Debian source package for Calculix
cblt2l
Re: Debian source package for Calculix
Postby cblt2l » Wed May 28, 2014 2:59 am
MarcoP,
Without seeing the complete log from dpkg-buildpackage I can't say for sure what the problem is, but I'm guessing it might be a dependency related issue. Make sure that you install the packages libspooles-dev libarpack2-dev gfortran from the 'universe' repository along with 'build-essential' and 'debhelper' which is what Norm was referring to. I ran a test using an Ubuntu precise amd64 chroot and was able to build it successfully. The package is here if you want to use it. Keep in mind that its for the amd64 architecture.
bernd
Postby bernd » Sun Oct 12, 2014 11:00 am
Tried on Debian Jessie and get an error at buildpackage. All the packages mentioned in the first post are installed.
a - strsplt.o
a - tau.o
a - tiedcontact.o
a - u_calloc.o
a - v_betrag.o
a - v_prod.o
a - v_result.o
a - writeBasisParameter.o
make[1]: *** No rule to make target '-larpack', needed by 'ccx_2.7'.  Schluss.
make[1]: Leaving directory '/home/hugo/Documents/projekte--ifc/calculix/ccx-2.7'
dh_auto_build: make -j1 returned exit code 2
debian/rules:13: recipe for target 'build' failed
make: *** [build] Error 2
dpkg-buildpackage: Fehler: Fehler-Exitstatus von debian/rules build war 2
but libarpack is installed. Where is the compiler looking for libarpack?
locate libarpack
/usr/lib/libarpack.a
/usr/lib/libarpack.so
/usr/lib/libarpack.so.2
/usr/lib/libarpack.so.2.0.0
/usr/share/doc/libarpack2
/usr/share/doc/libarpack2-dev
/usr/share/doc/libarpack2/changelog.Debian.gz
/usr/share/doc/libarpack2/changelog.gz
/usr/share/doc/libarpack2/copyright
/usr/share/doc/libarpack2-dev/README
/usr/share/doc/libarpack2-dev/changelog.Debian.gz
/usr/share/doc/libarpack2-dev/changelog.gz
/usr/share/doc/libarpack2-dev/copyright
/usr/share/doc/libarpack2-dev/debug.doc.gz
/usr/share/doc/libarpack2-dev/ex-complex.doc.gz
/usr/share/doc/libarpack2-dev/ex-nonsym.doc.gz
/usr/share/doc/libarpack2-dev/ex-sym.doc.gz
/usr/share/doc/libarpack2-dev/stat.doc
/var/lib/dpkg/info/libarpack2-dev.list
/var/lib/dpkg/info/libarpack2-dev.md5sums
/var/lib/dpkg/info/libarpack2.list
/var/lib/dpkg/info/libarpack2.md5sums
/var/lib/dpkg/info/libarpack2.postinst
/var/lib/dpkg/info/libarpack2.postrm
/var/lib/dpkg/info/libarpack2.shlibs
/var/lib/dpkg/info/libarpack2.symbols
tom_g
Postby tom_g » Mon Oct 20, 2014 11:08 pm
Hallo Bernd,
it seems as if the Makefile has an error in line 32.
The explicit make target $(LIBS) does not work because cblt2l chose to use the system development packages for libarpack and libspools, meaning there is no separate make target for those libraries.
With the following change, it compiles OK for me on Ubuntu 14.10 (beta). I guess when using the system libraries, you do not need to compile these separately.
--- ccx-2.7-orig/Makefile       2014-03-02 17:58:07.000000000 +0100
+++ ccx-2.7-compiles/Makefile   2014-10-21 05:30:21.075851282 +0200
@@ -29,7 +29,7 @@
 LIBS = -lspooles -larpack -lm -lpthread -lblas
-ccx_2.7: $(OCCXMAIN) $(ACCXMAIN) $(LIBS)
+ccx_2.7: $(OCCXMAIN) $(ACCXMAIN)
        ./date.pl;
        $(CC) $(CFLAGS) -c $(SCCXMAIN)
        $(FC) -Wall -g -o $@ $(OCCXMAIN) $(ACCXMAIN) $(LIBS)
(Why does the original, upstream calculix Makefile even work? Can you really provide a make target in the form "-lLibrary"?
