Build on MacOS missing security options.
keithsloan52
Post by keithsloan52 »
https://support.apple.com/en-gb/guide/m ... a35146/mac
Describes how to control an applications access to Documents/Downloads etc.
FreeCAD does not show up as a possible application :-(, so looks like FreeCAD on a Mac is missing setting some security options.
Problem occurs on MacOS - Catalina
see also https://forum.freecadweb.org/viewtopic.php?f=3&t=62434
doia
Re: Build on MacOS missing security options.
Post by doia »
I'm running on 0.19.2 and 0.20 latest master on Mac Big Sur. Haven't had a problem accessing these folders so far.
Do want to access these folders and are not able to do so? Or do you want explicitly grant (and revoke) access for FreeCAD?
keithsloan52
doia wrote: Thu Sep 23, 2021 4:54 pm Do want to access these folders and are not able to do so? Or do you want explicitly grant (and revoke) access for FreeCAD?
I have a problem when trying to load a scad file that loads an OpenSCAD library. OpenSCAD Libraries are stored in Documents
see https://forum.freecadweb.org/viewtopic.php?f=3&t=62434
What happens if you go to the python console in FreeCAD and enter
os.listdir('/Users/<your_user_name>/Documents')
Do you get something like
os.listdir('/Users/keithsloan/Documents')
PermissionError: [Errno 1] Operation not permitted: '/Users/keithsloan/Documents'
If you go to 'System Preferences' | 'Security & Privacy' | 'Privacy' | 'Files and Folder'
Is FreeCAD one of the listed Application?
doia
Post by doia »
Sorry, misunderstood you. Thought you were having trouble accessing the Documents and Download folders in the "Open File" dialog.
On the python console within FreeCAD I have the same errors as you.
From a separate terminal within an interactive Python session the command succeeds:
- Opening iterm on MAC and typing
➜  ~ python3
Python 3.9.7 (default, Sep  3 2021, 12:37:55)
[Clang 12.0.5 (clang-1205.0.22.9)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> os.listdir("/Users/my-username/Downloads")
//-> this lists the content of the downloads folder
doia
Post by doia »
Hold up, I did a differentiated test:
code into FC Python console directly after start-up (no other action or WB change)
os.listdir("/Users/my-user-name/Downloads")
v0.19-24291 --> access denied
OS: macOS 10.16
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
v0.20-25645 (weekly build from FreeCAD-Bundle https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds) --> access to folder succeeded
OS: macOS 10.16
Version: 0.20.25645 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
So, the error seems to be a v0.19 issue. -> Thats's why you always should post your version info ;)
keithsloan52
doia wrote: Fri Sep 24, 2021 8:21 am
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
Thanks - I had checked v0.20-25566 and it had the problem.
As does
OS: macOS 10.15
Version: 2021.922.24301 +4188 (Git)
Branch: LinkDaily
Hash: 3de879c7a2ba7111cc769d98636eb6d43189459d
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
