[SOLVED] Path WB & Boost 1.75
Gift
Post by Gift »
If I compile FreeCAD without path. All works fine. Cmake do not find python3 in the path module:
-- /tmp/freecad-20210730-62717-mgg84p/Build/src/Mod/Path/App/VoronoiVertexPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- Could NOT find Boost: missing: python39 (found /opt/homebrew/lib/cmake/Boost-1.75.0/BoostConfig.cmake (found version "1.75.0"))
-- Could NOT find Boost: missing: python3 (found /opt/homebrew/lib/cmake/Boost-1.75.0/BoostConfig.cmake (found version "1.75.0"))
CMake Error at /opt/homebrew/lib/cmake/Boost-1.75.0/BoostConfig.cmake:141 (find_package):
  Could not find a package configuration file provided by "boost_python"
  (requested version 1.75.0) with any of the following names:
Other modules like Part uses boost too. Someone know where is difference to the path wb? Thanks for supporting.
Homebrew, boost 1.75.0, cmake version 3.21.1
Gift
Re: Path WB & Boost 1.75
Post by Gift »