@cblt2l: The upstream calculix sources for version 2.7 have been changed after release, but for some reason, they didn't change the version number. The current version also compiles OK for me, if I use your Makefile and the debian/ subfolder.
I haven't used the compiled programs yet; i only tried a compilation run. Will try the tools tomorrow.
bernd
Postby bernd » Tue Oct 28, 2014 12:24 am
tom_g wrote:... The explicit make target $(LIBS) does not work because cblt2l chose to use the system development packages for libarpack and libspools, meaning there is no separate make target for those libraries... I guess when using the system libraries, you do not need to compile these separately.
@@ -29,7 +29,7 @@
        ./date.pl;
Yeah changeing the makefile did it on my Debian Jessie !! Thanks tom_g
NormandC
Postby NormandC » Tue Apr 07, 2015 3:31 am
Has anyone tried doing this from the newer cxx 2.8p2 source?
I just made an attempt, doing the following steps:
  1. Download ccx_2.8p2.src.tar.bz2 from http://www.dhondt.de/
  2. Extract it
  3. Go into ccx_2.8p2/src and move everything up in /ccx_2.8p2
  4. Copy debian folder from cblt2l into ccx_2.8p2
  5. Copy Makefile from cblt2l's to ccx_2.8p2 and overwrite the existing one
  6. In Makefile, edit all mentions of 2.7 version to 2.8p2
  7. In /debian, edit ccx.install, ccx.links and changelog to replace 2.7 with 2.8p2
Running debuild fails:
gfortran -Wall -g -o ccx_2.8p2 ccx_2.8p2.o ccx_2.8p2.a -lspooles -larpack -lm -lpthread -lblas
ccx_2.8p2.a(dgmres.o): dans la fonction « dcopy_._omp_fn.0 »:
dgmres.f:(.text+0x33): référence indéfinie vers « omp_get_num_threads »
dgmres.f:(.text+0x3b): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dgmres.o): dans la fonction « daxpy_._omp_fn.1 »:
dgmres.f:(.text+0x10c): référence indéfinie vers « omp_get_num_threads »
dgmres.f:(.text+0x113): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dgmres.o): dans la fonction « daxpy_._omp_fn.2 »:
dgmres.f:(.text+0x2aa): référence indéfinie vers « omp_get_num_threads »
dgmres.f:(.text+0x2b2): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dgmres.o): dans la fonction « ddot_._omp_fn.3 »:
dgmres.f:(.text+0x3c1): référence indéfinie vers « omp_get_num_threads »
dgmres.f:(.text+0x3c9): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dgmres.o): dans la fonction « dcopy_ »:
dgmres.f:(.text+0x649): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x658): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dgmres.o): dans la fonction « daxpy_ »:
dgmres.f:(.text+0x7e6): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x7f5): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x856): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x865): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dgmres.o): dans la fonction « dhels_ »:
dgmres.f:(.text+0x9e6): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x9f5): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0xaaa): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0xabc): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dgmres.o): dans la fonction « dorth_ »:
dgmres.f:(.text+0x19f5): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x1a07): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x1ad3): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x1ae5): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x1b9e): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x1bb0): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x1e71): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x1e83): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dgmres.o): dans la fonction « ddot_ »:
dgmres.f:(.text+0x2081): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x2090): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dgmres.o): dans la fonction « dxlcal_ »:
