[SOLVED] FC compilation fails with OCCT 7.6.0 beta.
fcaduser
Post by fcaduser »
Hello FC team.
Last FC code pulled today.
Debian 11, but clearly it is not related to the environment.
Thanks.
mainuser@station1:~/software/freecad_source/build_2021-10-07$ make -j 1
[  1%] Built target SMDS
[  1%] Built target Driver
[  2%] Built target DriverSTL
[  2%] Built target SMESHDS
[  2%] Built target DriverUNV
[  2%] Built target DriverDAT
[  2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_Mesh.cpp.o
In file included from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Message_ProgressScope.hxx:23,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Message_ProgressIndicator.hxx:157,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Message_ProgressRange.hxx:111,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/BRepBuilderAPI_MakeShape.hxx:28,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/BRepPrimAPI_MakeBox.hxx:25,
                 from /home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/SMESH/SMESH_Mesh.cpp:69:
/home/mainuser/software/occt-cf9dd8a/include/opencascade/Precision.hxx:98:7: error: redefinition of ‘class Precision’
   98 | class Precision
In file included from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Extrema_POnSurf.lxx:15,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Extrema_POnSurf.hxx:75,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Extrema_ExtPElS.hxx:27,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Extrema_ExtPS.hxx:24,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/ShapeAnalysis_Surface.hxx:20,
                 from /home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/inc/SMESH_MesherHelper.hxx:37,
                 from /home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/SMESH/SMESH_Mesh.cpp:34:
/home/mainuser/software/occt-cf9dd8a/include/opencascade/Precision.hxx:98:7: note: previous definition of ‘class Precision’
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/build.make:407 : src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_Mesh.cpp.o] Erreur 1
make[1]: *** [CMakeFiles/Makefile2:2474 : src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/all] Erreur 2
make: *** [Makefile:149 : all] Erreur 2
Founder
Re: FC compilation fails with OCCT 7.6.0 beta.
Post by wmayer »
This is the culprit: https://github.com/FreeCAD/FreeCAD/blob ... sh.cpp#L67
When compiling SMESH_Mesh.cpp at an earlier point the compiler includes Precision.hxx and later it will be included again. Now because of undefining _Precision_HeaderFile the compiler sees the class declaration a second time and thus raises an error.
This change has added the line: https://git.salome-platform.org/gitweb/ ... 5d477a1813
Originally the line was added to an older branch with: https://git.salome-platform.org/gitweb/ ... 59d68d1095
The commit log message:
0020062: [CEA 295] Type coherence in *.i files
doesn't tell why it was done.
My guess is that the OCCT version from 2008 had a mistake with a file guard.
Founder
Post by wmayer »
Please try again.
git commit 77b198048a
fcaduser
Post by fcaduser »
Testing... Thank you.
fcaduser
Post by fcaduser »
One step beyond...
[  2%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MeshAlgos.cpp.o
In file included from /home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/SMESH/SMESH_MeshAlgos.cpp:42:
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:39:40: error: ‘gp_Sphere’ does not name a type; did you mean ‘gp_Other’?
   39 |   Standard_EXPORT IntAna_Quadric(const gp_Sphere& Sph);
      |                                        gp_Other
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:42:40: error: ‘gp_Cylinder’ does not name a type
   42 |   Standard_EXPORT IntAna_Quadric(const gp_Cylinder& Cyl);
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:42:19: error: ‘IntAna_Quadric::IntAna_Quadric(const int&)’ cannot be overloaded with ‘IntAna_Quadric::IntAna_Quadric(const int&)’
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:39:19: note: previous declaration ‘IntAna_Quadric::IntAna_Quadric(const int&)’
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:45:40: error: ‘gp_Cone’ does not name a type
   45 |   Standard_EXPORT IntAna_Quadric(const gp_Cone& Cone);
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:45:19: error: ‘IntAna_Quadric::IntAna_Quadric(const int&)’ cannot be overloaded with ‘IntAna_Quadric::IntAna_Quadric(const int&)’
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:51:42: error: ‘gp_Sphere’ does not name a type; did you mean ‘gp_Other’?
