! notification - C:/:/dd/icons/linear Dimension.svg -
James Lisbon
Post by James Lisbon »
Am new to FreeCAD ( and am a tech Neanderthal ) - just installed 19 on windows OS , everything seems to be fine EXCEPT each time I open I get a notification :
File does not exist
! C:/:/dd/icons/linear dimension.svg
with a green opening status of 70%
I click OK and it goes away, returns to normal
Does this indication mean that there will no linear dimension icons when I am in for example a sketcher workbench
Should I uninstall and reinstall?
Re: ! notification - C:/:/dd/icons/linear Dimension.svg -
Hi and welcome to the forum!
You have probably still the outdated DrawingDimensioning workbenchh installed. It is deprecated as well as the Drawing workbench. Uninstall DrawingDimensioning and use TechDraw instead.
James Lisbon
OK thank you for the prompt reply - I will attempt your suggestion
best regards
zutxita
Post by zutxita »
chrisb wrote: Fri Aug 06, 2021 12:28 pm Hi and welcome to the forum!
Hi, I have the same issue, how do I unninstall this workbench?
GeneFC
Post by GeneFC »
zutxita wrote: Sat Aug 28, 2021 6:15 pm how do I unninstall this workbench?
From the main screen go into Tools >> Addon Manager.
Select the DrawingDimensioning WB from the left-hand column and uninstall.
Gene
fluid
Post by fluid »
thanks, I had the same problem and it's gone now.
Charles