dgmres.f:(.text+0x221c): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x222b): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x22ed): référence indéfinie vers « GOMP_parallel_start »
dgmres.f:(.text+0x22ff): référence indéfinie vers « GOMP_parallel_end »
dgmres.f:(.text+0x383): référence indéfinie vers « GOMP_barrier »
dgmres.f:(.text+0x4c5): référence indéfinie vers « GOMP_barrier »
ccx_2.8p2.a(dslugm.o): dans la fonction « dslui2_._omp_fn.1 »:
dslugm.f:(.text+0xe): référence indéfinie vers « omp_get_num_threads »
dslugm.f:(.text+0x15): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dslugm.o): dans la fonction « dslui2_._omp_fn.0 »:
dslugm.f:(.text+0x13f): référence indéfinie vers « omp_get_num_threads »
dslugm.f:(.text+0x146): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(dslugm.o): dans la fonction « dsmv_._omp_fn.2 »:
dslugm.f:(.text+0x1c4): référence indéfinie vers « omp_get_num_threads »
dslugm.f:(.text+0x1cb): référence indéfinie vers « omp_get_thread_num »
dslugm.f:(.text+0x20d): référence indéfinie vers « GOMP_barrier »
ccx_2.8p2.a(dslugm.o): dans la fonction « dsmv_._omp_fn.3 »:
dslugm.f:(.text+0x304): référence indéfinie vers « omp_get_num_threads »
dslugm.f:(.text+0x30b): référence indéfinie vers « omp_get_thread_num »
dslugm.f:(.text+0x34b): référence indéfinie vers « GOMP_barrier »
dslugm.f:(.text+0x421): référence indéfinie vers « GOMP_barrier »
ccx_2.8p2.a(dslugm.o): dans la fonction « dsmv_ »:
dslugm.f:(.text+0x570): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x57f): référence indéfinie vers « GOMP_parallel_end »
dslugm.f:(.text+0x5cd): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x5dc): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dslugm.o): dans la fonction « dslui_ »:
dslugm.f:(.text+0x676): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x688): référence indéfinie vers « GOMP_parallel_end »
dslugm.f:(.text+0x755): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x764): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(dslugm.o): dans la fonction « dslui2_ »:
dslugm.f:(.text+0x86b): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x87a): référence indéfinie vers « GOMP_parallel_end »
dslugm.f:(.text+0x921): référence indéfinie vers « GOMP_parallel_start »
dslugm.f:(.text+0x930): référence indéfinie vers « GOMP_parallel_end »
dslugm.f:(.text+0x1aa): référence indéfinie vers « GOMP_barrier »
dslugm.f:(.text+0x4f0): référence indéfinie vers « GOMP_barrier »
ccx_2.8p2.a(matvec.o): dans la fonction « matvec_._omp_fn.0 »:
matvec.f:(.text+0x18): référence indéfinie vers « omp_get_num_threads »
matvec.f:(.text+0x1f): référence indéfinie vers « omp_get_thread_num »
matvec.f:(.text+0x14c): référence indéfinie vers « GOMP_barrier »
matvec.f:(.text+0x221): référence indéfinie vers « GOMP_barrier »
ccx_2.8p2.a(matvec.o): dans la fonction « matvec_ »:
matvec.f:(.text+0x57f): référence indéfinie vers « GOMP_parallel_start »
matvec.f:(.text+0x58e): référence indéfinie vers « GOMP_parallel_end »
ccx_2.8p2.a(msolve.o): dans la fonction « msolve_._omp_fn.0 »:
msolve.f:(.text+0xe): référence indéfinie vers « omp_get_num_threads »
msolve.f:(.text+0x15): référence indéfinie vers « omp_get_thread_num »
ccx_2.8p2.a(msolve.o): dans la fonction « msolve_ »:
msolve.f:(.text+0x1a2): référence indéfinie vers « GOMP_parallel_start »
msolve.f:(.text+0x1b1): référence indéfinie vers « GOMP_parallel_end »
make[1]: *** [ccx_2.8p2] Erreur 1
make[1]: quittant le répertoire « /home/normand2/compilation/calculix/ccx_2.8p2 »
make: *** [build] Erreur 2
dpkg-buildpackage: erreur: debian/rules build a produit une erreur de sortie de type 2
debuild: fatal error at line 1364:
dpkg-buildpackage -rfakeroot -D -us -uc failed
I do not like changing the source code so much, for example moving all the files from the /src folder to the root folder and editing the Makefile.