   51 |   Standard_EXPORT void SetQuadric (const gp_Sphere& Sph);
      |                                          gp_Other
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:54:42: error: ‘gp_Cone’ does not name a type
   54 |   Standard_EXPORT void SetQuadric (const gp_Cone& Con);
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:54:24: error: ‘void IntAna_Quadric::SetQuadric(const int&)’ cannot be overloaded with ‘void IntAna_Quadric::SetQuadric(const int&)’
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:51:24: note: previous declaration ‘void IntAna_Quadric::SetQuadric(const int&)’
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:57:42: error: ‘gp_Cylinder’ does not name a type
   57 |   Standard_EXPORT void SetQuadric (const gp_Cylinder& Cyl);
/home/mainuser/software/occt-cf9dd8a/include/opencascade/IntAna_Quadric.hxx:57:24: error: ‘void IntAna_Quadric::SetQuadric(const int&)’ cannot be overloaded with ‘void IntAna_Quadric::SetQuadric(const int&)’
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/build.make:420 : src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MeshAlgos.cpp.o] Erreur 1
      |                                        gp_Other
      |                                          gp_Other
Founder
Post by wmayer »
That's an internal bug in OCCT. In previous versions of IntAna_Quadric.hxx there were some forward declarations:
class gp_Pln;
class gp_Sphere;
class gp_Cylinder;
class gp_Cone;
class gp_Ax3;
and they have been removed now: https://git.dev.opencascade.org/gitweb/ ... b2e#patch7
Removing the forward declarations is a regression and doesn't make any sense to me.
So, to work around that all what you can do is adding the needed header files before including IntAna_Quadric.hxx. So add this to SMESH_MeshAlgos.cpp
#include <gp_Pln.hxx>
#include <gp_Sphere.hxx>
#include <gp_Cylinder.hxx>
#include <gp_Cone.hxx>
fcaduser
Post by fcaduser »
What's next.
[  3%] Built target SMESH
[  3%] Built target MEFISTO2
[  3%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Adaptive1D.cpp.o
/home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Adaptive1D.cpp: In constructor ‘{anonymous}::TriaTreeData::TriaTreeData(const TopoDS_Face&, {anonymous}::ElementBndBoxTree*)’:
/home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Adaptive1D.cpp:321:33: error: ‘class Poly_Triangulation’ has no member named ‘Nodes’; did you mean ‘Node’?
  321 |       myNodes           = & tr->Nodes();
      |                                 Node
/home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Adaptive1D.cpp:322:43: warning: ‘const Poly_Array1OfTriangle& Poly_Triangulation::Triangles() const’ is deprecated: Deprecated method, Triangle() should be used instead [-Wdeprecated-declarations]
  322 |       myPolyTrias       = & tr->Triangles();
In file included from /home/mainuser/software/occt-cf9dd8a/include/opencascade/Poly_ListOfTriangulation.hxx:20,
                 from /home/mainuser/software/occt-cf9dd8a/include/opencascade/BRep_Tool.hxx:30,
                 from /home/mainuser/software/freecad_source/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Adaptive1D.cpp:40:
/home/mainuser/software/occt-cf9dd8a/include/opencascade/Poly_Triangulation.hxx:318:32: note: declared here
  318 |   const Poly_Array1OfTriangle& Triangles() const { return myTriangles; }
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/build.make:108 : src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Adaptive1D.cpp.o] Erreur 1
make[1]: *** [CMakeFiles/Makefile2:2535 : src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/all] Erreur 2
user1234
Post by user1234 »
Does it make sense to update the smesh sources? They seems to be outdated (7.7.1 vs. 9.7.0) and make problems on more places, like
here: https://forum.freecadweb.org/viewtopic.php?t=51997
and here: https://forum.freecadweb.org/viewtopic.php?t=62566
I have compiled smesh successfully, but are not able use it as external library in FreeCAD. Got to many cmake errors, they i do not understand.
Greetings
user1234
fcaduser
Post by fcaduser »
At this point my goal is to pinpoint all the modifications needed that can be straightforwardly done to the FC code without hassle. Concerning the third parties codes, we'll see point by point what can be done.
Founder
Post by wmayer »
To shorten the ping-pong here I have fetched the 7.6 sources and use it for FreeCAD.
