Help Compiling FC to test PR.
bleber
Post by bleber »
Hi.
I like to compile freecat to test PR, I start with these guide.
https://wiki.freecadweb.org/Compile_on_Windows
C make no errors, but when copiling have lot of warnings 62+ but not errors.
Finally when execute freecad.exe I have some errors and freecat not start.
freecad.exe system error not found
python38.dll
qt5widgets.dll
qt5gui.dll
qt5core.dll
Info:
W10Home
install GIT Git-2.32.0.2-64-bit
clone: https://github.com/FreeCAD/FreeCAD.git with tortoise GUI
Libpack: FreeCADLibs_12.5.2_x64_VC17.7z
Install Visual Studio Community vs_community__2002586652.1627323458 and install Visual C++ tools for CMake in VSC
install cmake-3.21.1-windows-x86_64, make configure ( no red flags ) make generate and open project.
IN VSC select release and all_build build.
openBrain
Re: Help Compiling FC to test PR.
Post by openBrain »
I guess that this is what is explained in https://wiki.freecadweb.org/Compile_on_ ... ng_FreeCAD
GeneFC
Post by GeneFC »
I have used those instructions numerous times. The warnings are not important; they just say that some code constructions are not the preferred method.
It is essential that the instructions on the referenced wiki page are followed exactly. Every time I have had a failure I went back and discoved I had skipped something.
The missing files issue indicates you may have skipped the section that says:
FREECAD_COPY_DEPEND_DIRS_TO_BUILD
FREECAD_COPY_LIBPACK_BIN_TO_BUILD
FREECAD_COPY_PLUGINS_BIN_TO_BUILD
Gene
bleber
Post by bleber »
Ok, thanks, I can now build freecad, but how to test a PR for example "Add Preference Pack support #4787"
Post by Kunda1 »
bieber, you can follow the instructions given by wmayer in this ticket but apply it to the relevant PR.
This is assuming you have previously cloned FreeCAD
cd Path_to_FreeCAD
git fetch https://github.com/chennes/FreeCAD/ addThemeSupport:addThemeSupport
mkdir ../build_addThemeSupport
git worktree add ../build_addThemeSupport addThemeSupport
cd ../build_addThemeSupport
mkdir build
cd build
cmake .. # eventually pass any parameters or run the GUI of cmake
make
openBrain
Post by openBrain »
Kunda1 wrote: Fri Jul 30, 2021 12:36 am bieber, you can follow the instructions given by wmayer in this ticket but apply it to the relevant PR.
IMO using a worktree is a bit overkill for this. :)
The simple method is (for PR 4752 as an example) :
git fetch origin pull/4752/head:MY_SUPER_TEST
git checkout MY_SUPER_TEST
Then just build (run 'make') as previously.