bernd
Postby bernd » Wed Apr 15, 2015 7:57 pm
Just for keeping it. Found this on github.
https://github.com/ricortiz/CalculiX-cmake
NormandC
Postby NormandC » Wed Apr 15, 2015 10:16 pm
Nice find! Unfortunately the author only made one commit, last year. BTW his GitHub profile indicates he works for Kitware, the primary developer of CMake.
I wonder if it might be better to use it as the source to build the deb package, rather than cblt2l's own modified source which did not include the license file and changed the tree.
NormandC
Postby NormandC » Fri Apr 24, 2015 2:32 am
FYI, I just found that CalculiX-CrunchiX (the solver) is a prospective package in Debian, someone is working on it (but there is not much activity so far): https://bugs.debian.org/cgi-bin/bugrepo ... bug=767617
gbrugnoni
Postby gbrugnoni » Mon Nov 30, 2015 9:05 am
I've followed this task trying to fix the mparam problem, that driven me crazy for days.
Finally I've found that the error doesn't depend on netgen version.
I've tried to fix the problem by using netgen-4.9.1, but mparam error was always present.
After some hours of troubles, I've found that freecad executable was completely ignoring the library module libnglib.so.
My mistake was in the NGLIB_LIBRARIES flag of freecad configuration. This flag must be used to indicate the library file, not the library path.
Those are the steps i've succesfully used to build FreeCAD with working FEM module in debian wheezy:
Opencascade configuration, version 6.5.5
$ cd ros
$ ./build_configure
$ ./configure --prefix=/opt/occt-6.5.5 --with-tcl=/usr/lib --with-tk=/usr/lib --with-freetype=/usr --with-ftgl=/usr --with-gl2ps=/usr --with-freeimage=/usr/ --with-tbb-include=/usr/include/tbb --with-tbb-library=/usr/lib/
$ make -j 8
$ sudo make install
NETGEN Configuration, version 5.3.1
$ ./configure --enable-nglib --disable-gui --enable-occ --with-occ=/opt/occt-6.5.5 --prefix=/opt/netgen-5.3.1
The file "libsrc/occ/Partition_Loop2d.cxx" must be patched with this little modification: at line 20, add the following line:
#define PI  M_PI
After this modification the build procedure should run without problems:
$ make -j 8
$ sudo make install
FreeCAD configuration:
$ cmake -DFREECAD_USE_EXTERNAL_PIVY=1 \
-DCMAKE_BUILD_TYPE=Debug \
-DPYTHON_LIBRARY=/usr/lib/libpython2.7.so \
-DPYTHON_INCLUDE_DIR=/usr/include/python2.7 \
-DBUILD_FEM_NETGEN=1 \
-DNGLIB_INCLUDE_DIR=/opt/netgen-5.3.1/include \
-DNGLIB_LIBRARIES:FILEPATH=/opt/netgen-5.3.1/lib/libnglib.so \
-DNETGENDATA=/home/user/local/build/netgen/netgen-5.3.1/libsrc \
-DCMAKE_CXX_FLAGS=-DNETGEN_V5 \
-DBUILD_ASSEMBLY=1 \
-DOCC_INCLUDE_DIR=/opt/occt-6.5.5/inc/ \
-DOCC_LIBRARY_DIR=/opt/occt-6.5.5/lib/ \
../src/free-cad-code/
$ make -j 8
$ sudo make install
That's all!
bernd
Postby bernd » Mon Nov 30, 2015 11:58 am
@gbrugnoni
thanks for your informations in the regard of netgen but this thread is only for compiling CalculiX ccx !!!
