Launch from Windows installer fails to drop privileges
Re: Launch from Windows installer fails to drop privileges
uwestoehr wrote: Tue Oct 26, 2021 2:32 am You miss the point: What you call "improvement" would mean to get rid of the feature. I explained it quite often and you must admit that I was very patient. However at some point I cannot repeat again and again. If you don't like the feature, feel free to remove it but expect complaints from admins about the missing feature.
A clarifying text wouldn't remove any feature, nor would fixing the uninstall issue - provided it can be reproduced.
uwestoehr
Post by uwestoehr »
chrisb wrote: Tue Oct 26, 2021 9:00 am A clarifying text wouldn't remove any feature, nor would fixing the uninstall issue - provided it can be reproduced.
I fully agree here. However, at first I need to be able to reproduce the uninstallation your described. i tested today on my second PC and could also not reproduce this. So I need further screenshots or step by step info from you.
sgrogan
Post by sgrogan »
uwestoehr wrote: Mon Oct 25, 2021 12:32 pm What I will now (as soon I find time) do is to assure the option is off by default. So people with less knowledge will not run into this.
This is all I ask for. Thanks :)
"fight the good fight"
uwestoehr
Post by uwestoehr »
sgrogan wrote: Tue Oct 26, 2021 10:19 pm This is all I ask for. Thanks :)
I had a look, and this is already the case. You must actively set this option to use it.
