Issues compiling freecad(opencascade)
Gip-Gip
Post by Gip-Gip »
I've had issues trying to compile freecad using cmake and I have yet to be able to rectify them
At first I thought it was a pthreads issue but that is, for some reason, an error that crops up when other things also fail.
This is the only other error I have. I do have open cascade installed.
CMake Error at cMake/FindOpenCasCade.cmake:101 (file):
  file STRINGS file "//include/opencascade/Standard_Version.hxx" cannot be
  read.
  cMake/FreeCAD_Helpers/SetupOpenCasCade.cmake:4 (find_package)
  CMakeLists.txt:51 (SetupOpenCasCade)
CMake Error at cMake/FindOpenCasCade.cmake:104 (string):
  string sub-command REGEX, mode MATCH needs at least 5 arguments total to
  command.
CMake Error at cMake/FindOpenCasCade.cmake:105 (file):
  read.
CMake Error at cMake/FindOpenCasCade.cmake:108 (string):
  command.
CMake Error at cMake/FindOpenCasCade.cmake:109 (file):
  read.
CMake Error at cMake/FindOpenCasCade.cmake:112 (string):
  command.
CMake Warning (dev) at /usr/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
  The package name passed to `find_package_handle_standard_args` (OCC) does
  not match the name of the calling package (OpenCasCade).  This can lead to
  problems in calling code that expects `find_package` result variables
  (e.g., `_FOUND`) to follow a certain pattern.
  cMake/FindOpenCasCade.cmake:120 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Found OCC: //include/opencascade (found version "..")
-- -- Found OCE/OpenCASCADE version: ..
-- -- OCE/OpenCASCADE include directory: //include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: //lib
jeinzi
Re: Issues compiling freecad(opencascade)
Post by jeinzi »
Sorry for necrobumping - I just faced the same issue and want to leave my solution here.
I am using Arch Linux and have no /include directory, so the solution for me was to simply edit cMake/FindOpenCasCade.cmake and replace
set(OCC_INCLUDE_DIR ${OpenCASCADE_INCLUDE_DIR})
with
set(OCC_INCLUDE_DIR "/usr/include/opencascade")
Hope this helps someone :)
