a Bash script to run it:
#!/bin/bash
./freecad.AppImage test.FCMacro
It works very well!
Now, I'd like to run FreeCAD on a Linux Server (Aruba server). I have tried to upload freecad.AppImage and the bash script to the cgi-bin directory and run the script with a .php file, but it doesn't work (of course!)
Do you have any idea how could I run it? Maybe Should I not use the AppImage version?
I thank you
Re: Installing FreeCAD on a Linux Server
Did you set the right permissions?
veigh
Post by veigh »
Yes, permissions setted on 755
From the log I read:
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: dlopen(): error loading libfuse.so.2:
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: : /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: AppImages require FUSE to run. : /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: You might still be able to extract the contents of this AppImage : /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: if you run it with the --appimage-extract option. : /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: See https://github.com/AppImage/AppImageKit/wiki/FUSE : /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
23/06/2021 18:31:16	[error] [client 5.171.105.144] - AH01215: for more information: /web/htdocs/www.mydomain.it/home/cgi-bin/test/test.php
adrianinsaval
Post by adrianinsaval »
do you have FUSE in your server? See: https://docs.appimage.org/user-guide/tr ... /fuse.html
veigh
Post by veigh »
I solved using a AWS server and installing Debian. It works well :D
